sebko Posted November 9, 2008 Share Posted November 9, 2008 Hi after a lot of internet surfing i found out how to make threads, and succesfully made a screw and nut.. .however in the assembly the mates dont seem to work.. any suggestions, ideas, help would be much appreciated here is my assembly with the mates... http://www.speedyshare.com/927254518.html cheers! Quote Link to comment Share on other sites More sharing options...
shift1313 Posted November 9, 2008 Share Posted November 9, 2008 are you trying to mate the threads to each other or are you just doing a concentric mate between the hole and bolt, and a mate between the surface of your part and the underside of the bolt head? Im not sure that i have ever tried to mate a thread to a thread. Quote Link to comment Share on other sites More sharing options...
sebko Posted November 9, 2008 Author Share Posted November 9, 2008 all i have is a nut and bolt. and want them to mate together... ive made the threads for both.. sorry for being unclear :S Quote Link to comment Share on other sites More sharing options...
shift1313 Posted November 9, 2008 Share Posted November 9, 2008 no i understand what you are saying i just wasnt sure if you were trying to mate the surface of the threads on your bolt with the surface of the threads on your nut, or you just wanted to put the two together regardless of thread orientation. i cant remember off hand how the wording is in solidworks but i believe there is a tool bar that is dimensions/relations. You want to add relation and a host of options will pop up and prompts telling you what to do. If you want to mate them in a general sense you will add a concentric mate to align the nut and bolt concentrically, then you will add a tangnent mate(i believe this is the correct term). there are pictures to go along with each selection. what version of solidworks are you using? if you need i can make a screen shot for you tomorrow at work. Quote Link to comment Share on other sites More sharing options...
