BIGMIKE09281946 Posted December 23, 2008 Share Posted December 23, 2008 I have excess block fragments lurking about in my drawing. How does one go about identifying these vermin so that they may be purged. The dynamic block is also available for critiquing. CHP10 BLK 009 LOOKUP FLANGE50.dwg Quote Link to comment Share on other sites More sharing options...
MaxwellEdison Posted December 23, 2008 Share Posted December 23, 2008 I don't see any extra block fragments floating around, but if you have any start with Ctrl+A(Select All) and deselect the things that should be there. Then delete the selection, after that PURGE everything. Turn on purge nested items and turn off confirm each item to be purged. As far as the block. I'm sure it does everything the book asks of it. But try replacing the separate linear parameters on the flange with a linear stretch pair and change its base to be from the midpoint. This way you can control the size of the flange with one parameter. Also look into changing the parameter description on under the Display Properties heading of the properties for the parameter. This is handy for others using your block as it will generate a tooltip when they hover over the grip point or the field in the dynamic block's properties. Overall I gie it a B, solid construction and an organized block editor layout. Add some polish to get that A. Quote Link to comment Share on other sites More sharing options...
BIGMIKE09281946 Posted December 23, 2008 Author Share Posted December 23, 2008 Am I heading in the right direction? BLK_CHP10_WELDNECK.DWG Quote Link to comment Share on other sites More sharing options...
MaxwellEdison Posted December 23, 2008 Share Posted December 23, 2008 Take a look at this. Let me know if anything got lost in the savedown BLK_CHP10_WELDNECK[Example].dwg Quote Link to comment Share on other sites More sharing options...
BIGMIKE09281946 Posted December 24, 2008 Author Share Posted December 24, 2008 Click Here!! BLK_CHP10_WELDNECK_CLIK_HERE.dwg Quote Link to comment Share on other sites More sharing options...
MaxwellEdison Posted December 24, 2008 Share Posted December 24, 2008 Looks good. I certainly hope you're doing well in the class. Quote Link to comment Share on other sites More sharing options...
BIGMIKE09281946 Posted December 24, 2008 Author Share Posted December 24, 2008 Thank You!! Happy Holidays! How come I can't explode the block in the flange drawing? The book and the exam, say that I can! I also don't have a good feeling about my copy of AutoCAD, too many things don't work; like the F8 key. Quote Link to comment Share on other sites More sharing options...
MaxwellEdison Posted December 24, 2008 Share Posted December 24, 2008 You didn't have the allow exploding checkbox set when you created the block. You can remake the block and turn that on, or delete the block, open the block dialog box (block at command line) select your block from the dropdown and click allow exploding. Then just re-insert it. Quote Link to comment Share on other sites More sharing options...
BIGMIKE09281946 Posted December 24, 2008 Author Share Posted December 24, 2008 The school was sent this message from me: Message: Can a weld-neck flange, such as the one being shown in the text of HACAD 2006, page 571, with 8 attributes be configured as a dynamic block with four different sizes of weld-necks? Their reply: Dear Michael, From Me: If the block is dynamic and defined to have an adjustable size, you can change the size in the Properties palette. AutoCAD Instructional Staff Is it any wonder? Is it possible to have attributes in a dynamic block? I am going to spend some time trying to figure this one out. Quote Link to comment Share on other sites More sharing options...
BIGMIKE09281946 Posted December 25, 2008 Author Share Posted December 25, 2008 Here you go! BLK_CHP10_TRESE.dwg Quote Link to comment Share on other sites More sharing options...
