Results 1 to 10 of 10
    Junior Member
    AutoCAD 2009
    Oct 2008
    16
    Embarrassed trying to add a centerline
    I'm trying to add a centerline by making a centermark on my circle, I went to modify the dimention style, and under center marks I selected line. but I just comes out as a mark... anyone know how to do this?
    Super Member nocturne00's Avatar
    nocturne00's Computer Details
    Windows Vista SP2
    Dell Studio XPS
    Intel(R) Core(TM)2 Duo CPU P8600
    4GB DDR3 RAM
    ATI Radeon, 512MB
    22" Samsung
    AutoCAD 2009
    Jun 2008
    Tartarus
    769
    a bit vague, you want to place a centerline?
    you could just draw a centerline snapping it to the center of the circle.
    a mark is a group of lines that will be generated w/ respect to the center of the circle when you use centermark
    ....always perform Beyond what is expected.
    Super Member papagyi's Avatar
    papagyi's Computer Details
    window 8
    AutoCAD 2017
    Apr 2008
    Myanmar
    518
    Drawing
    Another way for center mark is you can choose point style according to(format menu..point style) or "ddptype" command.Then you can make your center mark with "point" command.
    Let share our knowledge!One good image is better than a thousand of words.
    http://papagyi20477.blogspot.com/
    Junior Member
    AutoCAD 2009
    Oct 2008
    16
    Quote Originally Posted by nocturne00 View Post
    I'm trying to put a centreline on the circle, it's for an assignment and needs to be the long dash short dash type and I'm having a hard time figuring this out. :S
  5. #5
    Senior Member mugshot's Avatar
    AutoCAD 2008
    Jun 2008
    papua new guinea
    240
    .... try to scale up the center u made from the dimension. zoom the center line the scale> pick for the center line>input the scale factor....
  6. #6
    Windows Vista SP2
    Dell Studio XPS
    4GB DDR3 RAM
    ATI Radeon, 512MB
    22" Samsung
    AutoCAD 2009
    Jun 2008
    Tartarus
    769
    a centerline thru the circle line right? not the center mark.
    something like this?
    but which centerline? the yellow or the green one?
  7. #7
    Junior Member
    AutoCAD 2009
    Oct 2008
    16
    YELLOW YELLOW YELLOW lol
  8. #8
    Junior Member
    AutoCAD 2009
    Oct 2008
    16
    I think that one of my problems was the scale, but also, how do I make sure that yellow center line is right in the center??
  9. #9
    Junior Member
    AutoCAD 2009
    Oct 2008
    16
    I think I got it, thankyou guys for your help
  10. #10
    Windows Vista SP2
    Dell Studio XPS
    4GB DDR3 RAM
    ATI Radeon, 512MB
    22" Samsung
    AutoCAD 2009
    Jun 2008
    Tartarus
    769
    yes, check your line scale under properties, or just type LTSCALE to either increase or reduce it so the linetype will show.
    Ive not had many experience with using Solview, draw, etc but when making isometric projections, i cut and paste these projected views and paste them on UCS World so i could align them with respect to each other, using construction lines to make sure they're aligned with each other, at the same time i could align the center of a circle on front view, with same center on top view with a construction line(xline)
  1. Finding centerline of a cylinder
    By Footpeg in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Aug 2008, 12:30 am
  2. Rotate Object From Centerline
    By wahlwesle in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Apr 2008, 07:20 pm
  3. Replies: 6
    Last Post: 30th Jan 2008, 09:26 am
