Changing fonts globally?
mlockett216
I posted this question 2 days ago, but now I can't find it or any replies:
In AutoCAD 2000, I want to change all the fonts in all multiline text in a drawing. I can change the height by clicking each text, right-clicking and selecting 'properties'. In the properties box I can change the height, but not the font. To change the font, I have to select each text separately, pull-up the multiline text editor, highlight the text, then select the font. This is very time consuming.
Any suggestions?
check what text style is used & than go to format>text style & in that dialoguebox, slect the style & change the fonts for that style.
it will update the multiline texts only if th efints are not overriden in mmt editor with the above method you mentioned.
