VBA open file Has stopped working
ollie
Hey folks
I wrote a file comparison script for excel (i know this isn't an excel forum) that opens two files as read only. it worked thing when i was demonstrating tot he staff who will be using it but conveniently stopped working while i was showing the manager. can anyone suggest why this may have happened.
Combobox1 and 2 were filled using
Dim fso As New FileSystemObject
Dim fld As Folder
Dim fil As File
Set fld = fso.GetFolder("C:\vba excel compare"
For Each fil In fld.Files
   ComboBox1.AddItem fil.Name
   ComboBox2.AddItem fil.Name
next fil
Let Wbook = ComboBox1.Value     'value  "reg 1.xls"
Let Wbook2 = ComboBox2.Value   'value  "reg 2.xls"
Workbooks.Open Filename:=Wbook2, ReadOnly:=True
Workbooks.Open Filename:=Wbook, ReadOnly:=True
i am now getting runtime error 1004
Reg 2.xls could not be found. please check the spelling of the file name and make sure the location is correct
Any help would be appreciated
cheers,
Ollie.
I'd start by adding a trailing parentheses to the above line.
then id check to see that the file names are in your comboboxes
