Make the object a block, then use the Measure (or Divide) command with the block option.
Is there a way to copy an object along a p-line path.???
Thanks. I did that. However I want to have my block spaced out exactly 1' apart.??? How do I do that.???
Use MEASURE
"Constantly choosing the lesser of two evils is still choosing evil." ~ Jerry Garcia
flickr | work | blog | creed
rustysilo's tips & tutorials
how i could copy object along p line with uneven distance?
Someone, I think lpseifert, posted one here some time ago called measureplinepts.lsp, but it might take some searching.
Here's one similar to the one Rusty referred to. You could modify it to insert blocks instead of points.
>>edit<<Code:;places point at specified station along a polyline, measured from start LPS 2008 (defun c:pop () (vl-load-com) (setq oldosnap (getvar "osmode")) (setvar "osmode" 0) (command "ucs" "w") (if (/= (getvar "pdmode") 3)(setvar "pdmode" 3)) (setq ob (entsel "Select curve: ")) (setq p2 (getreal "\n Specify Distance : ")) (setq obj (vlax-ename->vla-object (car ob))) (setq pt1 (vlax-curve-getPointAtDist Obj p2)) (command "Point" pt1) (command "ucs" "p") (setvar "osmode" oldosnap) (princ) )
never mind, here is the PUT.lsp, seems to be what you want
you guys awsome thx a lot.
