For those of you running on autocad 2006 already, I am running into a problem with my custom toolbars that were created in vba. The toolbars will load fine once I run the loading macro, but even though I use the save option to save the toolbar, it won't carry over when autocad is started up the next time. I makes me load the toolbar each time.
2nd issue that I am running into: when you enter the customize interface in autocad 2006, none of my toolbars that were created in vba show up. Am I missing a step?
Any help would be great! Here is a code example when I load my toolbars:
Public Sub ToolsToolbar()
Dim MenuGroupObj As AcadMenuGroup
Dim ToolbarObj As AcadToolbar
Dim ButtonObj As AcadToolbarItem
On Error GoTo error
'delete the toolbar if it exists
ThisDrawing.Application.MenuGroups.Item("FEI").Too lbars.Item("Tools").Delete
error:
'set variables
Set MenuGroupObj = ThisDrawing.Application.MenuGroups.Item("FEI")
Set ToolbarObj = MenuGroupObj.Toolbars.Add("Tools")
'add the buttons
Set ButtonObj = ToolbarObj.AddToolbarButton(0, "Length of lines", "Find length of selected lines", "-vbarun p:/jason/business/AutocadCustomToolbar/mystuff.dvb!module2.length" & vbCr)
ButtonObj.SetBitmaps "c:\acadr05\macro.bmp", "c:\acadr05\macro.bmp"
'show the toolbar
ToolbarObj.Visible = True
MenuGroupObj.Save (acMenuFileCompiled)
End Sub
