+ Reply to Thread
Results 1 to 9 of 9
  1. #1
    Full Member Electroman7979's Avatar
    Computer Details
    Electroman7979's Computer Details
    Operating System:
    XP
    Computer:
    HP
    CPU:
    Intel(R) Core (TM)2 Duo CPU P8600
    RAM:
    2.4 GHz
    Graphics:
    NVIDIA Quadro FX770M
    Primary Storage:
    149 GB
    Monitor:
    Samsun SyncMaster 226BW
    Using
    Electrical 2009
    Join Date
    Nov 2008
    Location
    Colorado, USA
    Posts
    51
    Question Default Text Size
    Does anyone know how to change the default text size? I'm not sure if its an AutoCAD electrical feature or regular CAD issue.
    When i drop down the ribbon for all the text properties it only gives me the option for a size 4. I'd like other options in that pull down ribbon. Any help??????
  2. #2
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,075
    Default
    If you type the word STYLE on the command line and press Enter what happens? Does it bring up a Text Style dialog box?
  3. #3
    Computer Details
    Operating System:
    XP
    Computer:
    HP
    CPU:
    RAM:
    2.4 GHz
    Graphics:
    Primary Storage:
    149 GB
    Monitor:
    Using
    Electrical 2009
    Join Date
    Nov 2008
    Location
    Colorado, USA
    Posts
    51
    Default
    Yes when i type style it brings up a text window, but that doesn't change anything in my ribbon. Here is a screen shot of where i want to be able to add different text sizes,...... but as you can see, i only get one option......
  4. #4
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,075
    Default
    Try typing the variable TEXTSIZE at the command line and just for kicks say 4. Now check what it says under Text Height in the drop-down you have shown above. Does the new size show up?
  5. #5
    Computer Details
    Operating System:
    XP
    Computer:
    HP
    CPU:
    RAM:
    2.4 GHz
    Graphics:
    Primary Storage:
    149 GB
    Monitor:
    Using
    Electrical 2009
    Join Date
    Nov 2008
    Location
    Colorado, USA
    Posts
    51
    Default
    I just tried that, that works. To try another test, i added a few different sizes, i.e. 4, 8, 10, 2 and then saved the drawing. Everytime i dropped that ribbon down all sizes appereard in the menu. Then i closed AutoCAD and reopened, and they were all gone except the last one i added. do you know of a way to keep them permenant? like a setting in the project or a drawing setting? If nothing else i can work around it. thanks for the info
    -James
  6. #6
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,075
    Default
    I think you would have actually had to type in a letter or a word using the new size.
  7. #7
    Computer Details
    Operating System:
    XP
    Computer:
    HP
    CPU:
    RAM:
    2.4 GHz
    Graphics:
    Primary Storage:
    149 GB
    Monitor:
    Using
    Electrical 2009
    Join Date
    Nov 2008
    Location
    Colorado, USA
    Posts
    51
    Default
    K. just tried that. I selected the text size from the ribbon, added text. Repeated that a few times with the different sizes from the ribbon, and the text did not change sizes. I then saved the drawing and reopened AutoCAD and the ribbon went back to the default size of 4 and no other sizes. Must be my computer.... I'll just live with inputing text and changing the size after. Thanks for the help.
    -James
  8. #8
    Computer Details
    Operating System:
    XP
    Computer:
    HP
    CPU:
    RAM:
    2.4 GHz
    Graphics:
    Primary Storage:
    149 GB
    Monitor:
    Using
    Electrical 2009
    Join Date
    Nov 2008
    Location
    Colorado, USA
    Posts
    51
    Default
    I found a solution:
    See picture below. In the Annotation Ribbon, the A with a brush by it opens the window. Then you have to set the height to 0.0 and click set current and it applies it to that page only's settings. So the next time you type DTEXT or click input single line text, it prompts for starting, then it askes for height. You can either hit enter and use the last used or type a height value at that time.
    -James
  9. #9
    Full Member DonovanPorter's Avatar
    Computer Details
    DonovanPorter's Computer Details
    Operating System:
    Windows & 64 bit
    Computer:
    Celsius M470-2
    Motherboard:
    Xeon E5630
    CPU:
    2.53GHz 12mb
    RAM:
    16 gig
    Graphics:
    NVIDIA Quadro FX1800
    Primary Storage:
    1 TB
    Secondary Storage:
    1 TB
    Monitor:
    2 x 20" Acer
    Discipline
    Civil
    DonovanPorter's Discipline Details
    Occupation
    Water Infrastructure
    Discipline
    Civil
    Using
    Civil 3D 2011
    Join Date
    Aug 2009
    Location
    South Africa
    Posts
    51
    Default
    textsixe in command promt worked for me , thank you
Similar Threads
  1. Changing default text size in table cells
    By Siberian in forum AutoCAD Beginners' Area
    Last Post: 5th Jun 2008, 10:24 am
  2. Change default text style
    By Robert J in forum AutoCAD Beginners' Area
    Last Post: 3rd Oct 2007, 07:54 pm
  3. Replies: 1
    Last Post: 14th Dec 2006, 04:00 pm
  4. Default Text Style in 2000LT
    By cadaholic in forum AutoCAD Beginners' Area
    Last Post: 22nd Aug 2005, 03:42 pm
  5. Layout tab, want to change the default paper size
    By Jerry98vert in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jan 2004, 07:48 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
