Results 1 to 6 of 6
    Senior Member
    not specified
    Mar 2005
    208
    Default Dimension setting
    Is there a setting or variable so that I can make my dimensions (lines, arrows etc.) immune to object snap?
    I'm used to them being like that in Autocad Mechanical so I don't know if this is a Mechanical option or if I can do it in plain Autocad. I've stopped using Mechanical until they put out a patch to fix some of the bugs. (Version 2006)
    I've searched but I can't find what I'm looking for.
    Another quesiton...is there a dimalign command or lisp for plain Autocad? I mainly use Mechanical for the extra dimensioning capabilities, AMdimalign being one of my most used commands...and one that I sorely miss.
    If there is anything the nonconformist hates worse than a conformist,
    it's another nonconformist who doesn't conform
    to the prevailing standard of nonconformity.
    Junior Member
    Mechanical
    jetxcc's Discipline Details
    I'm a drafter. I design roadway structures.
    Mechanical
    Mechanical 2018
    Sep 2017
    Missouri, USA
    14
    Code:
    (DEFUN C:AD ()
    (Command "dimspace" pause (setq ss1 (ssget)) ss1"" "0.0"))
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,863
    Yes, there is an Aligned option for dimensions in AutoCAD.
    I'm retired now.....not dead. I have a few working brain cells left.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,797
    Much quicker to simply type dimspace. Is a LISP program really necessary to execute one command.
    As far as snap points in dimensions... see image below. Command = OPTIONS > Drafting tab.
    Further help... Command = OSNAP then uncheck Node. That way you wont get dimensions associated to each other instead of the objects you are dimensioning.
    Of course, if you use points, as in the command DIVIDE, you will have to turn Node back on in order to snap to them.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  5. #5
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,797
    Quote Originally Posted by Big Mike View Post
    How would you like the dimensions aligned?
  6. #6
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,797
    When I want my dims to be spaced equally, I simply draw a rectangle around the extents of the object(s) I want to dimension, then offset the rectangle by the same distance I want my dims to space out equally, a number of times. Yup, then once I apply a dimension I click it onto one side of the rectangle at the distance needed. Erase the rectangles. Takes a couple seconds but faster than DIMSPACE since it prepares all 4 sides at once, and no going back except to erase the rectangles.
    Like this... cheeze that's pretty dim. Hope you can see it on your screen.
