Results 1 to 2 of 2
Thread: sweep question
    Senior Member
    AutoCAD 2009
    Aug 2008
    Los Angeles area, CA
    118
    Default sweep question
    Is there a way to get the sweep to follow the entire path?
    I'm trying to add a stair nose to a step, but unless I add the profile at the end of the path it will only create the sweep for part of the path.
    If I add a second sweep using the same sketch and profile then it does complete the path, but is it possible to do it with only one sweep?
    Jesper
    Forum Deity shift1313's Avatar
    not applicable
    Sep 2008
    VA
    2,859
    i have done a sweep around an entire object before by selecting the sketch edge as my path. Do you have an edge you can select? you may need to use the convert entities while in a 3d sketch if everything isnt in the same plane
  1. Extrude or Sweep?
    By Oxygen454 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 28th Dec 2009, 07:29 am
  2. sweep going goofy
    By dumfatnhappy in forum AutoCAD General
    Last Post: 10th Sep 2008, 09:37 am
  3. problem in Sweep
    By alijahed in forum AutoCAD General
    Last Post: 29th Oct 2007, 11:19 pm
  4. problem with sweep
    By johnboy in forum AutoCAD General
    Last Post: 12th Sep 2007, 01:49 pm
  5. Sweep multiples
    By Erkden in forum Design Software
    Last Post: 21st Mar 2007, 08:29 pm
