Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Forum Newbie
    AutoCAD 2009
    Dec 2008
    2
    Default zoom/display problems?
    hi guys, I'm new here, and I'm getting frustrated with what I'm experiencing now with my autocad 2009 and now needs help.
    Whenever i zoom in (like zooming as much as it can), most of the diagonal lines are acting weird such as vanishing yet clickable, "ghost" lines appears (visible but not clickable), becomes a broken line, line stretching and etc. The Regen command doesn't help here.
    it was not like that before, and i didn't even touched the options.
    thx in advanced for those who will help^^
    specs:
    proc: c2q @ 2.5ghz
    mem: 4 gig (3 gig)
    gpu: ati hd 4870 512mb ddr5
    OS: vista home premium
    btw,
    I'm trying to upload a video of it, explaining excatly what happening is kinda hard.
    Super Member MaxwellEdison's Avatar
    MaxwellEdison's Computer Details
    Win 7 (64-bit)
    HP h8-1070t
    Intel Core i72600
    12GB
    AMD Radeon HD 6850
    Dell 20" LCD Widescreen (Main) NEC Accusync 125F 20" CRT (Secondary)
    Architecture 2012
    Dec 2008
    Lebanon, PA
    746
    First, welcome to the forums.
    Second, are these just regular lines or another type of element...dimensions, etc.? Is this happening on multiple drawings, or multiple machines? If it is only effecting your machine it may be an issue with the GFX driver. Check AutoCADs communication center to see if any new drivers have been made available for your card, also see if you have the latest service packs installed.
    Forum Newbie
    AutoCAD 2009
    Dec 2008
    2
    thx
    yes, regular lines, happens on any drawing I open.
    but the thing is it was working perfectly yesterday then suddenly acted strange today...
    but still, imma do what you advised ^_^
    Forum Newbie
    AutoCAD 2012
    Jan 2009
    7
    I have exactly the same problem. The nearly I zoom, the larger displacement of some lines (or polylines) are. And weird ghost lines appear.
    AutoCAD 2009 Update 2 doesn't repair that problem.
    If I change view>visual styles>2D wireframe to 3D wireframe, I can zoom nearer (little better) for this problem to apear.
    Anybody with solution?
  5. #5
    Super Member
    wannabe's Computer Details
    XP
    AutoCAD 2007
    Oct 2008
    Birmingham, UK
    772
    Look in tools>options and the level of graphical detail that can be applied to certain objects. I forget which tab, probably display.
    Hope this helps.
  6. #6
    Junior Member
    AutoCAD 2008
    Jun 2008
    16
    Turn off Hardware acceleration under Tools\Options\System\Performance settings\Manual tune. This should solve your problems, it did to me
  7. #7
    Forum Newbie
    AutoCAD 2012
    Jan 2009
    7
    Quote Originally Posted by Mrskotnjak View Post
    Finally, weirdest acad problem SOLVED!!!
    Thank you Mrs. Kotnjak!
  8. #8
    Forum Newbie
    AutoCAD 2012
    Jan 2009
    7
    Under
    Tools > Options > System > Performance Settings > Manual Tune
    turn Enhanced 2D Performance to OFF other accelerations can be enabled!
  9. #9
    Forum Newbie
    AutoCAD 2010
    Feb 2009
    2
    I been suffering with this problem for too long, Now is solved. Thanks guys
  10. #10
    Forum Newbie
    AutoCAD 2009
    Apr 2009
    4
    Wink Still want 3D?
    I had this problem as well... thought it was a display card error... was using X850 XE PE, then upgraded slightly to a HD4550.. and then HD4650..
    well, didn't do anything.
    I originally turned off 3D acceleration, but then performance suffered quite a bit.
    In the end, what worked for me was that whilst keeping Direct3D enabled, and all the gubbins turned on, you can turn OFF the Adaptive Degradation, and then the lines come out ok again!
    Not actually sure what adaptive degradation does when i'm working in 2D models most of the time, not actually sure if the performance needs to be adaptively degraded at any time.. but anyway, that worked for me, and now i can keep my nice Direct3D performance enhancements.
    wonder if the GeForce cards have this problem too?
  1. Display Order Problems and Exporting into Word
    By CML in forum AutoCAD Drawing Management & Output
    Last Post: 24th Apr 2009, 08:05 am
  2. 2004 Display Problems
    By ryank in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th Apr 2008, 01:32 pm
  3. Strange bug: Scroll mouse zoom out or ZOOM OUT
    By Martin Carmona in forum AutoCAD Drawing Management & Output
    Last Post: 19th Dec 2007, 11:42 pm
  4. Wheel Pan/Zoom problems
    By Randelli in forum AutoCAD Drawing Management & Output
    Last Post: 30th Oct 2006, 04:22 pm
