Read-only DWG files
Leslie Bierman
Maybe send it as a sheet set, that way the original drawing can't be modified. They can scribble changes without affecting anything. Just another option I suppose.
When sending drawing electronicly is there a way to make it read-only so that it can not be modified?:D
Thanks Leslie
I have seen this question hundreds of times, and the only reliable solution that I have ever seen is to use the products at http://www.cadlock.com
Anything else you might try is only some level of a deterrent.
The bigger question is "why do want to protect the drawing?" If you are afraid that the recipient may copy (i.e.: steal) your work, then why send the drawing in the first place? Why do business with someone you don't trust? I'm not trying to question your work habits, but I would just like some real world answers to why people need to "lock down" drawings...
