Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 30
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,559
    Default Polyline Vertex Question
    Hi Guys,
    Hope you are all having a great Christmas, and have a equally good New Year.
    Just a quick question, which I am sure can be answered in minutes.
    When looking at a problem posted on here recently (about marking points on a golf course...), I was thinking how I would approach the problem, and thought about using the vertices of a user-drawn polyline.
    To experiment, I drew myself a polyline (attached), and performed an entget operation on it to see what it would return.
    This is the result:
    Code:
    ((-1 . <Entity name: 7ef62ed8>)
    (0 . "LWPOLYLINE")  <<--- Entity Type
    (330 . <Entity name: 7ef53cc0>)
    (5 . "2DC3")
    (100 . "AcDbEntity")
    (67 . 0)
    (410 . "Model")  <<--- Tab Name
    (8 . "3")  <<--- Layer Name
    (100 . "AcDbPolyline")
    (90 . 4)
    (70 . 0)
    (43 . 0.0)
    (38 . 0.0)
    (39 . 0.0)
    (10 0.0 0.0)  <<--- First Vertex (Start Point)
    (40 . 0.0)   <<--- Starting Thickness for First Segment
    (41 . 0.0)  <<--- Ending Thickness for First Segment
    (42 . 0.0)
    (10 10.0 0.0)   <<--- Second Vertex
    (40 . 0.0)
    (41 . 0.0)
    (42 . 0.0)
    (10 10.0 10.0)  <<--- Third Vertex
    (40 . 0.0)
    (41 . 0.0)
    (42 . 0.0)
    (10 0.0 10.0)  <<--- Fourth Vertex (End Point)
    (40 . 0.0)
    (41 . 0.0)
    (42 . 0.0)
    (210 0.0 0.0 1.0))
    These coordinates correspond to the various vertices on my attached drawing. But my question is, how does one obtain these values through LISP?
    My initial assumption would be something of the form:
    Code:
    (defun c:test (/ ent Vertex)
        (setq ent (entget (car (entsel))))
        (setq Vertex (cdr (assoc 10 ent)))
    ) ;_  end defun
    But how would one retrieve the next vertex, and every other vertex after that? How do you cycle through the different entries for the DXF code 10?
    Many thanks for any advice and help provided
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Super Member ASMI's Avatar
    AutoCAD 2008
    Nov 2005
    Oceanus Procellarum, Moon
    1,427
    Try in command line:
    Click polyline to get DXF list:
    Code:
    Command: (setq plDxf(entget(car(entsel))))
    Select object: ((-1 . <Entity name: 7efa3368>) (0 . "LWPOLYLINE") (330 .
    <Entity name: 7efa1cf8>) (5 . "1AD") (100 . "AcDbEntity") (67 . 0) (410 .
    "Model") (8 . "0") (100 . "AcDbPolyline") (90 . 4) (70 . 0) (43 . 0.0) (38 .
    0.0) (39 . 0.0) (10 0.0 0.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 10.0 0.0) (40
    . 0.0) (41 . 0.0) (42 . 0.0) (10 10.0 10.0) (40 . 0.0) (41 . 0.0) (42 . 0.0)
    (10 0.0 10.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (210 0.0 0.0 1.0))
    Remove all non 10 groups:
    Code:
    Command: (setq lst10(vl-remove-if '(lambda(x)(/= 10(car x)))plDxf))
    ((10 0.0 0.0) (10 10.0 0.0) (10 10.0 10.0) (10 0.0 10.0))
    Remove first member of each list"
    Code:
    Command: (setq verLst(mapcar 'cdr lst10))
    ((0.0 0.0) (10.0 0.0) (10.0 10.0) (0.0 10.0))
    Or at once:
    Code:
    Command: (mapcar 'cdr(vl-remove-if '(lambda(x)(/= 10(car x)))(entget(car(entsel)))))
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,559
    Thank you for your reply, ASMI - I have learnt a lot from it.
    But, I note that this would only work for this example - for instance, if I had vertices with co-ordinates:
    (1.0 5.0 0.0)
    (2.0 6.0 0.0)
    (3.0 7.0 0.0)
    How would I deal with this situation?
    Is there not a generic function for dealing with multiple occurences of the same DXF group code?
    Thanks for your help ASMI, much appreciated.
    AutoCAD 2008
    Nov 2005
    1,427
    It will work with every lwpolyline.
  5. #5
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,559
    Ahh, Sorry, I misread you last post - when you removed the DXF 10 code. Sorry!
    And thanks for your help!
  6. #6
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,559
    Thanks lpseifert,
    Thats very interesting!
  8. #8
    Forum Deity David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    2,547
    Code:
    (defun massoc (key alist / x nlist)
      (foreach x alist
        (if (eq key (car x))
            (setq nlist (cons (cdr x) nlist))))
      (reverse nlist))
    This will return a list of values for the key in alist. It was made to deal with just such a scenario.
    You would have to do some extra coding for every other one etc.
    -David
    R12 (Dos) - A2K
  9. #9
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,559
    Excellent David,
    Simple and effective. Nice one
    Thanks
  10. #10
    Senior Member
    AutoCAD 2008
    Dec 2009
    200
    I might be missing something here, but would it be possible to take the points taken from the polyline and save them as pt1, pt2, pt3.... so they can be used in another command?
  1. Increase vertex of 3dmesh
    By MR MAN in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Sep 2008, 03:20 pm
  2. add vertex z or elevation to points
    By gvlisnas in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Aug 2007, 11:14 pm
  3. reading from vertex files
    By gib65 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 1st Feb 2007, 06:35 am
  4. Viewing 3DSolid vertex
    By LeoRoncetti in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd May 2006, 01:14 am
  5. newb! question - join polyline then fillet
    By pdlefief in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Apr 2006, 09:32 pm
