+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
  1. #1
    Junior Member
    Using
    AutoCAD 2009
    Join Date
    Oct 2008
    Posts
    16
    Default orthographic projection- hidden lines.
    anyone know how to change the appropriate lines to hidden or how to add centerlines? my understanding is that soldraw seperates layers, but how do you change the default linetype of the hidden layer?
  2. #2
    Super Member
    Using
    Architecture 2012
    Join Date
    Nov 2007
    Location
    El Paso, Tx
    Posts
    550
    Default
    use solview with soldraw, I believe.
  3. #3
    Junior Member
    Using
    AutoCAD 2009
    Join Date
    Oct 2008
    Posts
    16
    Default
    Quote Originally Posted by smorales02 View Post
    yes I used the solview command to make the viewports with my projections of my solid model. I went to properties to try and change the linetypes but nothing happened...
  4. #4
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,024
    Default
    If you want Soldraw to use the Hidden linetype instead of the Continuous linetype you must load the linetype before you run the command.
    To change linetypes after running Soldraw use Layer Manager.
  5. #5
    Junior Member
    Using
    AutoCAD 2009
    Join Date
    Oct 2008
    Posts
    16
    Default
    Quote Originally Posted by ReMark View Post
    I had loaded the linetypes already. I'm going to attach my assignment, if anyone can tell me what I'm doing wrong or how to make the appropriate lines hidden, or even how to add centrelines, it would be really appreciated. I need help.
  6. #6
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,024
    Default
    You did use Solview and Soldraw didn't you? I mean, I see you have three layers ending in -HID but when I view the model space drawing I don't see the flattened geometry generated by Soldraw.
    To change the three layers that end in -HID from linetype Continuous to linetype Hidden, click on one of the three layers, then press the < Ctrl > key and while holding it down individually select the other two layers. You should have all three layers highlighted. Now, double click on the word Continuous under the heading Linetype for layer front-HID. When the Select Linetype pop-up window appears choose Hidden as the linetype. Then click OK. All three layers should now have Hidden as their linetype.
    You still need to tell me what you did to generate the three views of the object. Did you erase something?
    Oh, do me a favor, could you use a little color in the drawing. Why use a $3500 software package and have everything drawn in black? Make all the hidden lines color blue. Thanks.
  7. #7
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,024
    Default
    OK...dummy me. I see what you did. Or, in this case, what you failed to do. I ran SolDraw on each view and it did exactly what I expected (generated the 2D geometry). I think you forgot this step.
  8. #8
    Junior Member
    Using
    AutoCAD 2009
    Join Date
    Oct 2008
    Posts
    16
    Default
    I saved it before I ran soldraw, but I was still trying to change the lines after I had run soldraw.
  9. #9
    Junior Member
    Using
    AutoCAD 2009
    Join Date
    Oct 2008
    Posts
    16
    Default
    how can I select a layer and highlight the rest? (sorry I'm such a newb )
    I just don't really see the difference between the layers. even in model space.
  10. #10
    Junior Member
    Using
    AutoCAD 2009
    Join Date
    Oct 2008
    Posts
    16
    Default
    ok I managed to go to format -- layers.. and changed the hid layers to hidden lines... can someone help me out with adding centrelines?
    the attachment includes my progress.
Similar Threads
  1. Orthographic Projection
    By JD Mather in forum AutoCAD Drawing Management & Output
    Last Post: 14th Dec 2007, 09:23 pm
  2. hidden lines
    By ref in forum AutoCAD Beginners' Area
    Last Post: 26th Oct 2007, 07:19 am
  3. 3D hidden lines
    By gofindsam in forum AutoCAD Drawing Management & Output
    Last Post: 5th May 2007, 12:23 pm
  4. hidden line projection from a camera view
    By jaydg in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Jun 2005, 09:10 am
  5. Hidden lines, not being hidden in 3D view
    By deadseasquirrels in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Sep 2003, 11:08 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
