Results 1 to 6 of 6
    Forum Newbie
    not specified
    Apr 2005
    Nottingham, UK
    5
    Default Newbie wants to edit but can only select the whole drawing
    Hi,
    Please excuse this total numpty question.
    I need to edit an autocad (i use 2004) drawing that has been sent to me. I only need to do some simple things but have hit a stummbling block due to the fact that i can only select the whole drawing and not individual items.
    In the noddy programs i normally use, i would select the object and apply "ungroup" to it so that i can edit it.
    I have done a search on "ungroup" but dont think that is what i need. (it didnt work either!).
    Can anyone help ?
    Thanks in advance.
    Ringo
    Administrator CADTutor's Avatar
    CADTutor's Computer Details
    Windows 7 Home Premium 64bit
    Asus P7P55D-E PRO
    Intel Core i7-860
    4GB PC3-12800 C8 Corsair Dominator
    NVIDIA Quadro FX 1800 768 MB
    Intel X25-M SSD 160GB
    Samsung Spinpoint 320GB
    BenQ FP241W 24" Wide
    Education
    CADTutor's Discipline Details
    Senior Lecturer (Digital Design), Landscape Architect & Web Designer
    Education
    AutoCAD 2014
    Aug 2002
    Hampshire, UK
    3,606
    Welcome ringo. Most likely, you are dealing with a "block" rather than a group. In AutoCAD, blocks can be Exploded in order to return them to their constituent parts. You'll find a "stick of dynamite" button on the Modify toolbar.
    Try that first and get back to us. There are other possibilities but this is the most likely.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
    Forum Newbie
    not specified
    Apr 2005
    Nottingham, UK
    5
    Thanks for the kind welcome! No luck im afraid.
    I have selected the only thing on the drawing that i can (its a border around a site plan - when i select it and got modify->erase, the whole drawing disapears) and then hit the stick of dynamite on the modify button.
    Nothing happens.
    In the command window it says:
    _explode 0 found
    1 was not able to be exploded.
    Select objects:
    Asus P7P55D-E PRO
    Intel Core i7-860
    Education
    Education
    AutoCAD 2014
    Aug 2002
    Hampshire, UK
    3,606
    OK, with more information I can make a better guess. You must be in Paper Space and the border you see is the viewport border. You can confirm this by looking at the tabs at the bottom-left of the screen. Your currently selected tab may say "Layout1". If that is the case, click the tab that says "Model". That takes you to Model Space where you should be able to edit your drawing.
  5. #5
    Forum Newbie
    not specified
    Apr 2005
    Nottingham, UK
    5
    yes you are right. I was on the tab that said layout1
    I have switched to the model tab and done a view->zoom->all and now i can see it AND modify it!!
    Brilliant.
    Incidentally, is the layout view just for plotting ?
    Thanks very much
    Ringo
  6. #6
    Asus P7P55D-E PRO
    Intel Core i7-860
    Education
    Education
    AutoCAD 2014
    Aug 2002
    Hampshire, UK
    3,606
    Quote Originally Posted by ringo
    Yes, your drawing is dome in model space and then you setup a paper space layout in order to arrange your drawing sheet. Title blocks and annotation are often drawn in paper space prior to plotting. The viewports are just views back into model space.
