Results 1 to 9 of 9
    Forum Newbie
    AutoCAD 2008
    Dec 2008
    5
    Default File lock timeout?
    I have a question regarding file locks when opening DWG files.
    Say user A connect to a server X using VPN and via the network open a file which is located on file server Y and saves it from time to time. User B then cannot open that file as it is locked by user A. What I would like to know for certain is what happens if the VPN connection for user A temporaily drops, is the file lock then lost at the server so that user B can open and edit the file and potentially overwriting the changes user A has made, or potentially causing them to work on the same file at the same time? What about file locks and their timeout period in this scenario?
    /Andreas
    Super Member
    Dipali's Computer Details
    windows 10
    TOSHIBA "SATELLITE"
    Intel inside CORE i7
    viewsonicVA1916w
    Architectural
    Dipali's Discipline Details
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2015
    Dec 2007
    INDIA
    1,109
    Quote Originally Posted by hermelin View Post
    /Andreas
    2 people working on the same file at same time is not possible.
    In the aboe senario, whatevr chnages user A has made after his last 'qsave' will be lost, he will have to do the save as of that file in his local drive & when the connection is restored save it back to server. In the meantime user B opens that file & make some changes but if user A replaces the file his(user B) changes will be lost & if does not than the changes he made will not be in the drawing afetr last 'qsave' before connection failed.
    "An architect's most useful tools are an eraser at the drawing board & a wrecking bar at the site."
    Frank Lloyd Wright
    Forum Newbie
    AutoCAD 2008
    Dec 2008
    5
    Quote Originally Posted by Dipali View Post
    Thanks! Do you know how long the file lock remains after user A loses the connection to the server? I understand that the DWL-file is controlling this, is there any documentation on this file and how it works?
    Super Member
    windows 10
    TOSHIBA "SATELLITE"
    viewsonicVA1916w
    Architectural
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2015
    Dec 2007
    INDIA
    1,109
    Unhappy
    I wasn't sure about that, so I tried out that senario here with other computer. & it seems that lockout does not open until 3-5 miniutes.but after 3 min. I was able to open that drawing.
    Frank Lloyd Wright
  5. #5
    Forum Newbie
    AutoCAD 2008
    Dec 2008
    5
    Nice to know, thanks! Do you know if this setting is configurable so that you can raise the timeout?
  6. #6
    Super Member
    windows 10
    TOSHIBA "SATELLITE"
    viewsonicVA1916w
    Architectural
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2015
    Dec 2007
    INDIA
    1,109
    Sorry, no idea.
    I will check with the netwrok (IT) people later on & try to find out.
    Frank Lloyd Wright
  7. #7
    Forum Newbie
    AutoCAD 2008
    Dec 2008
    5
    Sorry, no idea.
    Excellent, I'm looking forward to your reply! Thanks for helping me out
  8. #8
    Super Member
    windows 10
    TOSHIBA "SATELLITE"
    viewsonicVA1916w
    Architectural
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2015
    Dec 2007
    INDIA
    1,109
    I just talked to him & he says that to be able to keeep the lock on file, I will have to install 'Version control software'. fater that whenever I access that file using that & untill I submit back, it will open only as read only in other people's computer.
    Frank Lloyd Wright
  9. #9
    Forum Newbie
    AutoCAD 2008
    Dec 2008
    5
    Yep, a CVS system is what I figured as well but I am very happy with the answer. Thank you so much for the help!
  1. Lock Viewport
    By O Snap! in forum AutoCAD General
    Last Post: 11th Jul 2008, 05:58 pm
  2. lock washer
    By Impala62 in forum AutoCAD Drawing Management & Output
    Last Post: 8th May 2008, 05:02 pm
  3. Zoom Lock
    By M29 in forum AutoCAD Drawing Management & Output
    Last Post: 19th Jun 2007, 08:40 pm
  4. Lock an object
    By edwin in forum AutoCAD Drawing Management & Output
    Last Post: 20th Nov 2006, 03:53 am
  5. Is it possible to "lock" a DWG file???
    By tzframpton in forum AutoCAD Drawing Management & Output
    Last Post: 25th Jul 2006, 05:06 pm
