Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    Junior Member
    AutoCAD 2009
    Jan 2009
    14
    Default Volume Calculation
    Hi,
    I am trying to calculate the volume of a stockpile of material which has been drawin using co-ordinates in AutoCad 2009. The points have X,Y and Z values (Easterns, Northerns and Levels) I am trying to find the total volume but cannot make it work. I keep getting "No solids or regions selected". I am using Tools; Enquiries; Volume. How would I make solids or regions and is this necessary?
    Any help would be greatly appreciated.
    Many thanks.
    Senior Member arjun_samar's Avatar
    AutoCAD 2009
    Dec 2008
    Samar,Philippines
    182
    Quote Originally Posted by chap_engineer View Post
    Hi,
    Many thanks.
    sir welcome to the cadtutor forum....
    im not really sure.. i think, for you to be able to determine if the object is solid or not...
    select the object then Ctrl+1 to see the object's properties
    in the upper part of the pallet so can weather if the object is 3d solid etc.....
    hope it may help you sir....
    and dont worry to your question, im sure some of the best cad users can answer it
    Full Member RichterGMC's Avatar
    Map 3D 2008
    Sep 2008
    Alberta, Canada
    51
    I would use Land Development Desktop for this, creating a surface out of the points from the stockpile and then drawing a polyline representing the general shape of the stockpile and creating a surface out of that, making sure the polyline is connected to the outermost nodes of the pile. Does that make sense? Do you have access to LDD? Have you ever done a volume comparison between 2 surfaces?
    Super Member rustysilo's Avatar
    rustysilo's Computer Details
    WinXP
    Civil
    rustysilo's Discipline Details
    Senior CAD Draftsman
    Civil
    Civil 3D 2008
    Jul 2007
    Jacksonville, FL - USA
    1,458
    Yes, the best thing would be to use a civil product like Land Desktop, Civil 3d (the replacement product for Land Desktop), or another non-Autodesk software.
    You can use regular AutoCAD and create solids to get a volume, but if you have a large stock pile then it may be a little harder for your computer to digest. You would need to go to the 3d forums for assistance with doing it this way. I believe you would want to create contour lines, then loft them together into a solid which you could then get a volume on.
    "Constantly choosing the lesser of two evils is still choosing evil." ~ Jerry Garcia
    flickr |
    work | blog | creed
    rustysilo's tips & tutorials
  5. #5
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,590
    you might be able to use the LOFT command, look it up in help
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  6. #6
    Full Member Jaelin's Avatar
    Jaelin's Computer Details
    Windows XP (Service Pack 2)
    HP Workstation xw6200 (piece of junk :) )
    Intel Xeon CPU 3.40ghz
    4GB
    NVIDIA Quadro NVS 280 PCI 64MB
    300GB
    HP p930 & HP 1955
    Civil 3D 2009
    Dec 2008
    Bartow, Florida
    86
    I would agree with RichterGMC on this. We recently had to do volume calcs for dirt stockpiles and we found that this was the easiest way for us to do it. We used Civil 3D's Land Desktop Companion to do it.
  7. #7
    Junior Member
    AutoCAD 2009
    Jan 2009
    14
    Might be a silly question, but is Civil 3D an additional application seperate from AutoCAD? Or is it a package within it?
    Thanks
  8. #8
    Map 3D 2008
    Sep 2008
    Alberta, Canada
    51
    No such thing as a silly question, that's why we have forums
    Civil 3D is a program such as AutoCAD Map 3D, Land Desktop, AutoCAD itself, etc.
    You do not need, as far as I am aware, AutoCAD installed on your system to run Civil 3D, I believe it is its own entity. Please correct me if I'm wrong
  9. #9
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Civil 3D runs within Acad; when you purchase a license for C3D, it comes with Autocad.
  10. #10
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,400
    There are some free software programs out there that will calculate volumes etc search the net. One that comes to mind is Ezysurf
  1. Calculation of Area and Length
    By vipulgos in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Nov 2008, 04:01 pm
  2. Distance Calculation
    By jose_john in forum AutoCAD Beginners' Area
    Last Post: 21st Aug 2008, 12:54 pm
  3. volume calculation of a cross-section by rotating around the central axis
    By Brian in forum AutoCAD Drawing Management & Output
    Last Post: 29th Oct 2007, 09:33 pm
  4. calculation
    By cadmuska in forum AutoCAD Drawing Management & Output
    Last Post: 24th Jul 2006, 02:07 pm
  5. Scaling Calculation
    Last Post: 12th Jun 2006, 05:45 am
