Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Full Member
    not specified
    Apr 2006
    Philippines
    61
    Default Lisp for dimensioning
    Can you please provide me a lisp wherein when you make a line, arc or a circle, the dimension is already incorporated into it. The dimension lines should be located at 7mm above or below the line. Thanks.
    Senior Member wizman's Avatar
    AutoCAD 2009
    Nov 2007
    Abu Dhabi / Philippines
    408
    here is one for lines:
    Code:
    (defun c:DLine (/ line_pt1 line_pt2)
      (if (and (setq line_pt1 (getpoint ">>>...Pick First Point...>>>:"))
    	   (setq line_pt2 (getpoint line_pt1 ">>>...Pick next point...>>>: "))
          (vl-cmdf "._line" line_pt1 line_pt2 "")
          (while line_pt2
    	(command "._dimaligned"
    		 line_pt1
    		 line_pt2
    		 (polar	line_pt2
    			(+ (angle line_pt1 line_pt2) (/ pi 2))
    			7
    	(setq line_pt1 line_pt2
    	      line_pt2 '()
    	(if (and line_pt1
    Full Member
    not specified
    Apr 2006
    Philippines
    61
    Hi Wizman,
    Thanks for the lisp file. It's the lisp that I'm looking for. But I apologize that I didn't give you a detailed explanation on the lisp that suits my needs. Actually I needed a lisp that could dimension a kind of reinforcing bar bending lenght. And I draw it into different scales (1/30, 1/20) but mostly 1/50 scale. The 7 mm distance of the dimension line is the actual distance from the rebar when you plot it to a given scale. So for a 1/50 scale the distance should be 350 mm, 1/30 is 210 mm and 1/20 is 140 mm. I hope you'll find time to send me another lisp. Thanks you very much.
    P.S. Could you make the layer of the dimension separated from the rebar.
    AutoCAD 2009
    Nov 2007
    408
    this works for lines, i'll see if i can find time later for arcs.
    Code:
    (defun
         c:DLine
    	     line_pt1
    	     line_pt2
    	     dline_scale
    	     dline_curlay
    	     dline_scale_dist
    	     *error*
      (defun
           *error*
    	      (msg)
        (setvar 'clayer dline_curlay)
        (Setvar 'cmdecho 1)
      ) ;_ end_defun
      (Setvar 'cmdecho 0)
      (setq dline_curlay (getvar "clayer"))
      (command
        "Layer"
        "on"
        "DIMS"
        "unlock"
        "DIMS"
        "thaw"
        "DIMS"
        "m"
        "DIMS"
        "c"
        "6"
        "DIMS"
      ) ;_ end_command
     ;_ end_command
      ;;user input function by Cab
      (while
          (setq dline_scale
    	     (cond ((getint "\nEnter the drawing scale [20/30/50] <50>: "))
    		   (50)
    	     ) ;_ end_cond
          ) ;_ end_setq
          (if (not (vl-position dline_scale '(20 30 50)))
    	(not (prompt "\nChoose only from 20 30 & 50, please re-enter.")
    	) ;_ end_not
          ) ;_ end_if
        ) ;_ end_progn
      ) ;_ end_while
      (cond
        ((= dline_scale 20) (setq dline_scale_dist 140))
        ((= dline_scale 30) (setq dline_scale_dist 210))
        ((= dline_scale 50) (setq dline_scale_dist 350))
      ) ;_ end_cond
      (if
        (and
          (setq line_pt1
    	     (getpoint
    	       "\n>>>...Pick First Point...>>>: "
    	     ) ;_ end_getpoint
          ) ;_ end_setq
          (setq line_pt2
    	     (getpoint
    	       line_pt1
    	       "\n>>>...Pick next point...>>>: "
    	     ) ;_ end_getpoint
          ) ;_ end_setq
        ) ;_ end_and
           (while line_pt2
    	 (setvar 'clayer "DIMS")
    	 (command
    	   "._dimaligned"
    	   "non"
    	   line_pt1
    	   "non"
    	   line_pt2
    	   "non"
    	   (polar
    	     line_pt2
    	     dline_scale_dist
    	   ) ;_ end_polar
    	 ) ;_ end_command
    	       line_pt2	'()
    	 ) ;_ end_setq
    	 (if (and line_pt1
    		  (setq	line_pt2
    			 (getpoint
    			   line_pt1
    			 ) ;_ end_getpoint
    		  ) ;_ end_setq
    	     ) ;_ end_and
    	 ) ;_ end_if
           ) ;_ end_while
         ) ;_ end_progn
      ) ;_ end_if
      (*error* "")
    ) ;_ end_defun
    (prompt
      "\n>>>...dline.lsp is now loaded. Type dline to run...<<<"
    ) ;_ end_prompt
    Full Member
    not specified
    Apr 2006
    Philippines
    61
    Thanks Wizman, It works perfectly. Would it be possible for a lisp in such a way that when you pick a polyline (please see attachment) it will execute the same mode of dimensioning?
  6. #6
    AutoCAD 2009
    Nov 2007
    408
    update no. 3
    Code:
        PROGRAM CREATED FOR POLYLINE(with multiple segments) DIMENSIONING
        DATE: OCTOBER 19, 2008
        CREATED BY: WIZMAN
    (defun c:mdim
    	      (/		ent_layer
    	       mdim_curdimscal	mdim_curlay
    	       mdim_curluprec	mdim_curosmode
    	       mdim_enttemp	mdim_enttemp2
    	       mdim_pline_ent	mdim_pline_ent_vla
    	       mdim_pline_pts	mdim_pt1
    	       mdim_pt2		mdim_x
    	       mdim_x1		mdim_y
    	       mdim_y1		x
    	       *error*		2ND_POINT
    	       DERIV_AT_POINT	ENT_CLOSED
    	       ENT_ENTGET	ENT_LAYER
    	       ENT_TEMP_OPEN	LINE_PT1
    	       LINE_PT2		MDIM_CLOCKTEST
    	       MDIM_COUNTER	MDIM_CURDIMSCAL
    	       MDIM_CURLAY	MDIM_CURLUPREC
    	       MDIM_CUROSMODE	MDIM_DAN
    	       MDIM_ENTTEMP	MDIM_ENTTEMP2
    	       MDIM_PLINE_ENT	MDIM_PLINE_ENT_VLA
    	       MDIM_PLINE_PTS	MDIM_PT1
    	       MDIM_PT2		MDIM_SCALE
    	       MDIM_SCALE_DIST	MDIM_X
    	       MDIM_X1		MDIM_Y
    	       MDIM_Y1		MIDPOINT_AT_CURVE
    	       PARAM_AT_POINT	RON1
    	       RON2		X
      (vl-load-com)
      (defun
    	 *error*
    		(msg)
        (setvar 'clayer mdim_curlay)
        (setvar 'dimscale mdim_curdimscal)
        (setvar 'luprec mdim_curluprec)
        (command "._undo" "_end")
        (setvar 'cmdecho 1)
        (setvar 'osmode mdim_curosmode)
      ) ;_ end_defun
      (defun
    	 mdim_revpoly
    		     (selected_pline)
        (setq mdim_pt1
    	   (vlax-curve-getendpoint
    	     (vlax-ename->vla-object selected_pline)
    	   ) ;_ end_vlax-curve-getendpoint
        ) ;_ end_setq
        (setq mdim_y (cadr mdim_pt1))
        (setq mdim_x (car mdim_pt1))
        (setq mdim_x1 (+ mdim_x 100))
        (setq mdim_y1 (+ mdim_y 100))
        (setq mdim_pt2 (list mdim_x mdim_y1))
        (setvar 'clayer ent_layer)
        (command "line" "NON" mdim_pt2 "NON" mdim_pt1 "")
        (setq mdim_enttemp (entlast))
        (command "pedit" mdim_enttemp "y" "j" selected_pline "" "")
        (setq mdim_enttemp2 (entlast))
        (command "break" mdim_enttemp2 "NON" mdim_pt1 "NON" mdim_pt1) ;_ end of command
     ;_ end of command
     ;_ end of command
        (entupd mdim_enttemp2)
        (command "erase" mdim_enttemp2 "")
        (setq mdim_pline_ent (entlast))
        (setq mdim_pline_pts
    	   (mapcar
    	     '(lambda (x) (trans x 0 1))
    	     (mapcar
    	       'cdr
    	       (vl-remove-if-not
    		 '(lambda (x) (= 10 (car x)))
    		 (entget
    		   mdim_pline_ent
    		 ) ;_ end_entget
    	       ) ;_ end_vl-remove-if-not
    	     ) ;_ end_mapcar
    	   ) ;_ end_mapcar
        ) ;_ end_setq
        (defun
    	   clockwise-p
    		      (p1 p2 p3)
          (< (sin (- (angle p1 p3) (angle p1 p2))) -1e-14)
        ) ;_ end_defun
        (setq mdim_pline_ent_vla
    	   (vlax-ename->vla-object mdim_pline_ent)
    					;(command "._regen")
        ) ;_ end_setq
      ) ;_ end_defun
      (setvar 'cmdecho 0)
      (command "._undo" "_begin")
      (setq mdim_curlay (getvar 'clayer))
      (setq mdim_curdimscal (getvar 'dimscale))
      (setq mdim_curluprec (getvar 'luprec))
      (setq mdim_curosmode (getvar 'osmode))
      (command
        "Layer" "m"	"DIMS" "unlock"	"DIMS" "thaw" "DIMS" "on" "DIMS" "c" "6" "DIMS"	"") ;_ end_command
     ;_ end_command
     ;_ end_command
     ;_ end_command
      (while
          (setq mdim_scale
    		   (50)
    	     ) ;_ end_cond
          ) ;_ end_setq
          (if (not (vl-position mdim_scale '(20 30 50)))
    	(not
    	) ;_ end_not
          ) ;_ end_if
        ) ;_ end_progn
      ) ;_ end_while
      (cond
        ((= mdim_scale 20) (setq mdim_scale_dist 140))
        ((= mdim_scale 30) (setq mdim_scale_dist 210))
        ((= mdim_scale 50) (setq mdim_scale_dist 350))
      ) ;_ end_cond
      (setvar 'dimscale mdim_scale)
      (while
        (not
          (setq
    	mdim_pline_ent
    	 (ssget ":E:S" '((0 . "LWPOLYLINE")))
          ) ;_ end_setq
        ) ;_ end_not
         (princ "\nMISSED....PICK AGAIN")
      ) ;_ end_while
    ;;;  (command "._break" (ssname mdim_pline_ent 0)    (vlax-curve-getendpoint (vlax-ename->vla-object (ssname mdim_pline_ent 0)))
    ;;;    (vlax-curve-getendpoint (vlax-ename->vla-object (ssname mdim_pline_ent 0)))))
      (setq ent_layer (cdr (assoc 8 (entget (ssname mdim_pline_ent 0)))))
    	 (mapcar
    	   (mapcar
    	     'cdr
    	     (vl-remove-if-not
    	       (entget
    	       ) ;_ end_entget
    	   ) ;_ end_mapcar
    	 ) ;_ end_mapcar
      ) ;_ end_setq
      (if (and
    	(= (setq ent_closed (cdr (assoc 70 (entget (ssname mdim_pline_ent 0))))) 1)
    	(not (Setq mdim_clocktest
    		    (clockwise-p
    		      (car mdim_pline_pts)
    		      (cadr mdim_pline_pts)
    		      (caddr mdim_pline_pts)
    		    ) ;_ end_clockwise-p
    	     ) ;_ end_Setq
    	) ;_ end_not
          ) ;_ end_and
          (setq ent_entget (entget (ssname mdim_pline_ent 0)))
          (entmod (subst (cons 70 0) (assoc 70 ent_entget) ent_entget))
          (setq ent_temp_open t)
        ) ;_ end_progn
      ) ;_ end_if
      (if (not mdim_clocktest
     ;_ end_Setq
          ) ;_ end_not
        (mdim_revpoly (ssname mdim_pline_ent 0))
        ) ;_ end_setq
     ;_ end_setq
      ) ;_ end_if
      (setvar 'osmode 0)
      (setq mdim_counter 0)
      (while
        (< mdim_counter
           (fix
    	 (vlax-curve-getendparam mdim_pline_ent_vla)
           ) ;_ end_fix
        ) ;_ end_<
         (setq line_pt1
    	    (vlax-curve-getpointatparam mdim_pline_ent_vla mdim_counter)
         ) ;_ end_setq
         (setq line_pt2
    	      mdim_pline_ent_vla
    	      (1+ mdim_counter)
    	    ) ;_ end_vlax-curve-getpointatparam
         ) ;_ end_setq
         (command "._layer" "s" "DIMS" "")
         (if (= (vla-getbulge mdim_pline_ent_vla mdim_counter) 0.0)
    	 (princ "\nstraight")
    	 (command
    	   "._dimaligned"
    	   "non"
    	   line_pt1
    	   "non"
    	   line_pt2
    	   "non"
    	   (polar
    	     line_pt2
    	     mdim_scale_dist
    	   ) ;_ end_polar
    	 ) ;_ end_command
           ) ;_ end_progn
    	 (princ "\ncurve")
    	 (setq midpoint_at_curve
    		(vlax-curve-getpointatdist
    		  mdim_pline_ent_vla
    			(vlax-curve-getdistatparam
    			  mdim_pline_ent_vla
    			  (1+ mdim_counter)
    			) ;_ end of vlax-curve-getdistatparam
    			  mdim_pline_ent_vla
    			  mdim_counter
    		      ) ;_ end of -
    		      0.5
    		    ) ;_ end of *
    		    (vlax-curve-getdistatparam mdim_pline_ent_vla mdim_counter)
    		  ) ;_ end of +
    		) ;_ end of vlax-curve-getpointatdist
    	 ) ;_ end of setq
    	 (setq param_at_point
    		(vlax-curve-getparamatpoint
    		  mdim_pline_ent_vla
    		  midpoint_at_curve
    		) ;_ end of vlax-curve-getparamatpoint
    	 ) ;_ end of setq
    	 (setq deriv_at_point
    		(vlax-curve-getfirstderiv
    		  mdim_pline_ent_vla
    		  param_at_point
    		) ;_ end of vlax-curve-getfirstderiv
    	 ) ;_ end of setq
    	 (setq 2nd_point (mapcar '+ midpoint_at_curve deriv_at_point))
    	 (command
    	   "._dimangular"
    	   (osnap (vlax-curve-getpointatparam
    		    mdim_pline_ent_vla
    		    param_at_point	;(1+ mdim_counter)
    		  "_cen"
    	   ) ;_ end_osnap
    	   line_pt1
    	   line_pt2
    	   "non"
    	   (polar
    	     midpoint_at_curve
    	     (+ (angle midpoint_at_curve 2nd_point) (/ pi 2))
    	     mdim_scale_dist
    	   ) ;_ end_polar
    	 ) ;_ end_command
    	 (setq mdim_dan (vlax-ename->vla-object (entlast)))
    					;(setvar 'luprec 0)
    	 (vla-put-TextOverride
    	   mdim_dan
    	   (rtos
    	     (-	(Setq ron1 (vlax-curve-getdistatparam
    			     mdim_pline_ent_vla
    			     (1+ mdim_counter)
    			   ) ;_ end_vlax-curve-getdistatparam
    		(Setq ron2 (vlax-curve-getdistatparam
    			     mdim_pline_ent_vla
    			     mdim_counter
    		) ;_ end of Setq
    	     ) ;_ end_-
    	     2
    	     0
    	   ) ;_ end_-
    	 ) ;_ end_-
           ) ;_ end_vla-put-TextOverride
         ) ;_ end_progn
         (setq mdim_counter (1+ mdim_counter))
      ) ;_ end_while
      (if ent_temp_open
          (entmod (subst (cons 70 1) (assoc 70 (entget mdim_pline_ent)) (entget mdim_pline_ent)))
          (command
    	"._dimaligned"
    	"non"
    	  mdim_pline_ent_vla
    	  (1- (vlax-curve-getendparam mdim_pline_ent_vla))
    	"non"
    	(vlax-curve-getpointatparam mdim_pline_ent_vla (vlax-curve-getendparam mdim_pline_ent_vla))
    	"non"
    	(polar
    	    mdim_pline_ent_vla
    	  (+ (angle (vlax-curve-getpointatparam
    		      mdim_pline_ent_vla
    		      mdim_pline_ent_vla
    	     ) ;_ end_angle
    	     (/ pi 2)
    	  ) ;_ end_+
    	  mdim_scale_dist
    	) ;_ end_polar
          ) ;_ end_command
        ) ;_ end_progn
      ) ;_ end_if
      (*error* "")
    ) ;_ end_defun
    (prompt ">>>...mdim.lsp is now loaded. Type 'mdim'  to run command...<<<")
  7. #7
    AutoCAD 2009
    Nov 2007
    408
    updated code above.........:-)
    -wiz
  8. #8
    AutoCAD 2009
    Nov 2007
    408
    here's the latest version...'-)
    -wiz
  9. #9
    Full Member
    not specified
    Apr 2006
    Philippines
    61
    Hi,
    I downloaded the mdim.lsp file but I can't make it work.When you pick on the polyline, an option for editing a polyline will just pop out. I tried it on both model space and paper space but just the same. I'm using Autocad 2007 and I don't know if it has an effect on that. As I see on your attached drawing it's a powerfull tool with regards to my line of work because it reduces my time putting dimensions on all the rebar outlines that I'm making of. I hope you still find time to go through this file.Thanks you.
  10. #10
    AutoCAD 2009
    Nov 2007
    408
    i'll try take a look at it later today... try making a new an open pline with minimum of 3 segments first, then run mdim on that pline. let me know whats the result.
  1. VBA dimensioning
    By smed in forum Autodesk Inventor
    Last Post: 1st Oct 2007, 02:47 pm
  2. Replies: 10
    Last Post: 24th Aug 2007, 05:34 pm
  3. 3D Dimensioning Help!?^%$
    By apache73 in forum AutoCAD Drawing Management & Output
    Last Post: 23rd May 2007, 03:46 pm
  4. Dimensioning
    By aintgotone in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Aug 2005, 01:41 pm
  5. Lisp for dimensioning to the centre of a wall?
    By victoreric in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Feb 2005, 02:08 am
