+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
  1. #1
    Senior Member JerryG's Avatar
    Discipline
    Civil
    JerryG's Discipline Details
    Occupation
    Stream Restoration
    Discipline
    Civil
    Using
    Civil 3D 2012
    Join Date
    Jan 2008
    Location
    Washington State
    Posts
    286
    Default Converting Lidar SDF file to surface
    Hi all!
    Using Data Connect I have added a SDF connection
    to Lidar data and created contours of the site.
    It looks great and all but can I turn this data into a surface?
    I know I can create a surface from the contours but
    I'm looking for something more accurate.
    Thank you!
    Never trust a computer you can't throw out a window!
    Dimensions Drafting and Design;
    Specialty - Fish Passage - Civil - House plans Please visit us @ http://dimensionsdrafting.design.off...m/default.aspx
  2. #2
    Senior Member BOB'27T's Avatar
    Computer Details
    BOB'27T's Computer Details
    Computer:
    Dell Precision 690
    Monitor:
    Dual 21" Dell
    Using
    Civil 3D 2009
    Join Date
    Sep 2007
    Location
    Tavares,Florida
    Posts
    416
    Default
    I just use the lidar contours and make them into a surface. I've had really good success thus far.
    "Those Who Pay Attention Will Be Rewarded"
  3. #3
    Discipline
    Civil
    Occupation
    Stream Restoration
    Discipline
    Civil
    Using
    Civil 3D 2012
    Join Date
    Jan 2008
    Location
    Washington State
    Posts
    286
    Default
    Thanks bob - but is it accurate enough?
    I can see surface imperfections that the contours dont seam to pick up. I set to Major Contours at 4' - am I possibly missing a setting?
    Thank you for the help!
  4. #4
    Computer Details
    Computer:
    Dell Precision 690
    Monitor:
    Dual 21" Dell
    Using
    Civil 3D 2009
    Join Date
    Sep 2007
    Location
    Tavares,Florida
    Posts
    416
    Default
    I set mine to 5', maybe that will make a difference.
  5. #5
    Super Member rustysilo's Avatar
    Computer Details
    rustysilo's Computer Details
    Operating System:
    WinXP
    Discipline
    Civil
    rustysilo's Discipline Details
    Occupation
    Senior CAD Draftsman
    Discipline
    Civil
    Using
    Civil 3D 2008
    Join Date
    Jul 2007
    Location
    Jacksonville, FL - USA
    Posts
    1,458
    Default
    You might need to mess with your weeding/supplementing factors as well as performing surface edits after adding the contour data to your surface such as swapping edges. When you add the contours I think you can set it to "minimize flat areas by..." and check the options you want to include.
    What is in the lidar data? Is it points? Could you perhaps upload the sdf file? I've never had a chance to play with one of those as our topo is always conventional survey data.
    "Constantly choosing the lesser of two evils is still choosing evil." ~ Jerry Garcia
    flickr |
    work | blog | creed
    rustysilo's tips & tutorials
  6. #6
    Discipline
    Civil
    Occupation
    Stream Restoration
    Discipline
    Civil
    Using
    Civil 3D 2012
    Join Date
    Jan 2008
    Location
    Washington State
    Posts
    286
    Default
    Not points but more of a GIS based system like metadata.
    Sorry it wont let me load an ADF file. (orginal format).
    Unfortunatly I dont have the option to minimize flat areas since it
    is not a surface I'm creating contour data from.
    Its more of a image with Z values. (I think - still trying to grasp it all)
    The forum wont let me upload the file.
    Sorry.
  7. #7
    Computer Details
    Operating System:
    WinXP
    Discipline
    Civil
    Occupation
    Discipline
    Civil
    Using
    Civil 3D 2008
    Join Date
    Jul 2007
    Location
    Posts
    1,458
    Default
    Email it to me.
    flickr |
    work | blog | creed
  8. #8
    Discipline
    Civil
    Occupation
    Stream Restoration
    Discipline
    Civil
    Using
    Civil 3D 2012
    Join Date
    Jan 2008
    Location
    Washington State
    Posts
    286
    Default
    I just started from sctratch again and noticed that the orginale file is actually a adf file (sorry for the confusion)
    It dosn't create a SDf file until you create contour data from the image.
  9. #9
    Computer Details
    Operating System:
    WinXP
    Discipline
    Civil
    Occupation
    Discipline
    Civil
    Using
    Civil 3D 2008
    Join Date
    Jul 2007
    Location
    Posts
    1,458
    Default
    Ah I see. Maybe a small tutorial on creating contours from this data. Some of us have never used such file formats and created contours this way.
    flickr |
    work | blog | creed
  10. #10
    Discipline
    Civil
    Occupation
    Stream Restoration
    Discipline
    Civil
    Using
    Civil 3D 2012
    Join Date
    Jan 2008
    Location
    Washington State
    Posts
    286
    Default
    You bet...as soon as I figure it out more completly I'll write something up. This is really new to me also. Its something our GIS expert recomended so I thought I would give it a shot. My orginal idea was have hime convert it to a point file
    (from Lidar data) then just delete areas i didn't need. But by doing it this way you can clearly see your site and its
    a much more managable Dwg. (no crashes or slowdowns)
    BTW - tried emailing you file but dont see anywhere to attach file
    under Send Email or Send PM ?? I must be missing something simple?
Similar Threads
  1. Converting a .iam file in to a .dwg
    By BDIZZEL124 in forum Autodesk Inventor
    Last Post: 27th May 2008, 09:31 pm
  2. Converting a later dwg file to 2000
    By New2CADmike in forum AutoCAD Drawing Management & Output
    Last Post: 5th Apr 2008, 02:19 pm
  3. LIDAR, contours.shp files ?
    By ckhart in forum AutoCAD Drawing Management & Output
    Last Post: 26th Dec 2007, 03:20 pm
  4. Converting CAD file into powerpoint file like video file
    By rattaka in forum AutoCAD Beginners' Area
    Last Post: 2nd Sep 2007, 05:46 pm
  5. Converting CAD file into Word file
    By Ulqin in forum AutoCAD Beginners' Area
    Last Post: 31st Aug 2007, 02:56 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
