Results 1 to 10 of 10
Thread: Macro not found
    Senior Member Rooster's Avatar
    AutoCAD 2017
    Jun 2005
    281
    Default Macro not found
    I use several macros through buttons on my toolbar. However, for some reason AutoCAD can no longer find these macros (error msg: Macro not found). I know that the macros are still there though, because if I go to Tools/Macros I can load them and run them from there. Obviously it would be much easier if I could access them directly from my toolbars again.
    Can anyone please suggest how to get my toolbars to reference the macros again?
    Super Member
    wannabe's Computer Details
    XP
    AutoCAD 2007
    Oct 2008
    Birmingham, UK
    772
    I think you need to go into tools and then select the load application. Then reference the files to be loaded on startup.
    Not 100%
    AutoCAD 2017
    Jun 2005
    281
    Quote Originally Posted by wannabe View Post
    Not 100%
    Thanks, but that doesn't make any difference....
    Senior Member GhostRider's Avatar
    GhostRider's Computer Details
    Windows10
    Dell XPS
    Dell
    Intell Core 2 DUO 2.8ghz
    32 GIG
    Nvidia
    160 Gigger
    Dual Dell
    Architectural
    GhostRider's Discipline Details
    Residential Engineering/Contracting
    Architectural
    AutoCAD 2018
    Aug 2007
    N. Carolina
    405
    check to be sure the folders that the macros's and lisps are in the support path still on options
    So many commands, so little time....
  5. #5
    AutoCAD 2017
    Jun 2005
    281
    Quote Originally Posted by GhostRider View Post
    What section should they come under? There are several support paths options. I don't want to change the wrong one as I've done this before and had my fingers burnt as a result!
  6. #6
    Windows10
    Dell XPS
    Dell
    32 GIG
    Nvidia
    160 Gigger
    Dual Dell
    Architectural
    Architectural
    AutoCAD 2018
    Aug 2007
    N. Carolina
    405
    yea you don't want to change the wrong ones ( learned the hard way myself) but add the file path to the support file search path, under the files tab in options..
    where are your macros or lisps stored? are the in one file?
  7. #7
    AutoCAD 2017
    Jun 2005
    281
    I have 6 different entries under the Support File Search path
    - Users\....\R17\enu\support
    - Program Files\....\support
    - Program Files\....\fonts
    - Program Files\....\help
    - Program Files\....\express
    - Program Files\....\color
    I presume that it's not fonts/help/express/color, so which support should I change?
    The missing macros are not stored in the same folder as all my other LISPs etc. The add-on that I installed them from put them into a folder in Program Files.
  8. #8
    Windows10
    Dell XPS
    Dell
    32 GIG
    Nvidia
    160 Gigger
    Dual Dell
    Architectural
    Architectural
    AutoCAD 2018
    Aug 2007
    N. Carolina
    405
    dont' change any of the existing ones. you can add as many new search paths as needed.. Select "ADD" then "BROWSE" and add the folder where they are stored.
    It's a good idea to keep all your add on support files together so if you need to reinstall or something it's easily organized
  9. #9
    AutoCAD 2017
    Jun 2005
    281
    Perfect! Problem solved - thanks ghostrider
  10. #10
    Windows10
    Dell XPS
    Dell
    32 GIG
    Nvidia
    160 Gigger
    Dual Dell
    Architectural
    Architectural
    AutoCAD 2018
    Aug 2007
    N. Carolina
    405
    Glad it worked out, I know I don't explain clearly sometimes... I like to organize all the macro's and lisps under 1 main directory or folder than have sub folders for different things, menu's or CUI, blocks, Lisps, and macro's, and even toolpaletts. each subfolder has to be defined in the support search path though.
    then if you ever change machines or reload it's organized to find easily and reload.
  1. Xref not found
    By yrnomad in forum AutoCAD Drawing Management & Output
    Last Post: 16th May 2008, 03:14 pm
  2. FOUND IT! - Linetype/Lineweight/Color Macro
    By amattintime in forum AutoCAD General
    Last Post: 30th Jun 2006, 08:07 pm
  3. just found the forum!
    By maze in forum Feedback
    Last Post: 23rd Mar 2006, 08:54 pm
  4. Dictionary not found?
    By hyposmurf in forum AutoCAD Drawing Management & Output
    Last Post: 18th May 2004, 12:48 pm
  5. Website Ive found
    By hyposmurf in forum Useful Links
    Last Post: 18th Jun 2003, 11:44 am
