+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Exploding
  1. #1
    Forum Newbie
    Using
    AutoCAD 2009
    Join Date
    Nov 2008
    Posts
    5
    Default Exploding
    Hello all, I have a quick question on autocad 09 once I explode something how to I un explode it? Also is there any other way to calculate the area and volume other then clicking each point? Thank you in advance..
  2. #2
    Forum Deity rkent's Avatar
    Computer Details
    rkent's Computer Details
    Operating System:
    WIN7 PRO 64bit
    Computer:
    Dell Precision T7500
    CPU:
    Xeon Dual Core E5503 2.0Ghz
    RAM:
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    Graphics:
    nVidia Quadro 3800
    Primary Storage:
    300Gb, 10K rpm
    Monitor:
    Dell 24" FS (2x)
    Discipline
    Mechanical
    rkent's Discipline Details
    Occupation
    Facilities Design - Semi-conductor manufacturing
    Discipline
    Mechanical
    Details
    Designer: Process Piping, P&ID's, Machine Part Design, Planning / General Arrangement. Facilities Management. Drafting: Electrical, Controls, Architectural.
    Using
    Mechanical 2014
    Join Date
    Nov 2007
    Location
    Lat:35, Long:-106, Elev: 5164'
    Posts
    3,375
    Default
    Quote Originally Posted by nguyen08 View Post
    UNDO after exploding is the only way to "unexplode". If you are talking about a block then you can use the block command to remake it, if a pline then you can use pedit to join.
    With area you can select a closed pline. You can create a closed pline using the bpoly command and picking once in an area bounded by lines, plines, arcs, etc.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  3. #3
    Forum Newbie
    Using
    AutoCAD 2009
    Join Date
    Nov 2008
    Posts
    5
    Default
    Ty so much.. I have a .dwg that is about 592kb so I'm not able to attach the file. Is there any way I can send the file to you? I'm confused on how to calculate the volume of the area...
  4. #4
    Senior Member hotrodz0321's Avatar
    Using
    Civil 3D 2008
    Join Date
    Mar 2007
    Location
    Crystal River, Florida
    Posts
    237
    Default
    can you WBLOCK the object and post it?
    if you dont know how....just type W > select the objects, and save it by clicking browse (...) button
    Failure is a dress rehearsal for success.
    AutoCAD Land Development Desktop (2000, 2005 & 2006 )
    Civil 3D 2008
  5. #5
    Computer Details
    Operating System:
    WIN7 PRO 64bit
    Computer:
    CPU:
    RAM:
    Graphics:
    nVidia Quadro 3800
    Primary Storage:
    300Gb, 10K rpm
    Monitor:
    Dell 24" FS (2x)
    Discipline
    Mechanical
    Occupation
    Discipline
    Mechanical
    Details
    Using
    Mechanical 2014
    Join Date
    Nov 2007
    Location
    Posts
    3,375
    Default
    You don't find the volume of the area, area is 2d, volume is 3d. If you have a 3d object then use MASSPROP command, otherwise the area command does it. Area, Object, pick object. Or simply pick the object and look at Properties palette.
  6. #6
    Forum Newbie
    Using
    AutoCAD 2009
    Join Date
    Nov 2008
    Posts
    5
    Default
    Thanks!!! I blocked it then zipped it
  7. #7
    Using
    Civil 3D 2008
    Join Date
    Mar 2007
    Location
    Posts
    237
    Default
    ok...now what are you trying to find the area of? and are you needing volume? if so, of what?
    Civil 3D 2008
  8. #8
    Forum Newbie
    Using
    AutoCAD 2009
    Join Date
    Nov 2008
    Posts
    5
    Default
    I believe I can find the area by simply clicking the points but how would I calculate the volume of that area?
  9. #9
    Super Member nocturne00's Avatar
    Computer Details
    nocturne00's Computer Details
    Operating System:
    Windows Vista SP2
    Computer:
    Dell Studio XPS
    CPU:
    Intel(R) Core(TM)2 Duo CPU P8600
    RAM:
    4GB DDR3 RAM
    Graphics:
    ATI Radeon, 512MB
    Monitor:
    22" Samsung
    Using
    AutoCAD 2009
    Join Date
    Jun 2008
    Location
    Tartarus
    Posts
    759
    Default
    Very confusing?
    Is the object a 3D object, coz there is no such thing as "volume of an Area". a Volume pertains to Mass (amount of matter). Area pertains to a surface bounded by a perimeter.
    w/c are you after?
    ....always perform Beyond what is expected.
  10. #10
    Computer Details
    Operating System:
    Windows Vista SP2
    Computer:
    Dell Studio XPS
    CPU:
    RAM:
    4GB DDR3 RAM
    Graphics:
    ATI Radeon, 512MB
    Monitor:
    22" Samsung
    Using
    AutoCAD 2009
    Join Date
    Jun 2008
    Location
    Tartarus
    Posts
    759
    Default
    Compute AREA= Select an enclosed object, enclosed polylines or regions then use AREA command to extract the Surface area and total bounding Perimeter.
    Compute VOLUME= use MASSPROP command then select a 3D solid.
Similar Threads
  1. DIMENSIONS are exploding when placed
    By wasabi in forum Autodesk Software General
    Last Post: 22nd Oct 2008, 08:45 pm
  2. Reverse DIM exploding
    By Cad Sponge in forum AutoCAD Drawing Management & Output
    Last Post: 11th Oct 2007, 11:21 pm
  3. problem exploding
    By fresh in forum AutoCAD Drawing Management & Output
    Last Post: 10th Aug 2007, 02:59 pm
  4. Exploding a polyline in VBA
    By Nimbokwezer in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Dec 2006, 11:30 am
  5. Exploding blocks
    By Rainy-Day in forum AutoCAD Drawing Management & Output
    Last Post: 4th Aug 2006, 10:40 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
