Results 1 to 6 of 6
    Pitkru
    Default many probs please help!
    hello, i've got some annoying problems (with Autcad r14 that is!):
    1. when i copy and paste, the pasted object always seems to be inserted some distance below my original object. i'm using the .xy command so i can specify the exact points, but this doesnt seem to help. i end up having to use the move command to get it to the same x level! what am i doing wrong?
    i do find though that making and inserting as a block avoids this distance problem, but copy& paste is much quicker!
    2. furthermore, when i try to explode the newly pasted object, it goes thru with the explode but the object disappears entirely! not very useful! this also happens when i try to explode inserted blocks as well
    3. when i'm insering blocks, i go to the list window and notice loads of strangely titled blocks (eg: A$C04C04C00), what are these? and is there i way i can delete them to clean up the list window?
    sorry for the many questions, and many thanks for any help! cheers!
    ps. cadtutor-thanks for the great .xy tip in your tutorials- except for the above instance, i've found this command to be invaluable in my drawings!
    Administrator CADTutor's Avatar
    CADTutor's Computer Details
    Windows 7 Home Premium 64bit
    Asus P7P55D-E PRO
    Intel Core i7-860
    4GB PC3-12800 C8 Corsair Dominator
    NVIDIA Quadro FX 1800 768 MB
    Intel X25-M SSD 160GB
    Samsung Spinpoint 320GB
    BenQ FP241W 24" Wide
    Education
    CADTutor's Discipline Details
    Senior Lecturer (Digital Design), Landscape Architect & Web Designer
    Education
    AutoCAD 2015
    Aug 2002
    Hampshire, UK
    3,731
    Default Re: many probs please help!
    Pitkru
    The copy and paste thing never really worked well with R14. It wasn't until the acad 2000 multiple document interface that it really started to work properly. My advice with R14 is stick to using block insertions. I know it's tedious but it works (you could always move to acad 2000 or above!).
    Your disappearing block problem is a little more difficult to resolve - not sure what could be happening here.
    Problem 3 is relatively easy. It sounds like you are working on a drawing supplied by others. Most likely the drawing started as a template and had a number of standard blocks already defined in the database. You can get rid of any unused block references using the PURGE command.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
    Pitkru
    many thanks cadtutor for shedding some light! i guess i'll be making blocks for some time now.
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 10 (H)
    Dell Optiplex 9020 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Core i7-4770 quad (W)/AMD Athlon 2 X4 (H)
    16 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Geforce GTX 645 (W)/nVidia GF GT430 (H)
    256 gb SSD 0/ 1TB 1 (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Acer 28" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management, Space planning, Design
    AutoCAD 2017
    Sep 2002
    Winston-Salem, NC - USA
    5,618
    [quote author=Pitkru link=board=acadgen;num=1034455918;start=0#0 date=10/12/02 at 21:51:57]hello, i've got some annoying problems (with Autcad r14 that is!):
    <snip>
    <snip>
    ps. cadtutor-thanks for the great .xy tip in your tutorials- except for the above instance, i've found this command to be invaluable in my drawings![/quote]
    On number 2 it sounds like the original layer that the blocks were created on is frozen (not the layer that they were inserted on) is frozen or turned off. After you explode a block and it disapears go to your layer manager all unfreeze and turn-on all layers and see if it reappears. If so click on the items that were gone and see which layer it was on. Good luck.
    F7
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
  5. #5
    billsta
    correct me if im wrong on these..
    1, i thought when you copy form an existing dwg, it will uses the 0,0,0 of the parent dwg as the insertions point, so when you paste it on a to your target dwg, your insertion point will be located at your entry coodinates.
    2, my guess will be as the same as F7.
    3, i thought the 'BLOCK' name eg. 'A$C04C04C00' are the temp name for copy/paste blocks, i always think they are randon name given to the C/P block for autoCAD to differentiate ..
    cheers
  6. #6
    Tower 1
    in my experience any file with $ sign is temp file and should be deleted after , although i do remember the corupt file used to be renamed by autocad to alphabetical letter and then $ sign added to them and then a series of number
