Results 1 to 3 of 3
    Super Member MaxwellEdison's Avatar
    MaxwellEdison's Computer Details
    Win 7 (64-bit)
    HP h8-1070t
    Intel Core i72600
    12GB
    AMD Radeon HD 6850
    Dell 20" LCD Widescreen (Main) NEC Accusync 125F 20" CRT (Secondary)
    Architecture 2012
    Dec 2008
    Lebanon, PA
    749
    Default (not) Editing attributes in a dynamic block
    Whelp....I got me another dynamic block pickle. I put a lookup table in my detail block with an attribute directly underneath the leader. When you change the lookup state it sets size for a parameter and the attribute displays the state of the lookup action in a field. Everything is functioning properly, I can select the lookup state (in this case a specific post size) and the detail changes to the new size. Once the drawing is regen'ed the field updates as well, showing the changed information.
    The only problem remaining is the attribute field in the properties dialog for the block. Someone can enter a text string which overwrites the field and breaks the association. The lookup table still controls the size, but the field no longer updates. Is there a way I can lock or remove the attribute from the properties listing? I've tried making it constant, but that results in just null characers (#) being displayed under the field. And if I change it to invisible it simply dissapears (no surprise there ) So anyway I can stop well meaning individuals from breaking my block?
    I've attached a simplified portion of the block (saved in 2007 version) below that illustrates my problem. Any ideas?
    Just because you're , doesn't mean wrong is all that's .
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    Windows 7 Professional
    Dell
    Intel Xeon E5-1603@2,80GHz
    4GB
    NVIDA Quadro K600
    DELL 23" & SAMSUNG 21"
    not applicable
    Nov 2005
    Kenley, Surrey, UK
    5,644
    I can't look until I get to work but I haven't found a way to stop people editing fields yet. The best I have come up with is to set ATTREQ = 0 so that the attributes dialogue doesn't come up on insertion.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    "Everything in drafting is logical. Except what isn’t." - Gavin Guile. (from the Lightbringer series of books by Brent Weeks)
    Dave
    Win 7 (64-bit)
    HP h8-1070t
    Intel Core i72600
    12GB
    AMD Radeon HD 6850
    Architecture 2012
    Dec 2008
    Lebanon, PA
    749
    That's kind of the opinion I'm resigning myself to. Know of any strings or settings to allow a field to be inserted in an MLeader so the association will survive being inserted in another drawing? Currently I can't get it to pull for anything other than the arbitrary object id.
  1. Dynamic block with dynamic attributes
    By Helenka in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jul 2012, 09:56 am
  2. editing block with attributes
    By feargt in forum AutoCAD General
    Last Post: 2nd Oct 2008, 01:34 pm
  3. VBA: choosing dynamic block attributes
    By CADenator in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Aug 2008, 04:34 am
  4. A question about editing block attributes
    By alijahed in forum AutoCAD General
    Last Post: 9th May 2007, 06:02 am
  5. dynamic block attributes?
    By maxholer in forum AutoCAD General
    Last Post: 25th May 2005, 12:59 pm
