+ Reply to Thread
Results 1 to 6 of 6
Thread: Linetype Issue
  1. #1
    Forum Newbie
    Using
    AutoCAD LT 2004
    Join Date
    Dec 2008
    Posts
    3
    Default Linetype Issue
    I have been trying to fix a linetype issue in AutoCAD 2004. It is dashing my leader lines. I have set all my linetines to continuous and checked to make sure my linetype style command wasn't set at dashed. When I draw any type of line it is now dashing them too.
    My coworker opened the file on her computer and it is showing the leaders properly as continuous. I even reloaded the software and it is still showing the continuous line as a dashed line.
    Any insight would be greatly appreciated.
    S
  2. #2
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,493
    Default
    When did the problem first occur?
    If you open a different drawing and draw a new line does the same thing happen?
    It almost sounds like you are drawing on a layer that has a linetype already defined for it but you said you checked, right?
  3. #3
    Forum Newbie
    Using
    AutoCAD LT 2004
    Join Date
    Dec 2008
    Posts
    3
    Default
    The problem first occured today when I plotted and the linetypes were dashed. I don't remember having the issue on Friday. I have checked all my layer styles to make sure that they are continuous. I created multiple leader styles which I insert into my drawing, choosing the appropriate one for my final scale. I checked the leaderstyle dwg and it has the same issue of dashed lines. This file only has the layer 0 which is continuous and current.
    To create my leaders I insert the dwg and then make it the current dimension and text style.
    S
  4. #4
    Super Member skipsophrenic's Avatar
    Computer Details
    skipsophrenic's Computer Details
    Operating System:
    Vista 32 bit
    Computer:
    Compaq
    Motherboard:
    erm . . yeah?
    CPU:
    Intel Pentium Dual CPU E2140 @ 1.60 Ghz
    RAM:
    2039MB
    Graphics:
    don't ask you'll kill me
    Primary Storage:
    360gb
    Monitor:
    21" widescren - 16:10 ratio
    Using
    AutoCAD 2008
    Join Date
    Jul 2008
    Location
    Birmingham, United Kingdom
    Posts
    1,020
    Default
    This may seem a strange question but, has the .ctb file been changed at all to print out lines as dashed?
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. - Albert Einstein
    SET FILEDIA = 1
  5. #5
    Forum Newbie
    Using
    AutoCAD LT 2004
    Join Date
    Dec 2008
    Posts
    3
    Default
    I was in the ctb file to change a different lineweight. Somehow it changed yellow to be dashed. Thank you for your help on the situation.
    S
  6. #6
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,493
    Default
    Nice catch skipso.
Similar Threads
  1. linetype issue in viewport
    By 20hurtz in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th May 2008, 02:24 pm
  2. Custom Linetype Issue
    By spittle in forum AutoCAD Drawing Management & Output
    Last Post: 10th Dec 2007, 08:43 pm
  3. Linetype and Linetype Scale!
    By Penfold in forum AutoCAD Drawing Management & Output
    Last Post: 29th Oct 2007, 11:45 pm
  4. Hotfix Available for AutoCAD 2008 Linetype Display Issue
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 11th Oct 2007, 04:21 am
  5. More Linetype Q's
    By samla02 in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Jul 2007, 03:29 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
