Results 1 to 6 of 6
    Full Member
    AutoCAD 2009
    Nov 2008
    30
    Default align objects to curve
    I have 6 windows drawn in a straight line and want to bend them, so they will fit the bay curve.Is there a way to align them along the curve.The windows are six separate objects.I think polar, array should work, and i will be able to multiply one window along the curve, hopefully precisely. Hoverer, is there a way to bend the whole thing or get it to run along the curve.
    Super Member
    wannabe's Computer Details
    XP
    AutoCAD 2007
    Oct 2008
    Birmingham, UK
    772
    Quote Originally Posted by boyo View Post
    Have you tried using the MEASURE command?
    You will need to type that command, then choose block and click yes to align it.
    Of course, you will need to make the entity a block first. Then explode afterwords, if necessary.
    Super Member dumfatnhappy's Avatar
    dumfatnhappy's Computer Details
    Windows 7 64 bit
    3.6 dual quad core
    24 gig
    Quadro FX 1700
    269?
    twin 24" flat panels
    Mechanical
    dumfatnhappy's Discipline Details
    mechanical design (Petro-Chem)
    Mechanical
    Process piping (3D)
    MEP 2013
    Oct 2007
    Apollo Beach, Fla
    659
    divide works as well if you want them evenly space along a certain length of wall
    dum
    'Suppose you were an idiot. And suppose you were a member of Congress.. But I repeat myself.'
    --Mark Twain
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,074
    there isn't a way to bend a straight line (as your windows will be made up of), well not that I know of anyway
    Array should do the trick for you wrt arranging standard units along a curve to construct a bay, but you'll need to get in and edit the joins between each frame
    I'd array 3 of them, edit the joins, then array the edited unit (as the start and end frames will have a different junction with the wall they butt up to)
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
  5. #5
    Full Member
    AutoCAD 2009
    Nov 2008
    30
    Thank you for all answers. Measure wont work with blocks.The best way after all seems to be the polar array. I simply used the curve as a part of circle and center of the circle as pivot.Curve is 60deg of a full 360. Computer wont however fit all the windows inside. It took the begining of the first frame as a reference and the begining of the last frame as the end. So i was left with one frame sticking outside, along the curve and the need to increase curve lengh to the default+frame and the butt joint in order to accommodate the last frame.
  6. #6
    Super Member
    XP
    AutoCAD 2007
    Oct 2008
    Birmingham, UK
    772
    glad you solved your problem, but a bit concerned you couldnt suss out the MEASURE command. It gives you the option to choose block on the command prompt.
  1. Need help again. Align
    By david in forum AutoCAD Beginners' Area
    Last Post: 22nd May 2008, 11:14 am
  2. Align all objects to grid
    By slide in forum AutoCAD Beginners' Area
    Last Post: 18th Mar 2008, 07:29 pm
  3. Align a block to other objects (2006 and later)
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 14th Jan 2008, 05:32 am
  4. Align MS with PS
    By Tiger in forum AutoCAD General
    Last Post: 12th Nov 2007, 05:27 pm
  5. Align objects by touching
    By edgley in forum AutoCAD Beginners' Area
    Last Post: 25th Oct 2007, 12:31 pm
