Results 1 to 3 of 3
    Super Member rustysilo's Avatar
    Civil 3D 2008
    Jul 2007
    Jacksonville, FL - USA
    1,448
    Default ATTEXT Gone Awry
    I'm extracting attribute info to create a tree mitigation table and there is an attribute for tree size which for some reason on 4 of my trees is pulling the info from another attribute for some reason. Here is the output of a portion of the file:
    Code:
     1454.42,'22.04 LT','OAK',22.0,'INSIDE', 8.00
     1440.61,'20.78 LT','OAK',10.0,'INSIDE', 9.22
     1430.24,'22.67 LT','UNK',12.0,'INSIDE', 7.33
     1377.69,'24.45 LT','PINE',17.0,'INSIDE', 5.54
     1368.81,'22.35 LT','CAMPHOR', 6.0,'INSIDE', 7.64
     1680.31,'18.93 RT','MYRTLE',1680,'INSIDE', 11.07
     1495.83,'23.90 RT','PINE',24.0,'INSIDE', 6.10
     1476.25,'18.99 RT','MYRTLE',1476,'INSIDE', 11.01
     1461.54,'19.74 RT','MYRTLE',1461,'INSIDE', 10.26
     1449.16,'19.16 RT','MYRTLE',1449,'INSIDE', 10.84
    Note that the numbers in red are supposed to be the tree size and it is rather putting the station (1st column) value there. The attributes are properly filled in. Something is going bad when I extract the data only on these lines.
    "Constantly choosing the lesser of two evils is still choosing evil." ~ Jerry Garcia
    flickr | myspace
    | work | business | creed
    rustysilo's tips & tutorials
    Civil 3D 2008
    Jul 2007
    1,448
    Duh nevermind. I figured it out. There is no size value as the surveyor didn't give the size so I put n/a in the attribute... Sorry bout that.
    flickr | myspace
    Forum Newbie
    AutoCAD LT 2010
    Sep 2009
    1
    Unhappy Attext
    Rusty,
    How did you get that far. Been trying over the weekend to get a single field out using ATTEXT.
    Do you have a sample of your template?
    Haven been trying the things from ACAD Help without luck. Searching forums looking for an answer. You seem to have at least gotten it to work. Using 2010 LT. running out of hair. Starting to look like that smily face :-(
    CJ
    Quote Originally Posted by rustysilo View Post
    Code:
  1. Simple, Command customization question: -attext
    By TuFoFi in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Sep 2008, 05:23 am
  2. Attext
    By Maltacad in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Feb 2008, 10:42 am
  3. counting blocks using ATTEXT
    By explorer in forum AutoCAD Drawing Management & Output
    Last Post: 19th Jul 2007, 05:05 pm
  4. HELP! My aperature size has gone awry.
    By amattintime in forum AutoCAD Drawing Management & Output
    Last Post: 12th Oct 2006, 02:55 pm
