You can download free from this link..http://www.cadforum.cz/catalog_en/?q=2d+bicycle+block but you will need to free register.Then you will see many more than your wish.
Hi every body, any body can help to give me some Bicycle Block?
I need block for my project. My boss wants to see Bicycle in the plan and elevations.. Thanks in advance
Let share our knowledge!One good image is better than a thousand of words.
http://papagyi20477.blogspot.com/
Thank you very much buddy.
I appreciate it
Thanks again papagyi, i need another favor please, is it possible to convert the 3d bicycle into 2d? I need only top view and elevation on my drawing. Thanks again.![]()
Fri..This is many way to convert 3d to 2d....flatten , flatshot and Dxb plot.
First you should copy of 3d file.Then you will need to change elevation.Let say make with flatten.You can select 3d bicycle with elevation view by flatten command with remove hidden line "yes" option.Then wait a bit time.After you will need to use "overkill" command this will do remove overlap line.Wait a bit time to complete command.Finally you can edit 2d model as you want.For top view,you can do like this way.Another method,you can study from help.
Here is sample elevation of bicycle for you.
dear all, i would like to opening the bicycle file with CAD 2006 version?
manythanks
Check again!..
top elevation/front elevation?
ripper thanks!
I have a beautiful 3D bike file but, too large to post in the forums.
Great *.dwg wish I could take credit for making the bike drawing, but I can't. The only problem, I'm not a 3D guru, is, "I would like to fill (color yellow) the rear wheel support; from the frame (below the seat mount) to the rear tire axle. Any ideas?
If you or anyone else wants the file, very detailed mountain bike, PM me with your email address.![]()
Tankman
"When the well is dry, we know the worth of water." Ben Franklin ~ 1746
