Fullalove Posted December 23, 2008 Share Posted December 23, 2008 Is there a way to create sections views of a site, particularly where multiple surfaces overlap? Quote Link to comment Share on other sites More sharing options...
rustysilo Posted December 23, 2008 Share Posted December 23, 2008 If you are working in Civil 3d and want a sectional view of your site there are several ways: 1.) Draw a line where you want the section, select it > quick profile (this option will go away when you save again. if you want to keep it you'll have to export to landxml and then import said landxml file.) 2.) Create an alignment across your site where you want the section, profiles > create profile from surface > select your alignment and surface(s) > draw in profile view 3.) Create an alignment perpendicular to where you want the section and then generate sections at each station where you want one. (This would take more typing here so I won't get into it unless you really want to do it this way). hint: I'd go with #1 Quote Link to comment Share on other sites More sharing options...
Fullalove Posted December 23, 2008 Author Share Posted December 23, 2008 Thank You! Along the same lines, is there a way to edit the different material's renderings within the section view itself, so it is easier to differentiate between each? Quote Link to comment Share on other sites More sharing options...
rustysilo Posted December 24, 2008 Share Posted December 24, 2008 Different materials? You mean a different linetype or color for each section/profile? If so you do that by creating different profile styles. Look under the Toolspace > Settings tab > Profiles > Profile styles and right click it > new profile style. Set your colors, linetypes, etc. in there. Then select each respective profile > profile properties > and set your style in there. Hope that helps. Quote Link to comment Share on other sites More sharing options...
