Results 1 to 5 of 5
    Super Member
    wannabe's Computer Details
    XP
    AutoCAD 2007
    Oct 2008
    Birmingham, UK
    772
    Default VBA - Using IF and selection sets
    Public Sub ScanForCircle()
    ''This sub will scan the drawing to determine if circles are present
    'First, select all the items in the drawings by:
    '1. Creating a selection set
    Dim sset1Obj As AcadSelectionSet
    Set sset1Obj = ThisDrawing.SelectionSets.Add("SSET4")
    '2. Adding all objects to the selection set
    sset1Obj.Select acSelectionSetAll
    '3. Filter so only circles are left
    Dim dataValue(0) As Variant
    dataValue(0) = "Circle"
    sset1Obj.Select
    '4. Ask if circles are present in the selection set
    'Delete the selction set
    sset1Obj.Delete
    End Sub
    I decided that I wanted to understand how to use 'If Then Else' statements, so my first task was to scan the drawing for circles and then have a statement on the command prompt that lets me know whether there are or arent.
    Above, in the code, you can see I have made a selection set that selects all the objects in a drawing. I then want to ask if there are any circles present in that selection set and then insert two lines of code which will be the answer to my question.
    Can anyone advise, please?
    Super Member ASMI's Avatar
    AutoCAD 2008
    Nov 2005
    Oceanus Procellarum, Moon
    1,427
    If sset1Obj.Count <> 0 Then
    AutoCAD 2008
    Nov 2005
    1,427
    Something like this:
    Code:
    Sub ScanForCircles()
    Dim sCol As AcadSelectionSets
    Dim fTyp(0 To 0) As Integer
    Dim fDat(0 To 0) As Variant
    Set sCol = ThisDrawing.SelectionSets
    On Error Resume Next
    sCol.Item("SSET1").Delete
    Set sset1Obj = sCol.Add("SSET1")
    fTyp(0) = 0
    fDat(0) = "CIRCLE"
    sset1Obj.Select acSelectionSetAll, , , fTyp, fDat
    MsgBox "There is " & sset1Obj.Count & " circles."
    sset1Obj.Delete
    Set sset1Obj = Nothing
    End Sub
    Super Member
    XP
    AutoCAD 2007
    Oct 2008
    Birmingham, UK
    772
    Quote Originally Posted by ASMI View Post
    Code:
    fTyp(0) = 0
    fDat(0) = "CIRCLE"
    sset1Obj.Delete
    End Sub
    That's great again, thanks.
    Just a quick question, mate:
    I Understand what the 'MsgBox' represents but I don't fully understand what the quote marks represent. Obviously the ones at either end are essential, but the ones in-between the text I am unsure exactly how they work in VBA along with the '&' aswell.
    Can you explain, please?
  5. #5
    Senior Member borgunit's Avatar
    Mechanical 2006
    May 2007
    Ohio USA
    287
    I can try and explain. A message box feeds a string to the screen via a dialog box. What is shown is a concatenation (joining) of a string. It shows a string, denoted by "There is " and then it is joining (&) it to a string value (actually a integer that VB converts to a string) sset1Obj.Count and then joining (&) another string to that " circles." WHat you end up with is a message box that shows "There is 2 circles" when the selection set has two items in it.
    AutoCAD Mechanical 2006
    XP PRO SP3
    http://mechcad-insider.blogspot.com/
  1. VBA - Selection Sets
    By -KarL- in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Mar 2009, 10:54 am
  2. Sheet Sets
    By Norts in forum AutoCAD Drawing Management & Output
    Last Post: 8th Aug 2007, 05:32 pm
  3. Little help on selection sets please
    By Galingula in forum AutoCAD Drawing Management & Output
    Last Post: 17th Apr 2006, 03:39 pm
  4. selection sets..........
    By rajanikrishna in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Nov 2005, 11:32 am
  5. delay in selection of objects/selection windows
    By RedRobMol in forum AutoCAD Drawing Management & Output
    Last Post: 31st May 2005, 01:34 pm
