Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 31
  1. #11
    Super Member rustysilo's Avatar
    rustysilo's Computer Details
    WinXP
    Civil
    rustysilo's Discipline Details
    Senior CAD Draftsman
    Civil
    Civil 3D 2008
    Jul 2007
    Jacksonville, FL - USA
    1,458
    I always set up any computer I work on for best performance in the System Properties (right-click My Computer > Properties > Advanced tab > Performance > Visual Effects tab > Adjust for best performance). I doubt this would help very much with your situation since you are working with multiple attachments, but it may.
    "Constantly choosing the lesser of two evils is still choosing evil." ~ Jerry Garcia
    flickr |
    work | blog | creed
    rustysilo's tips & tutorials
  2. #12
    Forum Newbie
    AutoCAD 2007
    Nov 2008
    Oregon & Washington
    5
    It is just a friendly suggestion. We welcome you to CT and encourage your continued involvement.
    Good point, I will start a new thread with the same question and responses to ReMark's questions in that.
  3. #13
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,402
    Speed AutoCAD up, a few things to try, I am sure there are others.
    Options> Open and Save > Turn off display digital signature information
    Check in layer manager to make sure you don't have 100's of layer filters, if so delete them.
    Check the scale list to make sure you don't have 100's of scale lists.
    Don't use true type fonts (TTF) and see if that helps, lots of those will slow things down.
    Go through the file paths in Options>Files and make sure every single path listed
    actually exists, be meticulous.
    Dock the command line in the lower or upper portion of the autocad screen.
    Close the new layer manager in 2009. Use LAYERDLGMODE set to 0.
    Use -purge, Regapps, purge all.
    Clean empty groups and unnamed groups out of drawing.
    http://forums.augi.com/showthread.php?t=50895
    Various tips from an AutoCAD expert.
    http://blog.jtbworld.com/2008/09/aut...ance-tips.html
    Disable the communication center.
    http://otb.manusoft.com/2007/09/auto...tartup-fix.htm
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  4. #14
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,492
    rkent:
    That is an excellent list of suggestions you've put together. Thank you.
  5. #15
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,402
    rkent:
    Thanks, I have updated it based on other things I have remembered and or have read since this thread started.
    so delete them.
    Does your computer have Blue tooth? A user reported a blue tooth phone placed
    near the computer slowed the computer to a crawl, they moved the phone away and
    it sped back up.
    Manual Tune video driver - Options, System, Performance Settings, Manual Tune,
    Driver Name pulldown. Which one is showing? For vista Direct3D might be better.
    For XP pick the driver for your card, mine is from nVidia so I have nvd3d9.hdi
    picked. Pick the Enable hardware acceleration to see if that helps. Further
    down move the sliders over to the left.
    Viewres still affects the speed of the computer, contrary to what you may have
    been told. Autodesk has confirmed this to me personally, especially so with
    MEP. Set it to 500 instead of the maximum setting.
    Set ltscale to the proper value, a large drawing with linetypes will slow down
    when in MS with ltscale set to 1 or a small value.
    Set the virtual memory paging file to a larger size with a min and max rather
    than letting windose handle it for you. XP - Control Panel, System
    Properties, Advanced, Performance Settings, Advanced, Virtual Memory Change,
    Custom Size, Initial size = 3X ram (3GB ram = 9GB paging file size), maximum
    size = 4X ram. Go larger if you have the hard drive space.
    In the same area as immediately listed above, instead of Advanced tab pick V
    isual Effects tab, pick adjust for best performance, then if you must go to
    custom and pick the few settings you can't do without.
    Lower hardware acceleration setting, in Control panel, Display, settings, advanced,
    troubleshoot, move the hardware acceleration slider to the left one click
    and try it out, keep moving it right and watching for a change in performance
    and also fewer crashes. Find a setting you can live with.
    Antivirus software - disable and see if there is a difference in performance.
    Go to autodesk.com web site, pick Services and Support, use the Knowledge Base
    and search on "slow", "delay", etc.
  6. #16
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,402
    One more I remembered.
    TREEDEPTH at -2520 and SORTENTS at 20, or turn SORTENTS to 0 if a large file
    and using draworder.
  7. #17
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,492
    That is impressive. I am going to print it out and tape it to the wall next to my workstation. Great work!
  8. #18
    Senior Member
    AutoCAD 2009
    Oct 2008
    129
    What is the max physical RAM limitation on your computer? 4GB?
    32bit OS, so 3gb is kinda the max.
  9. #19
    Senior Member Bogbadbob658's Avatar
    Bogbadbob658's Computer Details
    Windows 7
    Asus P8P67 LE
    Intel 2nd Generation Coreā„¢ i5-2500
    8GB 1333MHz Dual Channel DDR3 SDRAM
    512MB Nvidia GeForce Quadro FX 580
    1TB Samsung F3 SATA 7200rpm 32MB Cache
    24" Iiyama LCD Monitor - Full HD 1920x1080
    Architecture 2012
    Aug 2007
    Gloucester UK
    252
    I found that changing the 'Layout Region Option' to 'Regen when switching layouts' (found in options, system) helped. Before changing this my machine would hang for ages. Hope it helps.
  10. #20
    Senior Member
    AutoCAD 2009
    Oct 2008
    129
    A setting that was allready enabled, so no effect.
  1. AutoCAD 2009, too slow, How can I speed it up?
    By muck in forum AutoCAD General
    Last Post: 25th Nov 2008, 11:51 am
  2. Anyone know how to speed up tables?
    By raj1954 in forum AutoCAD General
    Last Post: 1st Jul 2008, 12:51 pm
  3. Animation speed
    By Haz in forum Rigging & Animation
    Last Post: 30th Jun 2008, 11:47 am
  4. What speed processor to run autocad
    By kevin23 in forum AutoCAD Beginners' Area
    Last Post: 29th Jul 2007, 05:53 pm
  5. GETTING UP TO SPEED WITH VIZ
    By BRYANSCUBA in forum Cameras, Lighting & Rendering
    Last Post: 17th Aug 2004, 01:13 pm
