Results 1 to 3 of 3
Thread: Remove Dcl
    Senior Member JONTHEPOPE's Avatar
    AutoCAD 2009
    May 2008
    Canada
    237
    Default Remove Dcl
    Code:
    ;Tip1662c:   POFFSET.LSP    Piping Utilities    (c)2000, Mitch Thaxter
    (defun C:POFFSET ()
      (setq OLD_BLIPMODE (getvar "blipmode"))
      (setvar "blipmode" 0)
      (setq FILE_FOUND_DCL (findfile "poffset.dcl"))
      (if (= FILE_FOUND_DCL NIL)
        (ANGLE_FILE_NOT_FOUND)
      ) ;_ end of if
      (setq DCL_ID (load_dialog FILE_FOUND_DCL))
      (if (not (new_dialog "poffset" DCL_ID))
        (exit)
      ) ;_ end of if
      (action_tile "cancel" "(exit)")
      (action_tile "pipe_size" "(setq pipe_size $value)")
      (if (= 1 (start_dialog))
        (start_dialog)
        (exit)
      ) ;_ end of if
    ;;;Nominal
      (if (= PIPE_SIZE "0")
        (setq PIPE_SIZE 0.405)
      ) ;_ end of if
    ;;;  1/8"
      (if (= PIPE_SIZE "1")
        (setq PIPE_SIZE 0.540)
      ) ;_ end of if
    ;;;  1/4"
      (if (= PIPE_SIZE "2")
        (setq PIPE_SIZE 0.675)
      ) ;_ end of if
    ;;;  3/8"
      (if (= PIPE_SIZE "3")
        (setq PIPE_SIZE 0.840)
      ) ;_ end of if
    ;;;  1/2"
      (if (= PIPE_SIZE "4")
        (setq PIPE_SIZE 1.050)
      ) ;_ end of if
    ;;;  3/4"
      (if (= PIPE_SIZE "5")
        (setq PIPE_SIZE 1.315)
      ) ;_ end of if
    ;;;   1"
      (if (= PIPE_SIZE "6")
        (setq PIPE_SIZE 1.660)
      ) ;_ end of if
    ;;; 1 1/4"
      (if (= PIPE_SIZE "7")
        (setq PIPE_SIZE 1.900)
      ) ;_ end of if
    ;;; 1 1/2"
      (if (= PIPE_SIZE "8")
        (setq PIPE_SIZE 2.375)
      ) ;_ end of if
    ;;;   2"
      (if (= PIPE_SIZE "9")
        (setq PIPE_SIZE 2.875)
      ) ;_ end of if
    ;;; 2 1/2"
      (if (= PIPE_SIZE "10")
        (setq PIPE_SIZE 3.500)
      ) ;_ end of if
    ;;;   3"
      (if (= PIPE_SIZE "11")
        (setq PIPE_SIZE 4.000)
      ) ;_ end of if
    ;;; 3 1/2"
      (if (= PIPE_SIZE "12")
        (setq PIPE_SIZE 4.500)
      ) ;_ end of if
    ;;;   4"
      (if (= PIPE_SIZE "13")
        (setq PIPE_SIZE 5.563)
      ) ;_ end of if
    ;;;   5"
      (if (= PIPE_SIZE "14")
        (setq PIPE_SIZE 6.625)
      ) ;_ end of if
    ;;;   6"
      (if (= PIPE_SIZE "15")
        (setq PIPE_SIZE 8.625)
      ) ;_ end of if
    ;;;   8"
      (if (= PIPE_SIZE "16")
        (setq PIPE_SIZE 10.75)
      ) ;_ end of if
    ;;;  10"
      (if (= PIPE_SIZE "17")
        (setq PIPE_SIZE 12.75)
      ) ;_ end of if
    ;;;  12"
      (setq DIST   (/ PIPE_SIZE 2)
            PICBOX ""
      ) ;_ end of setq
      (princ "\nCurrent offset < ")
      (princ DIST)
      (setq ENT (entsel "\nSelect line: "))
      (setq POINT (cadr ENT))
      (setq SIDE (getpoint "\nSelect side: "))
      (setq DIS1 (distance SIDE POINT))
      (setq ANG (angle SIDE POINT))
      (if (or (or (< ANG 0.78) (> ANG 5.5))
              (and (> ANG 2.35) (< ANG 3.92))
          ) ;_ end of or
        (setq ANG (- 0 ANG))
        (setq ANG (- pi ANG))
      ) ;end if
      (setq OTHER (polar POINT ANG DIST))
      (command "offset" DIST ENT SIDE ENT OTHER "")
      (prin1)
    ) ;_ end of defun
    CAN SOME ONE SHOW ME HOW TO REMOVE CALL FOR DCL
    THE HOLY ONE
    Super Member CAB's Avatar
    AutoCAD 2000
    May 2004
    Tampa, Florida
    801
    Just what is this crude routine supposed to be doing?
    Code:
    ; Modified 11/17/08
    (defun C:POFFSET (/ ANG DAT DIS1 DIST ENT OTHER PIPE_SIZE POINT SIDE)
      (and
        (setq PIPE_SIZE (getint "\nEnter Pipe Size: "))
        (setq dat (assoc Pipe_size
                         '((0  0.405)
                           (1  0.540) ;  1/4"
                           (2  0.675) ;  3/8"
                           (3  0.840) ;  1/2"
                           (4  1.050) ;  3/4"
                           (5  1.315) ;   1"
                           (6  1.660) ; 1 1/4"
                           (7  1.900) ; 1 1/2"
                           (8  2.375) ;   2"
                           (9  2.875) ; 2 1/2"
                           (10 3.500) ;   3"
                           (11 4.000) ; 3 1/2"
                           (12 4.500) ;   4"
                           (13 5.563) ;   5"
                           (14 6.625) ;   6"
                           (15 8.625) ;   8"
                           (16 10.75) ;  10"
                           (17 12.75) ;  12"
        (setq DIST   (/ (cadr dat) 2.))
        (princ DIST)
            ) ;_ end of or
        )     ;end if
        (command "offset" DIST ENT "non" SIDE ENT "non" OTHER "")
      (prin1)
    ) ;_ end of defun
    AutoCAD 2009
    May 2008
    Canada
    237
    Default Cab
    THANKS FOR THE REPLY I SEEM TO HAVE STUMBLED ON QUITE A FEW CLOUDY ROUTINES IVE USED THIS PROGRAM POFFSET AND THE SIZES WERENT AS SPEICIFIED I GUESS IM JUST SPOILED BY AWSOME PROGRAMMERS HERE AND ALL THEIR HELP.
    Code:
    ;Tip1714:  ATTUPDATE.LSP    Attribute update      (c)2001, Brian Iwaskewycz
    (defun C:ATTUPDATE  (/ NEXTENTTYPE ENTTYPE BLOCKNAME SSET ENTNAME
                         SELECTION FILENAME INDEX1 NEWBLOCKNAME MAINENTNAME
                         SUBENTNAME ATTLIST INSPOINT XSCALE YSCALE ZSCALE
                         ROTATION ENTDATA INDEX2 VALUE LOSSFLAG LAYERNAME)
      (while (or (/= "ATTRIB" NEXTENTTYPE) (/= "INSERT" ENTTYPE))
        (setq BLOCKNAME "")
        (setq BLOCKNAME
               (getstring
                 "\nEnter name of block to update or <ENTER> to select: "))
        (if (/= "" BLOCKNAME)
            (setq SSET
                   (ssget "x"
                          (list (cons 0 "INSERT") (cons 2 BLOCKNAME))))
            (if SSET
                (setq ENTNAME (ssname SSET 0))
                (setq ENTTYPE (cdr (assoc 0 (entget ENTNAME))))
                (if (entnext ENTNAME)
                  (setq NEXTENTTYPE
                         (cdr
                           (assoc 0
                                  (entget (entnext ENTNAME)))))
                  (princ "\nThe selected block has no attributes.")
                (princ (strcat "\nBlock name "
                               (strcase BLOCKNAME)
                               " not found."))
                (setq NEXTENTYPE NIL
                      ENTTYPE NIL)
            (setq SELECTION NIL)
            (while (not SELECTION)
              (setq SELECTION (entsel "\nSelect block to update:"))
            (setq ENTNAME (car SELECTION))
              (setq NEXTENTTYPE
                     (cdr (assoc 0 (entget (entnext ENTNAME))))))
            (if (/= "INSERT" ENTTYPE)
              (princ "\nThe selected entity is not a block.")
              (if (/= "ATTRIB" NEXTENTTYPE)
                (princ "\nThe selected block has no attributes."))
      (if (= "" BLOCKNAME)
        (setq BLOCKNAME (cdr (assoc 2 (entget ENTNAME)))))
      (setq SSET (ssget "x" (list (cons 0 "INSERT") (cons 2 BLOCKNAME))))
      (princ (strcat "\n"
                     (itoa (sslength SSET))
                     " occurrence(s) of block "
                     (strcase BLOCKNAME)
                     " found.\n"))
      (setq FILENAME (getfiled "Select New Block Name" "" "dwg" 0))
      (setq INDEX1 (strlen FILENAME))
      (while (/= "\\" (substr FILENAME INDEX1 1))
        (setq INDEX1 (1- INDEX1))
      (setq BLOCKNAME (strcase BLOCKNAME))
      (setq NEWBLOCKNAME
             (strcase (substr FILENAME
                              (1+ INDEX1)
                              (- (- (strlen FILENAME) INDEX1) 4))))
      (setvar "attdia" 0)
      (setvar "attreq" 0)
      (setvar "cmdecho" 0)
      (if (and (tblsearch "block" NEWBLOCKNAME)
               (/= NEWBLOCKNAME BLOCKNAME))
          (princ
            (strcat "A block named "
                    NEWBLOCKNAME
                    " already exists.  Using local copy instead."))
          (command "insert" NEWBLOCKNAME "0,0,0" "" "" "")
          (if (/= BLOCKNAME NEWBLOCKNAME)
            (command "rename" "b" BLOCKNAME NEWBLOCKNAME))
          (command "insert"
                   (strcat NEWBLOCKNAME "=" FILENAME)
                   "0,0,0"
      (setq MAINENTNAME (entlast))
      (setq SUBENTNAME (entnext MAINENTNAME))
      (while (= "ATTRIB" (cdr (assoc 0 (entget SUBENTNAME))))
        (setq
          ATTLIST (append ATTLIST
                          (list (cdr (assoc 2 (entget SUBENTNAME))))))
        (setq SUBENTNAME (entnext SUBENTNAME))
      (entdel MAINENTNAME)
      (setvar "attreq" 1)
      (setq INDEX1 0)
      (command "ucs" "w")
      (princ "\n")
      (while (setq MAINENTNAME (ssname SSET INDEX1))
        (setq INSPOINT (cdr (assoc 10 (entget MAINENTNAME))))
        (setq XSCALE (cdr (assoc 41 (entget MAINENTNAME))))
        (setq YSCALE (cdr (assoc 42 (entget MAINENTNAME))))
        (setq ZSCALE (cdr (assoc 43 (entget MAINENTNAME))))
        (setq ROTATION
               (* (/ 180.0 pi) (cdr (assoc 50 (entget MAINENTNAME)))))
        (setq LAYERNAME (cdr (assoc 8 (entget MAINENTNAME))))
        (while (= "ATTRIB"
                  (cdr (assoc 0 (setq ENTDATA (entget SUBENTNAME)))))
          (set (read (cdr (assoc 2 ENTDATA))) (cdr (assoc 1 ENTDATA)))
        (setq INDEX2 0)
        (command "insert" NEWBLOCKNAME INSPOINT "xyz" XSCALE YSCALE ZSCALE
                 ROTATION)
        (while (< INDEX2 (length ATTLIST))
          (setq VALUE (eval (read (nth INDEX2 ATTLIST))))
          (if VALUE
            (command VALUE)
              (command "")
              (setq LOSSFLAG t)
          (set (read (nth INDEX2 ATTLIST)) NIL)
          (setq INDEX2 (1+ INDEX2))
        (entmod (subst (cons 8 LAYERNAME)
                       (assoc 8 (entget (entlast)))
                       (entget (entlast))))
        (setq INDEX1 (1+ INDEX1))
        (princ (strcat "\r"
                       (itoa INDEX1)
                       " blocks updated."))
      (command "ucs" "p")
      (setvar "cmdecho" 1)
      (setvar "attdia" 1)
      (if LOSSFLAG
        (princ
          "\nWARNING! Due to non-identical tag names, some data may have been lost."))
      (princ (strcat "\n"
                     " occurrences of block "
                     BLOCKNAME
                     " updated successfully."))
        (princ (strcat "\nBlock was renamed to " NEWBLOCKNAME ".")))
    (princ "ATTUPDATE ver 1.0 loaded.")
    THIS CODE IS FOR AREA AND WANTED TO KNOW IF IT TO IS OUT OF DATE? COULD YOU ALSO HELP WITH THIS ONE?
    THE HOLY ONE
  1. remove [X] from DCL??
    By russell84 in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Aug 2008, 12:11 pm
  2. remove faces
    By sceejays in forum AutoCAD 3D Modelling & Rendering
    Last Post: 25th Apr 2008, 09:18 am
  3. How to remove corner radiuses in views; to remove confusing double lines in layout
    By nbaryosef in forum AutoCAD Drawing Management & Output
    Last Post: 17th Feb 2008, 12:06 am
  4. Can't remove objects
    By nscherneck in forum AutoCAD Drawing Management & Output
    Last Post: 11th Jan 2008, 12:17 pm
  5. how to remove plotstamp?
    By nivradolobo in forum AutoCAD Drawing Management & Output
    Last Post: 26th Dec 2007, 03:14 pm
