wannabe Posted December 5, 2008 Share Posted December 5, 2008 Anyone got a routine that can help me to produce a cross-section from a plan. Normally I make a polyline putting a little cross on each contour. I then use this to show my cross section contained within a grid showing height and and distance. I am aware this is possible in Map 3D, and dont expect a function for vanilla that can do this exactly the same. Nevertheless, if any improvements can be made to the current process it would be a big help . Thanks. Quote Link to comment Share on other sites More sharing options...
Ritch7 Posted December 5, 2008 Share Posted December 5, 2008 i havent got a lisp for you im umfraid check the threads at the bottom, because im not a lisp man but im sure of what your'e asking isnt a hard task to say the least Quote Link to comment Share on other sites More sharing options...
BOB'27T Posted December 5, 2008 Share Posted December 5, 2008 Check out this lisp that I use: QuickProfile[1].LSP Quote Link to comment Share on other sites More sharing options...
wannabe Posted December 8, 2008 Author Share Posted December 8, 2008 Check out this lisp that I use: Hi Bob, Thats an excellent routine; thanks for the refferal. One small issue, and it really is minor, is that my contours are mainly on one layer, but there are a couple on another layer I need to add. I could easily do it manually, not a problem. But if there is a way of using this routine to enter multiple layers, then please let me know. Some drawings may allow me to convert all contours onto one layer. But that may mean copying xref's and things. So it would be good if I could ask this routine to recognise contours on multiple layers. Cheers. Quote Link to comment Share on other sites More sharing options...
rupasinghe Posted October 3, 2009 Share Posted October 3, 2009 Hi Bob, Could you please explain how this QuickProfile LISP works? cheers Sanji Quote Link to comment Share on other sites More sharing options...
afrazawan Posted February 26, 2012 Share Posted February 26, 2012 could u help me please how this LISP works? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 26, 2012 Share Posted February 26, 2012 Would this help at all? http://www.cadtutor.net/forum/showthread.php?62153-data-from-contour&p=423779&viewfull=1#post423779 Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 26, 2012 Share Posted February 26, 2012 One would assume the lisp routine must somehow determine what contours are being crossed and their elevation then cut the appropriate section just like it would be done manually on the drafting board. Oops...looks like Lee Mac beat me to the punch here. Follow his advice. Quote Link to comment Share on other sites More sharing options...
schoeller Posted September 19, 2013 Share Posted September 19, 2013 Sorry to bother, I wish to use quickprofile.lsp from Bricscad as a CAD-newby. This is what I did Drawing 3d polylines and/or splines on layer CONTOURS Drawing polyline on layer ALIGNMENT Loading script During execution defining contour layer as CONTOURS Select line from ALIGNMENT as horizontal Leaving exaggeration as default Hence I receive the error message ; ----- LISP : Call Stack ----- ; [0]...C:QP ; [1].....LISTPTINTERSECT ; ; ----- Error around expression ----- (VLAX-CURVE-GETDISTATPOINT HA-ENAME INTERSECTPT) Any hints for getting this to work are appreciated. Unfortunately I cannot read LISP code. I have attached the file I am working with. Best wishes from Bamako Sebastian quickprofile_test.dwg Quote Link to comment Share on other sites More sharing options...
schoeller Posted September 22, 2013 Share Posted September 22, 2013 (edited) When doing in above sequence for step number Drawing 3d polyline I have to FLATTEN the polyline and then CONVERTPOLY to lwpolyline. Hence I get a profile drawn referenced to 0,0. Seems that 3d polyline is not read and 2d polyline neither. Unfortunately I loose the elevation information while doing so. Any hints appreciated Edited September 22, 2013 by schoeller Wrong information provided Quote Link to comment Share on other sites More sharing options...
rahulcivilhzb Posted February 14, 2015 Share Posted February 14, 2015 Dear Friends, I want to know that how I make Typical Cross Section Drawing for Road Work & Culvert in Autocad , PLZ reply me early as possible. Quote Link to comment Share on other sites More sharing options...
Organic Posted February 22, 2015 Share Posted February 22, 2015 If you are drawing a typical cross section then I would draw it as a polyline. Add some dimensions also afterwards. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 22, 2015 Share Posted February 22, 2015 Dear Friends, I want to know that how I make Typical Cross Section Drawing for Road Work & Culvert in Autocad , PLZ reply me early as possible. Creating a cross-section using plain AutoCAD is pretty much like doing one manually on a drafting board unless you are working off of a 3D model. Are you? Quote Link to comment Share on other sites More sharing options...
