Page 3 of 3 FirstFirst 1 2 3
Results 21 to 30 of 30
  1. #21
    Senior Member
    AutoCAD 2008
    Dec 2009
    200
    Yeah it is, but the I wasn't getting the answer I was looking for, so I did some more digging and found this one and was hoping to get closer to the solution. I guess looking back I should have just referenced this post in the other one, sorry rookie mistake.
  2. #22
    Senior Member
    AutoCAD 2008
    Dec 2009
    200
    Quote Originally Posted by ASMI View Post
    Try in command line:
    Click polyline to get DXF list:
    Code:
    Command: (setq plDxf(entget(car(entsel))))
    Select object: ((-1 . <Entity name: 7efa3368>) (0 . "LWPOLYLINE") (330 .
    <Entity name: 7efa1cf8>) (5 . "1AD") (100 . "AcDbEntity") (67 . 0) (410 .
    "Model") (8 . "0") (100 . "AcDbPolyline") (90 . 4) (70 . 0) (43 . 0.0) (38 .
    0.0) (39 . 0.0) (10 0.0 0.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 10.0 0.0) (40
    . 0.0) (41 . 0.0) (42 . 0.0) (10 10.0 10.0) (40 . 0.0) (41 . 0.0) (42 . 0.0)
    (10 0.0 10.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (210 0.0 0.0 1.0))
    Remove all non 10 groups:
    Code:
    Command: (setq lst10(vl-remove-if '(lambda(x)(/= 10(car x)))plDxf))
    ((10 0.0 0.0) (10 10.0 0.0) (10 10.0 10.0) (10 0.0 10.0))
    Remove first member of each list"
    Code:
    Command: (setq verLst(mapcar 'cdr lst10))
    ((0.0 0.0) (10.0 0.0) (10.0 10.0) (0.0 10.0))
    Or at once:
    Code:
    Command: (mapcar 'cdr(vl-remove-if '(lambda(x)(/= 10(car x)))(entget(car(entsel)))))
    How would I change this last line of code to automattically select the last polyline drawn?
  3. #23
    Super Member CAB's Avatar
    AutoCAD 2000
    May 2004
    Tampa, Florida
    805
    (ssname (ssget "_X" (list (cons 0 "LWPOLYLINE"))) 0)
  4. #24
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,559
    You can get at the last entity entered into the drawing database using entlast.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  5. #25
    Senior Member
    AutoCAD 2008
    Dec 2009
    200
    Quote Originally Posted by CAB View Post
    Replace "entsel" with this?
  6. #26
    Senior Member
    AutoCAD 2008
    Dec 2009
    200
    Quote Originally Posted by Lee Mac View Post
    Do I replace "entsel" with "entlast", or use:
    Code:
    entsel(entlast)
  7. #27
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,559
    Replace
    Code:
    (car (entsel))
    With
    Code:
    (entlast)
    Or the code that CAB kindly provided.
    Look up the entlast function in the Help files - you will see that it returns an ename (if successful), whereas entsel returns a list, therefore we can conclude that the 'car' must be replaced also, as we are not dealing with a list.
  8. #28
    Senior Member
    AutoCAD 2008
    Dec 2009
    200
    Thanks a ton guys, really appriciate your help!!!
  9. #29
    AutoCAD 2000
    May 2004
    Tampa, Florida
    805
    Use this
    (mapcar 'cdr(vl-remove-if '(lambda(x)(/= 10(car x)))(ssname (ssget "_X" (list (cons 0 "LWPOLYLINE"))) 0)))
    Problem with (entlast) is that the last entity may not be a LWPolyline.
    Unless you just created it.
    The example I posted would bomb if there are no LWPolylines in the DWG.
  10. #30
    Junior Member leo321's Avatar
    leo321's Computer Details
    w7 64bt
    TOSHIBA / DELL
    i5 3°generation
    4 gb other 6gb
    1gb other 2gb
    500gb
    2 tera
    21' and 17'
    Structural
    leo321's Discipline Details
    design Project
    Structural
    Pipelines, Industrials Units, Wind Farms, Minig, transmission line, thermoelectric, etc..
    AutoCAD 2012
    Jan 2013
    São Paulo / Brazil
    21
    Want change this!
    (defun C:LP(/ PNT1 P1X P1Y STDY DY COORDN COORDE PTXT)
    (setq PNT1 (getpoint
    "\nPick coordinate point: "))
    (setq P1X (car pnt1)) ;x coord
    (setq P1Y (cadr pnt1)) ;y coord
    (setq STDX (rtos P1X 2 2))
    (setq STDY (rtos P1Y 2 2))
    (setq COORDN (strcat "N=" STDY ))
    (setq COORDE (strcat "E= " STDX ))
    (setq PTXT (getpoint
    "\nPick text location: "))
    (command "LEADER" PNT1 PTXT "" COORDN COORDE "")
    now print this
    N=8566159.79
    E= 505422.47
    wanted this way
    N=8.566.159,79
    E= 505.422,47
  1. Increase vertex of 3dmesh
    By MR MAN in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Sep 2008, 03:20 pm
  2. add vertex z or elevation to points
    By gvlisnas in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Aug 2007, 11:14 pm
  3. reading from vertex files
    By gib65 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 1st Feb 2007, 06:35 am
  4. Viewing 3DSolid vertex
    By LeoRoncetti in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd May 2006, 01:14 am
  5. newb! question - join polyline then fillet
    By pdlefief in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Apr 2006, 09:32 pm
