Results 1 to 7 of 7
    Full Member ankers's Avatar
    AutoCAD 2008
    Jan 2008
    34
    Default Linear Dimension
    any ideas on how i can rotate the text in the attached drawing so that it is horizontal.
    cheers
    Senior Member Commandobill's Avatar
    AutoCAD 2008
    Oct 2008
    Massachusetts
    268
    dimstyle
    go in and currently under text you have it set to be aligned with the dimension you can change it to be horizontal
    ***Commandobill***
    Abusing AutoCad Since 1999
    "Caddatude... Do you has it?"
    Sorry for my poor English, I'm American...
    AutoCAD 2008
    Jan 2008
    34
    cheers for that!!
    paul
    Super Member Tankman's Avatar
    Tankman's Computer Details
    XP Pro SP3
    IBM T60 Thinkpad™
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,794
    Quote Originally Posted by Commandobill View Post
    dimstyle
    Go in and currently under text you have it set to be aligned with the dimension you can change it to be horizontal.
    Painless! "Ask and you shall receive."
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  5. #5
    Super Member happyunited's Avatar
    AutoCAD 2010
    Jun 2006
    Manchester, England
    588
    Following on from this dims question I thought I would post here instead of opening a new thread.
    Anyone got any idea how I force the arrow heads inside the dimension here and not have them outside the way it defaults?
    Attached dwg.
    Cheers
  6. #6
    Senior Member BOB'27T's Avatar
    BOB'27T's Computer Details
    Dell Precision 690
    Dual 21" Dell
    Civil 3D 2009
    Sep 2007
    Tavares,Florida
    416
    I set the text offset to .025 and it moved them inside.
    "Those Who Pay Attention Will Be Rewarded"
  7. #7
    AutoCAD 2008
    Oct 2008
    Massachusetts
    268
    Even if you set it to .5 it will put the arrows inside
    ***Commandobill***
  1. linear dimension
    By cad_student in forum AutoCAD Beginners' Area
    Last Post: 8th Jul 2008, 12:52 pm
  2. Co-Linear lines removal
    By DreamtechMech in forum Tutorials & Tips'n'Tricks
    Last Post: 28th Jan 2008, 10:23 pm
  3. Follow linear dimension with continued dimension
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 4th Aug 2007, 09:31 pm
  4. Reading Textual Properties of a Linear Dimension via VBA
    By tommyo in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Dec 2006, 08:47 am
  5. Linear lighting in Bryce 5
    By erona in forum Design Software
    Last Post: 2nd Jun 2005, 09:22 pm
