Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 30
  1. #11
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,454
    Quote Originally Posted by KRBeckman View Post
    I might be missing something here, but would it be possible to take the points taken from the polyline and save them as pt1, pt2, pt3.... so they can be used in another command?
    Wow... this is an old thread - takes me back to when I started learning all this..
    As for your question - all the point data is in the resulting list, so you could assign your variables from that.
    But I would approach it differently and use vlax-curve-getPointatParam as you have much more control.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  2. #12
    Senior Member
    AutoCAD 2008
    Dec 2009
    200
    I tried to search Visual Lisp's help and google for this and I can only find examples of it being used that went way over my head... do you mind showing me an example of using this function and break it down step by step how it works?
  3. #13
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,454
    Each curve object is 'divided' by a parameter, you can look at it as the parameter in a set of parametric equations that would describe the curve if you like, so for a circle:
    Code:
    x = r cos(t)
    y = r sin(t)
    Where, in this case, t is the parameter.
    The curve functions allow you to get a point for a specific parameter value.
    In the case of LWPolylines, each segment spans between two integer values of the parameter, hence each vertex is at an integer parameter value.
    This gives you a lot of control when getting specific parameter values, as you can just 'count' the vertices.
    Example:
    Code:
    (defun c:test (/ ent i pt)
      (setvar "PDMODE" 34)
      (if (setq ent (car (entsel "\nSelect LWPolyline: ")))
          (setq i (1- (vlax-curve-getStartParam ent)))
          (while (setq pt (vlax-curve-getPointatParam ent (setq i (1+ i))))
            (entmakex (list (cons 0 "POINT") (cons 10 pt))))))
      (princ))
  4. #14
    Super Member CAB's Avatar
    AutoCAD 2000
    May 2004
    Tampa, Florida
    805
    A long winded example.
    Code:
    (defun c:test (/ ent idx pt startParam endParam)
          (setq startParam (vlax-curve-getStartParam ent))  ; this is usually zero
          (setq endParam (vlax-curve-getEndParam ent))
          (setq idx startParam)
          (while (<= idx endParam) ; loop until we get to the last param
    	(setq pt (vlax-curve-getPointatParam ent idx))
    	(cond
    	  ((= idx endParam)
    	   (setq idx (1+ idx)) ; force an exit of the loop
    	  ((> (setq idx (1+ idx)) ; next param
    	      endParam) ; test to see of we are past the end Param
    	    (setq idx endParam) ; in case the last param is a fraction
    Senior Member
    AutoCAD 2008
    Dec 2009
    200
    Wow, way over my head, I still have a lot to learn
  6. #16
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,454
    I would recommend persevering with the curve-functions, they are a handy (and quick!) asset in your toolbox
  7. #17
    Senior Member
    AutoCAD 2008
    Dec 2009
    200
    So, I've looked into this a bunch and I'm not getting anywhere... How would I use the vlax-curve-getPointatParam function to save the vertices as pt1, pt2, pt3....?
  8. #18
    AutoCAD 2000
    May 2004
    Tampa, Florida
    805
    All you need is a LIST of points, correct?
    This returns a list of points from the entity list of a LWPolyline.
    Code:
    (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= 10 (car x))) elst))
    Use it like this:
    Code:
    (defun c:test()
      (setq ent (car(entsel "\nSelect a polyline.")))
      (setq elst (entget ent))
      (setq PointList (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= 10 (car x))) elst)))
    You don't need to assign each point to a variable.
    Tell us what you want to do with these points.
  9. #19
    Senior Member
    AutoCAD 2008
    Dec 2009
    200
    Code:
    Yeah, I've gotten this far...
    I want to use these points in filling the Polyline with 3d-Faces
  10. #20
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,454
    Wasn't this being addressed here?
    http://www.cadtutor.net/forum/showthread.php?t=44611
  1. Increase vertex of 3dmesh
    By MR MAN in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Sep 2008, 03:20 pm
  2. add vertex z or elevation to points
    By gvlisnas in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Aug 2007, 11:14 pm
  3. reading from vertex files
    By gib65 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 1st Feb 2007, 06:35 am
  4. Viewing 3DSolid vertex
    By LeoRoncetti in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd May 2006, 01:14 am
  5. newb! question - join polyline then fillet
    By pdlefief in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Apr 2006, 09:32 pm
