Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 49 of 49
  1. #41
    Full Member
    AutoCAD 2008
    Jan 2009
    46
    thanks so much, uve been a huge help today. ealry start tomorow then as the deadline is looming.
    just a few things, u mentions my units im millimeters, are you sure, as i set them in meters and when i checked they still were in meters. also as you said ive been drawing each wall line seperatly abd then using the offset function to create the wall thickness. so you think its better if i actually do everything in rectangles, each individual wall??
    thanks again
  2. #42
    Super Member chelsea1307's Avatar
    chelsea1307's Computer Details
    windows xp
    AutoCAD 2011
    Sep 2008
    Sacramento, Ca USA
    1,109
    doing individual lines and offsetting them wont give you a 3d solid which is what your looking for. You can do it with polylines also but the wall needs to be one entity when you extrude it. in other words when you click it the entire wall should be selected not just one line of the wall.
    "The problem is stupidity. I am not saying there should be capital punishment for stupidity, but, why don't we just take the safety labels off of everything and let the problem solve itself? "
  3. #43
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,643
    Sounds like the OP missed the lecture about what constitutes an object that can be extruded and the various ways to go about obtaining such an object using polylines, or lines then the PEdit command, or the Boundary or Region commands. I suspected he actually had a separate interior and exterior wall with just "space" between the two and not a "solid" wall after rereading through his posts. It's a shame he discovered this fact so far into his drawing. He's got some ground to retrace.
  4. #44
    Senior Member arjun_samar's Avatar
    AutoCAD 2009
    Dec 2008
    Samar,Philippines
    182
    Quote Originally Posted by MaxwellEdison View Post
    I recommend thinking in terms of converting your floorplan to 3d. Use rectangles for the entire length of a wall and seperate rectangles for doors/windows, this will allow you later to easily extrude everything and subtract out your openings. I'd also take the time to model your doors and windows so that you can easily insert them later. If time is an issue (when isn't it ) XRef those features in and start with simple 3d blocks. then when its time to add polish you can go into the file to work on each one individually and update the drawing globally. Start with a simple but sound wall layout and layer in the details until you run out of time or patience. Also don't forget the color faces command available under SOLIDEDIT for a quick and easy way to slap on a coat of paint to a room. And check out sites like Cad Block Exchange Network to find furniture or other things you need. Also Kohler and Kraftmaid have some pretty good surface models available through i-drop.
    good day sir,
    so far... im not familliar with xref... and what do you mean by udate the drawing globally?
    and if possible are there step by step tutorial ?
  5. #45
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,643
    I think he is referring to swapping out the "simple 3d blocks" with a "finished block" of greater detail.
  6. #46
    AutoCAD 2009
    Dec 2008
    Samar,Philippines
    182
    then putting all the detailed block in the drawing?
  7. #47
    Super Member MaxwellEdison's Avatar
    MaxwellEdison's Computer Details
    Win 7 (64-bit)
    HP h8-1070t
    Intel Core i72600
    12GB
    AMD Radeon HD 6850
    Dell 20" LCD Widescreen (Main) NEC Accusync 125F 20" CRT (Secondary)
    Architecture 2012
    Dec 2008
    Lebanon, PA
    749
    For the detailed XRef explaination I'd recommend reading over the Help File first. But as simply as I can put it; an Xref (External Reference) is bringing another drawing in as a block. When you change the source file, every drawing that has it Xref'ed in will update when you open the file or reload the Xref.
    As for updating globally, I simply mean you can edit the Xref and update your block drawing and every insatnace will be updated autoatically when you open the file.
    And as for tutorials...You're better off asking Google, than asking me. :smirk:
    Just because you're , doesn't mean wrong is all that's .
  8. #48
    Win 7 (64-bit)
    HP h8-1070t
    Intel Core i72600
    12GB
    AMD Radeon HD 6850
    Architecture 2012
    Dec 2008
    Lebanon, PA
    749
    Actually I meant to start with Xref'ed placeholder blocks, and then go back and "prettify" them once the rest of the structure is done. You could accomplish the same thing with blocks, but Xref's will keep your filesize down. If you need to turn in the actual file, you can simply bind all the Xref's as inserted blocks so you don't need to worry about seperate files or pathing problems.
  9. #49
    AutoCAD 2009
    Dec 2008
    Samar,Philippines
    182
    ok... i'll try to look for more explanitions on xref... thanks a lot...
  1. Need house plans for practice
    By haneet22 in forum Blocks, Images, Models & Materials
    Last Post: 30th Aug 2012, 09:42 pm
  2. 3D House Plans
    By hust0051 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Feb 2012, 09:01 am
  3. Autocad book - house plans and house 3D
    By crjones1 in forum AutoCAD Beginners' Area
    Last Post: 17th Dec 2007, 07:36 pm
  4. Working with house plans
    By edgley in forum AutoCAD Beginners' Area
    Last Post: 31st Aug 2007, 05:31 pm
