+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Forum Newbie
    Computer Details
    ms_scene's Computer Details
    Computer:
    Any PC thats available at the moment.
    Using
    AutoCAD 2009
    Join Date
    Nov 2008
    Location
    NYC
    Posts
    1
    Exclamation How To Make A Title Block
    I have to add a title block to several drawings of plans and elevations.
    How do I go about making a title block? And once Ive created one, does it then become a template I can modify over and over? Thanks in advance!
  2. #2
    Forum Deity rkent's Avatar
    Computer Details
    rkent's Computer Details
    Operating System:
    WIN7 PRO 64bit
    Computer:
    Dell Precision T7500
    CPU:
    Xeon Dual Core E5503 2.0Ghz
    RAM:
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    Graphics:
    nVidia Quadro 3800
    Primary Storage:
    300Gb, 10K rpm
    Monitor:
    Dell 24" FS (2x)
    Discipline
    Mechanical
    rkent's Discipline Details
    Occupation
    Facilities Design - Semi-conductor manufacturing
    Discipline
    Mechanical
    Details
    Designer: Process Piping, P&ID's, Machine Part Design, Planning / General Arrangement. Facilities Management. Drafting: Electrical, Controls, Architectural.
    Using
    Mechanical 2014
    Join Date
    Nov 2007
    Location
    Lat:35, Long:-106, Elev: 5164'
    Posts
    3,373
    Default
    Quote Originally Posted by ms_scene View Post
    You can find a few sample title blocks in the template folder, it will be buried deep in the file structure, something like,
    C:\Documents and Settings\yourname\Local Settings\Application Data\Autodesk\AutoCAD 2009\R17.2\enu\Template
    There will be files ending in DWT and DWG. The DWT files are template files which are nothing more than DWG files renamed or saved as DWT. In the template the border will need to be in PS. If you want a border to simply insert later the information will need to be in MS.
    So open the sample DWT, SAVEAS to a name you want with extension of DWT. when you navigate to that folder only DWG files will be showing, go down to the bottom of the dialog and select .DWT or type *.dwt in the file name location. Edit it all you want, add dim styles, layers, etc. Set this file as your default so when you pick the new button autocad automatically uses that template file for you. Options> Files> Default Template File Name for QNEW.
    Last edited by rkent; 4th Nov 2008 at 04:50 pm. Reason: clarified where information should be for MS or PS
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  3. #3
    Super Member Tankman's Avatar
    Computer Details
    Tankman's Computer Details
    Operating System:
    XP Pro SP3
    Computer:
    IBM T60 Thinkpad™
    Monitor:
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    Using
    AutoCAD 2007
    Join Date
    Mar 2008
    Location
    Eastern PA, USA
    Posts
    1,794
    Default
    As rkent stated, many templates available in you AutoCAD program.
    You can edit to suit your needs. Save the edited title block with a different name, in the directory you like.
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  4. #4
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,090
    Default
    Be creative...make your own! Then find a template with a border you like, blow away its title block and insert your own. Do a "save as" and give it a new name like "The Best Titleblock on Earth" and use it over and over again.
  5. #5
    Super Member skipsophrenic's Avatar
    Computer Details
    skipsophrenic's Computer Details
    Operating System:
    Vista 32 bit
    Computer:
    Compaq
    Motherboard:
    erm . . yeah?
    CPU:
    Intel Pentium Dual CPU E2140 @ 1.60 Ghz
    RAM:
    2039MB
    Graphics:
    don't ask you'll kill me
    Primary Storage:
    360gb
    Monitor:
    21" widescren - 16:10 ratio
    Using
    AutoCAD 2008
    Join Date
    Jul 2008
    Location
    Birmingham, United Kingdom
    Posts
    1,020
    Default
    Just remember if you make your own to save it as a DWT and not DWG
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. - Albert Einstein
    SET FILEDIA = 1
Similar Threads
  1. Title Block
    By jc1981 in forum AutoCAD Beginners' Area
    Last Post: 22nd Sep 2009, 11:21 pm
  2. OLE title block ?
    By sparkyuk in forum AutoCAD Beginners' Area
    Last Post: 15th Aug 2008, 04:31 pm
  3. New title block
    By hhhhh in forum Autodesk Inventor
    Last Post: 25th Apr 2007, 03:01 pm
  4. How do i make a title block w/updated sheet numbers
    By Frank the Frowner in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Feb 2007, 08:11 pm
  5. title block help please
    By kunal in forum AutoCAD General
    Last Post: 3rd Jan 2007, 11:36 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
