Results 1 to 7 of 7
    Forum Newbie
    AutoCAD 2005
    Sep 2008
    7
    Default Merge closed polylines
    Hello all,
    every time i use Autocad i realize how few i know about it...
    There are so many things it can do that i do not know (yet anyway).
    The latest problem i came across was trying to merge 2 closed polylines. That is i have 2 closed polylines having at least 2 same points with each other. I want to merge those 2 to become 1 or better yet create a new polyline containing both. I can not do it through PEDIT -> Multiple.
    I guess there must be a way to do so but i do not know it...
    Thanks in advance for any reply!
    PS: I have searched for this question in the forum and found no answers to that problem! I am sorry if such a thread already exists!
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,023
    I don't believe there is a native AutoCAD function that will merge two closed polylines. However, you might want to take a look at a program called PolyTools 2.0 that advertises itself as a collection of polyline editing tools for AutoCAD. One of those tools is a routine for merging two polylines (supposedly with one click). It retails for $100 (US) but there is a free 30-day trial available at:
    http://www.swisscad.com/products.php...duct=polytools
    Forum Newbie
    AutoCAD 2005
    Sep 2008
    7
    Smile
    Thank you for the reply. Actually i had searched internet and found that collection. Haven't still tried it though! But i still believe there must be another way to do this through autocad, for example with BOUNDARY command (only that output would be 1 polyline).
    Thank you for the help... I will try that collection and see. Problem is it is not free!
    Senior Member
    Doove's Computer Details
    7
    HP Elitebook
    Intel i7 M620 2.67GHz
    8GB
    NVidia Quadro FX880M (512MB)
    Inventor 2011
    Oct 2008
    South Wales
    135
    You can change status of closed polylines to open via properties tab; alternatively you can 'break' each polyline at the required vertex using "pedit", then "edit vertex", then "break".
    You can then rejoin the polylines as you wish.
  5. #5
    Forum Newbie
    AutoCAD 2005
    Sep 2008
    7
    Quote Originally Posted by Doove View Post
    This was the way i do it... But i came across with needing to merge more polylines and also do it faster (time=money)...
    But still Thanks for the help!
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,023
    The method proposed by Doove is one I've used myself but a true "merge" option in the polyline edit toolset would be a welcomed addition. I could see a good use for it in architectural drawings working with walls.
  7. #7
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    Draw a big rectangle to enclose the two polylines. Use the BPOLY command and select a point inside the rectangle but outside the polylines. The command will create two new polylines: une superposed with the rectangle and one more that suit your needs. Just delete the initial polylines and the rectangles.
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  1. LISP for marks Centroids of closed polylines
    By Fantomas in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Mar 2011, 03:00 am
  2. moving polylines within other closed polyline
    By sryabinin in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Feb 2010, 07:42 am
  3. LISP ROUTINE EXTRUDE CLOSED POLYLINES
    By huguini in forum AutoCAD General
    Last Post: 7th Oct 2005, 02:16 pm
  4. dividing closed polylines
    By gainer in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Apr 2005, 03:40 pm
  5. How to merge?
    By aubob in forum AutoCAD Drawing Management & Output
    Last Post: 20th Jan 2005, 01:17 am
