It would be nice to have a bit more information. What is it supposed to do? What is the problem you are experiencing?
Can anyone please tell me wht's wrong with this code?
Thanks
Code:(defun getEnt (lst / ent) (setvar "ERRNO" 0) (while (and (not ent) (/= (getvar "ERRNO") 52)) (cond ((setq ent (car (entsel))) (if (not (member (cdr (assoc 0 (entget ent))) lst)) (setq ent nil) ) ) ) ) ent ) (defun getSegments (/ s1 s2) (setq s1 (max (getvar "SURFTAB1") 6) s2 (max (getvar "SURFTAB2") 12) ) (list (cond ((getint (strcat "\nSpecify horizontal segmentation <" (itoa s1) ">: "))) (s1) ) (cond ((getint (strcat "\nSpecify vertical segments <" (itoa s2) ">: "))) (s2) ) ) ) (defun getVertices (curve segh / vlst n v p offset osm) (setq n (vlax-curve-getStartParam curve) v (vlax-curve-getEndParam curve) offset (/ 1.0 segh) osm (getvar "OSMODE") ) (setvar "OSMODE" 0) (while (< n v) (setq p n) ;; use EQUAL to adjust for small decimal deviations ;; otherwise it could just be (< p (1+ n)) (while (not (equal p (1+ n) 1.0E-6)) (setq vlst (cons (vlax-curve-getPointAtParam curve p) vlst) p (+ p offset) ) ) (setq n (1+ n)) ) (setvar "OSMODE" osm) (reverse vlst) ) (defun dtr (ang)(/ (* ang pi) 180.0)) (defun C:FLUTEX (/ osm mlist angcnt angincr cpt end_ang ent hgt mlen nlen obj ptlist rot result seg1 seg2 st_ang z ) (cond ((setq ent (getEnt '("LWPOLYLINE"))) (mapcar 'set '(seg1 seg2) (getSegments)) (setq rot (getreal "\nSpeficy rotation in degr.: ") hgt (getdist "\nSpecify height: ") ) (setq obj (vlax-ename->vla-object ent)) ) ) ;; check if all stuff is ok (cond ((and obj (apply 'and (mapcar 'numberp (list seg1 seg2 rot hgt)))) ;; ready to extract points from obj (cond ((and (setq ptlist (getVertices obj seg1)) (setq cpt (getpoint "\nCenter of rotation: ")) (setq taper (cond ((getdist "\nTaper distance <0.0>: ")) (T 0.0) ) ) ) (setq mlist (cons ptlist mlist) mlen (length ptlist) ) ;; first point set is already added to mlist, ;; so set hgtcnt to one step up the z-ladder (setq rot (dtr rot) hgtcnt (/ hgt seg2) hgtincr hgtcnt cpt (list (car cpt)(cadr cpt) hgtcnt) angincr (/ rot seg2) tcnt 0.0 tincr (/ taper seg2) stpt (list (caar ptlist)(cadar ptlist) hgtcnt) angcnt (angle cpt stpt) osm (getvar "OSMODE") ) (setvar "OSMODE" 0) (command "UNDO" "Begin") (while (and (apply 'and ptlist) (<= hgtcnt hgt)) ;;(< angcnt end_ang)) (setq ptlist (mapcar (function (lambda (pt / npt) (setq npt (list (car pt) (cadr pt) hgtcnt)) (setq npt (polar cpt (+ (angle cpt npt) angincr) (- (distance cpt npt) tcnt))) ) ) ptlist ) ) (setq hgtcnt (+ hgtcnt hgtincr) cpt (list (car cpt) (cadr cpt) hgtcnt) angcnt (+ angcnt angincr) tcnt (+ tcnt tincr) ) (setq mlist (cons ptlist mlist)) ) (princ (setq nlen (length mlist))) (cond ((entmake (list '(0 . "POLYLINE") '(100 . "AcDbEntity") '(8 . "0") '(100 . "AcDbPolygonMesh") '(66 . 1) '(10 0.0 0.0 0.0) (cons 70 (+ 16 32)) '(40 . 0.0) '(41 . 0.0) '(210 0.0 0.0 1.0) (cons 71 nlen) (cons 72 mlen) '(73 . 0) '(74 . 0) '(75 . 0) ) ) (foreach mrow mlist (foreach nrow mrow (entmake (list '(0 . "VERTEX") '(100 . "AcDbEntity") '(100 . "AcDbPolygonMesh") '(100 . "AcDbPolygonMesh") (cons 10 nrow) '(70 . 64) ) ) ) ) (setq result (entmake (list '(0 . "SEQEND")))) ) ) (setvar "OSMODE" osm) (command "UNDO" "End") ) ) ) ) )
Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
The only problem is when i load the program and run it in AutoCAD it gives an error after asking the questions.I think you've got to have a polygon drawn and then you load the program,it extrudes a polygon and then twistes it...
Could you try it on and see if you can make it work?
Thanks for your help
Check out this topic for more options to twist and extrude solids.
Note to self: must put Twister in the AutoLISP Archive.
