Results 1 to 3 of 3
    Senior Member
    AutoCAD 2009
    Mar 2007
    475
    Question how can i make 2 commands happen with one click of a toolbar button??
    i need to change the macro in the CUI so that when i click on a button in the toolbar it runs a command prior to the command i want to call up.
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,816
    You could call the command and add a line of pauses until the next command, in LISP it looks like this:
    Code:
    (command....)
    (while (> (getvar "cmdactive") 0) (command pause))
    (command....)
    Lee Mac Programming
    Just another Swamper
    Senior Member brawleyman's Avatar
    brawleyman's Computer Details
    Windows 7
    Dell Precision T3500
    Intel Xeon W3530 (4x2.8Ghz)
    6Gb DDR3
    Nvidia Quadro 600
    250Gb
    Asus 20" 1680x1050, Samsung 24" 1920x1080
    AutoCAD 2010
    Oct 2008
    Bentonville, AR
    100
    Macro is where I first started in customizing commands, then I moved up to working in LISP (which I am still having a hard time working with). I created several custom macro's that contained over 10 commands in a single button click!
    What commands are you wanting to combine? First, create a new command or copy the command that will be first in your macro. Set up the macro for the first command to do what you want, then at the end, put in ";" which acts like when you type enter which ends the first command, then ^C^C and the name of the second command you want.
    Afterwards, you can create a custom icon or button image for your custom macro. Just remember, you never want to mess with the original macro commands, just copy and manipulate it that way.
    ***EDIT***
    I forgot, when you have more than one command in a macro, if you choose to do it that way, use "+" after the last ";" and before ^C^C. Here is an example:
    ^C^Cselect;\pedit;m;previous;;j;j;a;12";+^C^Cfille t;p;last;
    Guess what? I got a fever! And the only prescription.. is more Cad Lines!
  1. Flyout toolbar auto open (no mouse click)
    By sloman in forum AutoCAD Beginners' Area
    Last Post: 10th Dec 2007, 07:23 am
  2. make ESC key a toolbar button
    By autoadam in forum Tutorials & Tips'n'Tricks
    Last Post: 20th Mar 2007, 03:14 am
  3. a toolbar button for an SQL request...
    By najd in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Jul 2006, 09:13 am
  4. Button Commands
    By Teeds in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Aug 2005, 04:05 pm
  5. How to make this custom toolbar button?
    By Cadastrophic in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Oct 2004, 01:23 am
