Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    Senior Member
    AutoCAD 2000
    Nov 2008
    182
    Default Shortcut command for circle
    This is my code:
    ;; Shortcut command for circle
    (defun c:ctd (/ a)
    (setq a (/ (getreal "\nd:") 2))
    (command "circle" "_ttr" pause pause a)
    At present this is what appears on my command line,
    Command: ctd
    d:100
    circle Specify center point for circle or [3P/2P/Ttr (tan tan radius)]: _ttr
    Specify point on object for first tangent of circle:
    Specify point on object for second tangent of circle:
    Specify radius of circle: 50.00000000000000
    Command:
    Command:
    And this if I press ESCAPE at prompt,
    Command:
    CTD
    d:
    ; error: bad argument type: numberp: nil
    What I want to achieve is something like this,
    Command: ctd
    d<0>:100 <------NOTICE THIS
    Command:
    Command:
    And when I press ENTER,
    Command: ctd
    d<100>: ( press ENTER key at this point)
    Specify radius of circle <50.0000>: 50.00000000000000
    Command:
    Command:
    How will I do that?
    We learn more by looking for the answer to a question and not finding it than we do from learning the answer itself. ~Lloyd Alexander
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,536
    Perhaps this?
    Code:
    (defun c:ctd (/ a)
        (or (getenv "DIAM") (setenv "DIAM" "0"))
        (if    (setq a (/ (getreal (strcat "\nd<" (getenv "DIAM") ">: ")) 2))
        (setenv "DIAM" (rtos (* 2 a)))
        ) ;_  end if
        (command "_circle" "_ttr" pause pause (getenv "DIAM"))
    ) ;_  end defun
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Senior Member
    AutoCAD 2000
    Nov 2008
    182
    Thanks Lee Mac! That was pretty quick.
    How can I fix this error when I press escape?
    Command: ctd
    d<100>: *Cancel*
    ; error: Function cancelled
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,536
    I thought maybe this, but it doesn't really get around it.
    Code:
    (defun c:ctd (/ a)
        (defun *error* (msg)
        (if (= msg "")
            (princ "\nFunction Complete.")
            (princ (strcat "\n" (strcase msg)))
        ) ;_  end if
        ) ;_  end defun
        ) ;_  end if
    ) ;_  end defun
    Plus, if I hit enter when the default is there it says, bad argument, numerp nil.
  5. #5
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,536
    Sorry, haven't got much time today
  6. #6
    Senior Member
    AutoCAD 2000
    Nov 2008
    182
    Ok, thanks, I'll wait for others...
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,536
    Looked over it again - stupid mistake really.
    Can't quite sort your error problem though:
    Code:
    (defun c:ctd (/ a)
        (if (= msg "")
        ) ;_  end if
        ) ;_  end defun
        (if    (setq a (getreal (strcat "\nd<" (getenv "DIAM") ">: ")))
        (setenv "DIAM" (rtos a))
        ) ;_  end if
        (command "_circle" "_ttr" pause pause (rtos (/ (atof (getenv "DIAM")) 2)))
    ) ;_  end defun
  8. #8
    Forum Deity David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    2,547
    totzky,
    You need a lot of trapping on something like this to insure the command call is complete.
    I take the approach of having all of the values before calling CIRCLE:
    Code:
    (defun c:ctd (/ olderr oldsnp lent dia pt1 pt2)
      (setq olderr *error*
           *error* (lambda (e)
                     (while (> (getvar "CMDACTIVE") 0)
                            (command))
                     (and (/= e "quit / exit abort")
                          (princ (strcat "\nError: *** " e " *** "))))
           oldsnp (getvar "OSMODE"))
      (setvar "OSMODE" 512)
      (setvar "CMDECHO" 0)
      (setq lent (entlast))
      (initget 7)
      (setq dia (getdist "\nDiameter:   "))
      (while (not pt1)
             (setq pt1 (osnap (getpoint "\nSelect 1st TANGENT Point:  ") "_TAN")))
      (while (not pt2)
             (setq pt2 (osnap (getpoint "\nSelect 2nd TANGENT Point:  ") "_TAN")))
      (command "_.CIRCLE" "_TTR" pt1 pt2 (/ dia 2.))
      (and (eq lent (entlast))
           (princ "\nCommand Failed..."))
      (setvar "OSMODE" oldsnp)
      (setq *error* olderr)
      (prin1))
    Good Luck -David
    R12 (Dos) - A2K
  9. #9
    Senior Member
    AutoCAD 2000
    Nov 2008
    182
    Test your code David and this is what happens,
    Command: ctd
    Diameter: 100
    Select 1st TANGENT Point: *Cancel* (At this point I pressed ESCAPE)
    Error: *** Function cancelled ***
  10. #10
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD pre 2000
    Dec 2003
    2,547
    Kinda lost me there ?
    Did you pick a valid tangent point?
    -David
    R12 (Dos) - A2K
  1. Creating a shortcut for a command and a layer
    By Siberian in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Nov 2007, 08:43 pm
  2. Shortcut Key
    By johnengineer in forum AutoCAD General
    Last Post: 10th Sep 2007, 04:32 pm
  3. Shortcut Command
    By gofindsam in forum AutoCAD Drawing Management & Output
    Last Post: 30th May 2007, 09:15 pm
  4. Tutorial: Create a command alias (keyboard shortcut)
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 18th Mar 2007, 12:11 am
  5. Line from inner circle to outer circle
    By jocaan in forum AutoCAD Beginners' Area
    Last Post: 11th Mar 2004, 09:28 pm
