Results 1 to 4 of 4
    Super Member dumfatnhappy's Avatar
    dumfatnhappy's Computer Details
    Windows 7 64 bit
    3.6 dual quad core
    24 gig
    Quadro FX 1700
    269?
    twin 24" flat panels
    Mechanical
    dumfatnhappy's Discipline Details
    mechanical design (Petro-Chem)
    Mechanical
    Process piping (3D)
    MEP 2013
    Oct 2007
    Apollo Beach, Fla
    659
    Default trying to draw a "transition"
    as per the attached, I need a transition or 'boot' for this classifier to hit the conveyor. The odd part is the 'ellipse' is at a slght angle and the opening in the conveyor is a true circle.
    #1 how can I make a transition (what command am I lacking)
    #2 how can you keep the mesh from 'twisting when doing a rulesurf. (I've experienced thes for mana manay years)
    dum
    'Suppose you were an idiot. And suppose you were a member of Congress.. But I repeat myself.'
    --Mark Twain
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,483
    use the LOFT command.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
    Windows 7 64 bit
    3.6 dual quad core
    24 gig
    Quadro FX 1700
    269?
    Mechanical
    Mechanical
    Process piping (3D)
    MEP 2013
    Oct 2007
    Apollo Beach, Fla
    659
    Default awesome
    Quote Originally Posted by StykFacE View Post
    I did but kept trying "guides", etc.....
    I just stayed with the prompts and it worked. Thanks Styke. It looks funny in wireframe but is good when rendered...
    dum
    --Mark Twain
    Forum Deity shift1313's Avatar
    not applicable
    Sep 2008
    VA
    2,859
    the rule surf issue probably has to do with the selection process. glad you go it with loft.
  1. "save" in the file "pull down menu" not working
    By kfarrar in forum Civil 3D & LDD
    Last Post: 17th Feb 2010, 06:45 am
  2. Why do people use a "," rather than a "." as a decimal point?
    By Tempest in forum AutoCAD Beginners' Area
    Last Post: 10th Nov 2007, 12:32 am
  3. Convert "body" to "Solid"
    By powerdog in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Jun 2007, 04:11 pm
  4. "LINK template" icons "greyed out" -why?
    By Chrisjpritchard in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Mar 2007, 10:25 pm
  5. "Union" Meshes or "Slice" 3D Mesh
    By Peter31712 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Apr 2004, 11:11 pm
