+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
  1. #1
    Full Member
    Using
    AutoCAD 2010
    Join Date
    Nov 2008
    Location
    South Africa
    Posts
    35
    Default Jogged dimension
    I don't even know if I have the rigth description for what I need to know. Basically I have an 11m wall between two doors and need to show both doors on a 1:50 scale, which means all the detail will not print on a A4. Is there a way I can show a dimension broken up in die middel like as you do with the function 'jogged line' but keep the original dimention description at 11m?
    Thanks for all your help
  2. #2
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,052
    Default
    Look under Help > Dimensions > Jog lines.
  3. #3
    Senior Member soleary's Avatar
    Computer Details
    soleary's Computer Details
    Operating System:
    Windows Vista
    Using
    AutoCAD 2008
    Join Date
    Oct 2008
    Location
    Ireland, Republic of
    Posts
    202
    Default
    Quote Originally Posted by ALoock View Post
    Have you tried the jogged linear dimension?
  4. #4
    Full Member
    Using
    AutoCAD 2010
    Join Date
    Nov 2008
    Location
    South Africa
    Posts
    35
    Default
    Thanks ReMark, I had a look and forgive me if I sound even more stupid now. You see, to add a jog on an existing dimension is not the problem (the dimension being the full 11m) how do I get a dimension of 11m to show a jogged line, say 11m and only be 1m?
    Thanks for your response!
  5. #5
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,052
    Default
    Fake it like they used to do before AutoCAD added the ability to jog a linear dimension. Do it manually.
  6. #6
    Computer Details
    Operating System:
    Windows Vista
    Using
    AutoCAD 2008
    Join Date
    Oct 2008
    Location
    Posts
    202
    Default
    You didn't sound stupid in the first place so no need to say that. We all had to start AutoCAD at some stage. It's only with experience and training, we gather the knowledge.
    I think it's the use of the word 'dimension' that is slightly confusing. Do you mean you have an object that is drawing at in CAD 1m in length (with a jog) but this 'really' reperesents 11m and you want the dimension to show 11m when you do your dimension?
  7. #7
    Full Member
    Using
    AutoCAD 2010
    Join Date
    Nov 2008
    Location
    South Africa
    Posts
    35
    Default
    Thanks soleary. I typed in 'dimjogline'; was asked to select the dimension; which I did and then it makes a neat jog but the dimension does not change! What do I do wrong?
  8. #8
    Full Member
    Using
    AutoCAD 2010
    Join Date
    Nov 2008
    Location
    South Africa
    Posts
    35
    Default
    Quote Originally Posted by soleary View Post
    Thanks!
    Yes, that is what I mean. On the description of jogged linear it says that that is what it does, yet I struggle!
  9. #9
    Computer Details
    Operating System:
    Windows Vista
    Using
    AutoCAD 2008
    Join Date
    Oct 2008
    Location
    Posts
    202
    Default
    You probably didn't do anything wrong. The problem (I think) is that the software doens't know what to change it to. As ReMark said you can do it manully by overriding the dimension text. Click on the dimension, type properties and a pallette will open. Scroll down and under 'text' there is an option to override the text. Put the value that you want in there. Hope that helps
  10. #10
    Full Member
    Using
    AutoCAD 2010
    Join Date
    Nov 2008
    Location
    South Africa
    Posts
    35
    Default
    Great, that works, thanks guys!
Similar Threads
  1. Dimension - remove dimension line but not arrows
    By jkristia in forum AutoCAD Beginners' Area
    Last Post: 7th Nov 2008, 04:24 pm
  2. add text in dimension below dimension line
    By Dipali in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th Apr 2008, 01:03 pm
  3. Follow linear dimension with continued dimension
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 4th Aug 2007, 09:31 pm
  4. Jogged arc dimension.
    By Cadastrophic in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Oct 2005, 12:07 am
  5. Dimension>Style or Format>Dimension Style problem
    By jocaan in forum AutoCAD Beginners' Area
    Last Post: 21st Apr 2004, 08:50 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
