Results 1 to 2 of 2
Thread: Mtext editing
    Forum Newbie
    Map 3D 2008
    Oct 2008
    5
    Default Mtext editing
    Hi
    When I insert an mtext, the text editor blows up so it fills the whole screen (and more). Is there a way to change the default size of the mtext editor (as a percentage of screen size or something)?
    I am aware of the mtextfixed-command. But having the mtextfixed set to 0 when editing existing mtexts, stops it from automaticaly rotateting and resizing the mtext editor (so you have to zoom in or out to see what your editing), and i would like to keep this nice feature.
    Regards
    tAC
    Forum Newbie
    AutoCAD 2009
    Nov 2008
    Boulder, CO USA
    6
    Here you go
    at the Aotocad command prompt:
    servar
    MTEXTFIXED = 1
    should do it...
  1. 3D editing
    By alijahed in forum AutoCAD General
    Last Post: 29th Oct 2007, 07:14 am
  2. Can Lisp use mtext to make multi string mtext editor?
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Dec 2006, 03:22 am
  3. CTB Editing
    By Galingula in forum AutoCAD Drawing Management & Output
    Last Post: 3rd May 2006, 03:54 pm
  4. SIZE OF IN PLACE EDITOR WHEN EDITING MTEXT
    By graham in forum AutoCAD Beginners' Area
    Last Post: 13th Jan 2006, 04:33 pm
  5. MTEXT created in same MTEXT editor on different layers?
    By hyposmurf in forum AutoCAD General
    Last Post: 5th Sep 2003, 12:54 pm
