nicnicman Posted November 3, 2008 Share Posted November 3, 2008 Hello Everyone, The outlet of this drawing was the last part of this drawing. It was created in different parts. As each piece of the outlet was created I connected them using the Union command. Once the drawing was complete I saved it but upon reopening I noticed many of the details are missing. For example the 4 identical rectangular blocks near the cord were only created to Subtract sections from the outlet. They were deleted but now they' re back again and part of the solid. Also much of the outlet was filleted but now the edges are square. Two holes where created in the prongs but now the holes are gone. The 4 blocks are easy enough to remove but I have found refilleting the edges impossible. The command prompt reads "failure while filleting". I suspect that the Union command had something to do with this but I can't be sure. Has anyone ever seen this? Is there a way to remedy it? Thanks for any help. Nick Lamp.zip Quote Link to comment Share on other sites More sharing options...
shift1313 Posted November 3, 2008 Share Posted November 3, 2008 if you can save a copy as an acad04 drawing i can open it up at home, unfortunately i cant see what you have there. Quote Link to comment Share on other sites More sharing options...
nicnicman Posted November 3, 2008 Author Share Posted November 3, 2008 Here it is. Thanks for looking. Lamp04.zip Quote Link to comment Share on other sites More sharing options...
nicnicman Posted November 4, 2008 Author Share Posted November 4, 2008 Any suggestions or comments are welcome! Quote Link to comment Share on other sites More sharing options...
mugshot Posted November 4, 2008 Share Posted November 4, 2008 ... 'bout ur fillet command, there is nothing wrong, but you must fillet the edges based on orderly manner, second, ur radius must be larger than the corners to be fillet. Quote Link to comment Share on other sites More sharing options...
