Results 1 to 4 of 4
    Senior Member eric_monceaux's Avatar
    eric_monceaux's Computer Details
    Windows 7 Home Premium (64-Bit)
    Toshiba Qosmio X505-Q880
    TOSHIBA Qosmio X505
    1.60 gigahertz Intel Core i7 Q 720 64-bit
    8GB DDR3
    NVIDIA GeForce 360M
    64 SSD
    500GB SATA
    18.4" Laptop Monitor, 19" LCD Secondary
    Architectural
    eric_monceaux's Discipline Details
    3D Designer/Draftsman
    Architectural
    AutoCAD 2014
    Apr 2006
    Texas
    114
    Default AttDef filter?!?
    I am trying to create a section symbol dynamic block in AutoCAD 2009. I have all my parameters set properly, or so I thought. All of the actions work except for the references to the Attributes.
    I have two attributes within a circle seperated by a line. What I want to do is be able to rotate the entire symbol and also be able to rotate the attribute portion separately.
    The problem, however, is that when I try and select the attribute for the action reference, it gives the following message:
    Select objects: 1 unlocked AttDef filtered from selection.
    I am at a loss as to how to fix this. I have made Dynamic blocks before with attributes and those work fine. I even checked the attribute itself and made sure that it was not locked.
    Can someone please help?
    "The way I see it, every life is a pile of good things and bad things. The good things don’t always soften the bad things, but vice versa, the bad things don’t always spoil the good things and make them unimportant.”
    — The Doctor, Season 5, Episode 10
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    Windows 7 Professional
    Dell
    Intel Xeon E5-1603@2,80GHz
    4GB
    NVIDA Quadro K600
    DELL 23" & SAMSUNG 21"
    not applicable
    Nov 2005
    Kenley, Surrey, UK
    5,644
    you need to LOCK the attribute position. I know it sounds wrong but trust me, I'm a draughtsman.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    "Everything in drafting is logical. Except what isn’t." - Gavin Guile. (from the Lightbringer series of books by Brent Weeks)
    Dave
    TOSHIBA Qosmio X505
    8GB DDR3
    NVIDIA GeForce 360M
    64 SSD
    500GB SATA
    Architectural
    Architectural
    AutoCAD 2014
    Apr 2006
    Texas
    114
    Awesome! That worked. Thanks for the help dbroada!
    Forum Newbie
    Mechanical
    AutoCAD 2017
    Mar 2017
    3
    Wow thanks
  1. Using "Filter" to filter out MText
    By kirkmactavish in forum AutoCAD Drawing Management & Output
    Last Post: 10th Dec 2007, 02:11 pm
  2. Automatic AttDef Batch Process
    By nitefisher in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Oct 2007, 02:22 am
  3. Replies: 0
    Last Post: 2nd Nov 2006, 11:51 pm
  4. Need help with XRef's/ATTDEF
    By tzframpton in forum AutoCAD Drawing Management & Output
    Last Post: 9th Jun 2006, 11:50 am
  5. ATTDEF/ATTEDIT
    By hankthelank in forum AutoCAD Drawing Management & Output
    Last Post: 11th Nov 2004, 06:32 am
