Results 1 to 7 of 7
Thread: thebes stool
    Full Member
    AutoCAD 2008
    Sep 2008
    25
    Default thebes stool
    How do i make a thebes stool in autocad 2008?
    Super Member nocturne00's Avatar
    nocturne00's Computer Details
    Windows Vista SP2
    Dell Studio XPS
    Intel(R) Core(TM)2 Duo CPU P8600
    4GB DDR3 RAM
    ATI Radeon, 512MB
    22" Samsung
    AutoCAD 2009
    Jun 2008
    Tartarus
    759
    Create 2 SPHERES, the larger is with the outer radius of the stool, one smaller than the other in order to make a shell off the larger sphere to create the thickness of the stool.
    next make a square with the dimensions of the stool(the violet cube in the drawing), position it at the center of the sphere shell
    then use INTERSECT on the 2 solids.
    VOILA.
    Thats just one method, ,maybe someone will post his own routine.
    ....always perform Beyond what is expected.
    Windows Vista SP2
    Dell Studio XPS
    4GB DDR3 RAM
    ATI Radeon, 512MB
    22" Samsung
    AutoCAD 2009
    Jun 2008
    Tartarus
    759
    Im sure youll be able to manage the legs and web supports of the stool.
    Forum Deity shift1313's Avatar
    not applicable
    Sep 2008
    VA
    2,859
    you can also make the stool by using 4 arcs or 4 splines and doing an edge surface(edgesurf) between them. Nocturnes method is perfect if you need a solid and its a perfect sphere.
    Are you just drawing a representatio nof this? or are you trying to acurately model it?
  5. #5
    Full Member
    AutoCAD 2008
    Sep 2008
    25
    Quote Originally Posted by shift1313 View Post
    Yup im doing a presentation for my job interview.
  6. #6
    Windows Vista SP2
    Dell Studio XPS
    4GB DDR3 RAM
    ATI Radeon, 512MB
    22" Samsung
    AutoCAD 2009
    Jun 2008
    Tartarus
    759
    thats nice, Practice also Shift's suggestion if you want to impress your employer. solving the same problem w/ 2 solution is a mark of proficient drafter
  7. #7
    not applicable
    Sep 2008
    VA
    2,859
    i just want to note that if you are going to be doing solid editing i would draw it the way nocturne showed you above. but i agree, draw it both as a solid model and surface model to show the empolyer you can find multiple solutions
