Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
  1. #11
    Super Member rustysilo's Avatar
    rustysilo's Computer Details
    WinXP
    Civil
    rustysilo's Discipline Details
    Senior CAD Draftsman
    Civil
    Civil 3D 2008
    Jul 2007
    Jacksonville, FL - USA
    1,458
    I guess you'd have to email, then I can reply which would allow you to reply back and attach via your email client.
    "Constantly choosing the lesser of two evils is still choosing evil." ~ Jerry Garcia
    flickr |
    work | blog | creed
    rustysilo's tips & tutorials
  2. #12
    Forum Newbie
    Civil 3D 2009
    Nov 2008
    6
    I think you're working with DEM (digital elevation model) data. Is it a grayscale image? Each grayscale represents an elevation, the program just de-codes that. Are you using Civil3d. If so, once imported just create the contours, the surface is already made.
    Mike -
  3. #13
    Senior Member JerryG's Avatar
    Civil
    JerryG's Discipline Details
    Stream Restoration
    Civil
    Civil 3D 2012
    Jan 2008
    Washington State
    286
    Right mike.
    I was able to get that far fairly easily. But the contours
    are not picking up all the grade slopes as they really exist.
    Is there a way to put the contours in at say a 2' intervale
    as opposed to 5' and 10' ? There are allot of areas on the image where I can see a small hill etc. but the contours are not picking it up.
    Never trust a computer you can't throw out a window!
    Dimensions Drafting and Design;
    Specialty - Fish Passage - Civil - House plans Please visit us @ http://dimensionsdrafting.design.off...m/default.aspx
  4. #14
    Forum Newbie
    Civil 3D 2009
    Nov 2008
    6
    Yes, in the toolspace, under Surfaces, right click and select Create Surface. On the dialog you should see a Style and to the right it should say Standard, click the little box and another dialog opens. Click the little box with the pencil and the Surface Style editor opens. Find the words Contour Intervals on the Contour tab. For minor set it to 2 feet. You can save various styles. 2 and 5's, 5's and 10's etc.
    Hope this helps.
    Mike -
  5. #15
    Forum Newbie
    Civil 3D 2012
    May 2012
    6
    Hi guys, I know this is an old thread but I was hoping for a little bit of clarification. I'm loading massive point cloud files (.las) to my Civil3d drawings and it's taking forever. I really only need small parts and am planning on clipping them (I'm also not sure of how I'm going to do this), but really, should I be waiting 30min for these point clouds to load? Any other way I could do this? I am also going to be turning them into contour lines..
    Thanks in advance
  6. #16
    Senior Member Emigrato's Avatar
    not applicable
    Sep 2011
    116
    Which commands do you use to load that .LAS file?
  7. #17
    Forum Newbie
    Civil 3D 2009
    Nov 2008
    6
    Quote Originally Posted by giraffeking View Post
    Thanks in advance
    In my experience it does take a huge amount of time to load .las files. We have a guy with Merrick Mars Explorer software, which is used to edit and process our .las point cloud data prior to importing directly into Cad. Applied Imagery Terrain Modeler is another software.
    Mike -
  8. #18
    Forum Newbie
    Civil 3D 2012
    May 2012
    6
    I'm just entering it in through the Home tabCreate Ground Data panelCreate Point Cloud. And it really does take a really long time to update after I've entered it. Miken, I think I'll look into that software, but I'm curious if you know how to clip point data to certain lats/longs? I've tried the conventional methods and it doesn't work (not that I thought I would but I thought I'd give it a shot) I Just need a small section so even if after the long loading time if I could cut out 90% of the point cloud it would really help in not bogging down the program so much.
  1. Converting a .iam file in to a .dwg
    By BDIZZEL124 in forum Autodesk Inventor
    Last Post: 27th May 2008, 09:31 pm
  2. Converting a later dwg file to 2000
    By New2CADmike in forum AutoCAD Drawing Management & Output
    Last Post: 5th Apr 2008, 02:19 pm
  3. LIDAR, contours.shp files ?
    By ckhart in forum AutoCAD Drawing Management & Output
    Last Post: 26th Dec 2007, 03:20 pm
  4. Converting CAD file into powerpoint file like video file
    By rattaka in forum AutoCAD Beginners' Area
    Last Post: 2nd Sep 2007, 05:46 pm
  5. Converting CAD file into Word file
    By Ulqin in forum AutoCAD Beginners' Area
    Last Post: 31st Aug 2007, 02:56 am
