Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 21
  1. #11
    Super Member ASMI's Avatar
    AutoCAD 2008
    Nov 2005
    Oceanus Procellarum, Moon
    1,427
    <-- Please read post before.
    Code:
    (defun c:dwrite(/ plObj stBl enBl datLst cAns hyObj okFlg cMat mLst mNum)
    ; ************ MODIFY LIST OF MATERIALS ************
      (setq mLst '(
    	       (0 . "N/A")
    	       (1 . "DIN 2391")
    	       (2 . "DIN 2392")
    	       (3 . "DIN 2394")
    	); end setq
    ; ************ MODIFY DEFAULT MATERIAL ************
      (if(not dwrite:material)
         (setq dwrite:material "N/A")
        ); end if
      (defun Entsel_or_Text(Spaces Message / lChr tStr grLst filPt
    			selSet outVal pSps)
      (princ Message)
      (setq tStr ""); end setq
      (if Spaces
        (setq pSps(list "\r"))
        (setq pSps(list " " "\r"))
        ); end if
       (while
          (and
            (not(member lChr pSps))
    	(/= 3(car grLst))
            ); end and
          (if
            (setq grLst(grread nil 4 2))
             (cond
              ((= 3(car grLst))
               (setq filPt(cadr grLst)
                     selSet(ssget filPt)
                     ); end setq
               (if selSet
                    (setq outVal
                    (list(ssname selSet 0)filPt))
                 ); end if
               ); end condition #1
    	  ((or
    	     (equal '(2 13) grLst)
    	     (equal 25(car grLst))
    	     ); end or
    	    (setq lChr "\r"
    		  outVal tStr); end setq
    	   ); end condition #2
    	  ((and
    	     (equal '(2 8) grLst)
    	     (< 0(strlen tStr))
    	     ); end and
    	   (setq tStr(substr tStr 1(1-(strlen tStr))))
    	   (princ(strcat(chr 8)(chr 32)(chr 8)))
    	   ); end condition #3
              ((and
    	     (= 2(car grLst))
    	     (<= 32(cadr grLst)126)
    	     ); end and
               (setq lChr(chr(cadr grLst)))
               (if(not(member lChr pSps))
                     (setq tStr(strcat tStr lChr)
                 (princ lChr)
               ); end progn
              ); end if
             ); end condition #4
            ); end cond
           ); end progn
          ); end if
         ); end while
        outVal
     ); end of Entsel_or_Text
      (while(not okFlg)
        (princ(strcat "\nCurrent material = " dwrite:material))
        (setq plObj(Entsel_or_Text T "\nSelect polyline or [Material]: "))
        (cond
          ((and
    	  (= 'LIST(type plObj))
    	  (= "LWPOLYLINE"(cdr(assoc 0(entget(car plObj)))))
    	 ); end and
           (setq plObj(car plObj)
    	     okFlg T); end setq
           ); end condition #1
          ((= 'LIST(type plObj))
           (princ "\nThis isn't LwPolyline! ")
           ); end condition #2
          ((and
    	 (= 'STR(type plObj))
    	 (member(strcase plObj) '("M" "_M" "MATERIAL" "_MATERIAL"))
    	 ); end and
           (textscr)
           (princ "\n====== MATERIAL LIST ======")
           (foreach m mLst
    	 (princ(strcat "\n[" (itoa(car m)) "] - "(cdr m)))
    	 ); end foreach
           (princ "\n===========================")
           (setq mNum(getint "\nSelect material from list: "))
           (if(and mNum(setq cMat(assoc mNum mLst)))
    	   (setq dwrite:material(cdr cMat))
    	   (graphscr)
    	   ); end progn
    	 (princ "\nCan't find material with this number! ")
    	 ); end if
           ); end condition #3
          ((null plObj)
            (princ "\nEmpty selection! ")
           ); end condition #4
          (T
           (princ "\nInvalid keyword option! ")
           ); end condition #5
          ); end cond
        ); end while
      (while(not stBl)
        (setq stBl(Entsel_or_Text T "\nSelect 'Begin' block or type name: "))
        (cond
          ((and
    	 (= 'LIST(type stBl))
    	 (= "INSERT"(cdr(assoc 0(entget(car stBl)))))
    	); end and
            (setq stBl(cdr(assoc 2(entget(car stBl)))))
           ); end condition #1
          ((= 'LIST(type stBl))
            (princ "\nThis isn't block! ")
            (setq stBl nil)
           ); end condition #2
          ((null stBl)
           (princ "\nEmpty input! ")
           ); end condition #3
          ); end cond
        ); end while
     (while(not enBl)
        (setq enBl(Entsel_or_Text T "\nSelect 'End' block or type name: "))
        (cond
          ((and
    	 (= 'LIST(type enBl))
    	 (= "INSERT"(cdr(assoc 0(entget(car enBl)))))
    	); end and
            (setq enBl(cdr(assoc 2(entget(car enBl)))))
           ); end condition #1
          ((= 'LIST(type enBl))
            (setq enBl nil)
           ); end condition #2
          ((null enBl)
           ); end condition #3
          ); end cond
        ); end while
      (setq datLst(list(cons 1 stBl)(cons 2 enBl)(cons 3 dwrite:material))
    	plObj(vlax-ename->vla-object plObj)
    	hyObj(vla-get-Hyperlinks plObj)
    	); end setq
      (if(vlax-ldata-get plObj "PipeData")
    	(initget "Yes No")
    	(setq cAns(getkword "\nPipe data already exists. Overwrite? [Yes/No]<Yes>: "))
    	(if(null cAns)(setq cAns "Yes"))
    	(if(= "Yes" cAns)
    	   (vlax-ldata-delete plObj "PipeData")
    	   (vlax-ldata-put plObj "PipeData" datLst)
    	   (vla-Delete(vla-Item hyObj 0))
    	   (vla-Add hyObj "Has Pipe Data" (strcat "ID: "  (itoa(vla-get-ObjectID plObj))
    					          "\nMaterial: " dwrite:material
    					          "\nLength: " (rtos(vlax-curve-GetDistAtParam plObj
    						                       (vlax-curve-GetEndParam plObj)))))
    	   (princ "\n<<< Data successfuly added >>> ")
    	   ); end progn
    	  ); end if
    	); end progn
           ); end progn
          ); end if
     ); c:dwrite
    (defun c:dcollect(/ plSet oLst cDat fDescr fName cAns exApp wbCol cDoc)
      (if(setq plSet(ssget "_X" '((0 . "LWPOLYLINE"))))
          (foreach pl (mapcar 'vlax-ename->vla-object
                         (vl-remove-if 'listp
                           (mapcar 'cadr(ssnamex plSet))))
    	(if(setq cDat(vlax-ldata-get pl "PipeData"))
    	    (setq oLst(cons
    			(list
    			     (vla-get-ObjectID pl)
    			     (vla-get-ConstantWidth pl)
    			     (vla-get-Layer pl)
    			     (cdr(assoc 1 cDat))
    			     (cdr(assoc 2 cDat))
    			     (cdr(assoc 3 cDat))
    			       (vlax-curve-GetEndParam pl))
    			    ); end list
    		      oLst); end cons
    		  ); end setq
    	    ); end progn
    	  ); end if
    	); end foreach
          (if oLst
    	  (setq fDescr(open
    			(setq fName(strcat(vl-filename-directory(getvar "SAVENAME"))
    			  "\\"(vl-filename-base(getvar "DWGNAME")) ".csv")) "w"))
    	  (write-line "Pipe ID;Diameter;Layer;From;To;Material;Length" fDescr)
    	  (foreach itm (reverse oLst)
    	          (write-line(strcat (itoa(nth 0 itm))
    				 ";" (strcat(rtos(* 1000.0(nth 1 itm)))
    				 ";" (nth 2 itm)
    				 ";" (nth 3 itm)
    				 ";" (nth 4 itm)
    				 ";" (nth 5 itm)
    				 ";" (rtos(nth 6 itm)))
    			  ); end strcat
    		fDescr)
    	    ); end foreach
    	  (close fDescr)
    	  (princ(strcat "\nCSV file location: " fName ))
    	  (initget "Yes No")
    	  (setq cAns(getkword "\nOpen file [Yes/No]: "))
    	  (if(= cAns "Yes")
    	    (if(setq exApp(vlax-get-or-create-object "Excel.Application"))
    		(vlax-put-property exApp 'Visible :vlax-true)
    	        (setq wbCol(vlax-get-property exApp 'Workbooks)
    		      cDoc(vlax-invoke-method wbCol 'Open fName))
    		(vlax-release-object cDoc)
    		(vlax-release-object wbCol)
    		(vlax-release-object exApp)
    		); end progn
    	      ); end if
    	    ); end if
    	  ); end progn
    	(princ "\nNo data found! ")
    	); end if
          ); end progn
        ); end if
      ); end of c:dcollect
    (defun c:ddata(/ cEnt cDat cPln)
      (if(setq cEnt(entsel "\nSelect polyline to view data: "))
        (if(= "LWPOLYLINE"(cdr(assoc 0(entget(car cEnt)))))
          (if(setq cDat(vlax-ldata-get(setq cPln(vlax-ename->vla-object(car cEnt))) "PipeData"))
    	(alert(strcat
    		"                   PIPE DATA                 \n"
    		"\nPipe ID: " (itoa(vla-get-ObjectID cPln))
    		"\nDiameter: " (rtos(* 1000.0(vla-get-ConstantWidth cPln)2 0))
    		"\nLayer: " (vla-get-Layer cPln)
    		"\nFrom: " (cdr(assoc 1 cDat))
    		"\nTo: " (cdr(assoc 2 cDat))
    		"\nMaterial: " (cdr(assoc 3 cDat))
    		"\nLength: " (rtos(vlax-curve-GetDistAtParam cPln
    			           (vlax-curve-GetEndParam cPln)))
    		); end strcat
    	      ); end alert
    	); end if
          ); end if
        (princ "\nNothing selected! ")
        ); end if
      ); end of c:ddata
    (defun c:ddelete(/ cCnt cAns plSet cDat hyCol cHyp)
      (initget 1 "All Selection")
      (setq cAns(getkword "\nWhich data to delete [All/Selection]: ")
    	cCnt 0)
      (if(= cAns "All")
        (setq plSet(ssget '((0 . "LWPOLYLINE"))))
        ); end if
      (getstring "\n*** WARNING! All data will deleted. Enter to Continue or Esc to Quite. ***")
      (if plSet
    	    (vlax-ldata-delete pl "PipeData")
    	    (setq cCnt(1+ cCnt))
    	    ); end progn
    	  ); end if
                (vlax-for hy(vla-get-Hyperlinks pl)
    	      (if(= "Has Pipe Data"(vla-get-URL hy))
    		(vla-Delete hy)
    		); end vlax-for
    	      ); end vlax-for
    	); end foreach
          (if(/= 0 cCnt)
    	(princ(strcat "\n<<< " (itoa cCnt) " item(s) was deleted >>> "))
    	(princ "\nNothing data found! ")
    	); end if
          ); end progn
        ); end if
      ); end of c:ddelete
    (vl-load-com)
    DWRITE - write data
    DCOLLECT - put data to *.csv file
    DDATA - view data
    DDELETE - remove all or selected data
  2. #12
    AutoCAD 2008
    Nov 2005
    1,427
    Fogot to say. Please remove all old data with DDELETE command befor you will test the current version.
  3. #13
    Senior Member
    feargt's Computer Details
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    319
    Thanks again ASMI, will try that out tomorrow in the office and give u any feedback. Your assistance is much appreciated.
  4. #14
    Forum Deity
    AutoCAD 2009
    Oct 2008
    2,112
    Nice coding ASMI,
    But I am curious. Is there a way to change existing data that has been already attached and can each piece of data be parced to a separate cell. It seems that if you wanted to change existing data on an object you would need to erase that object and start over, So I do not see much of an advantage to attaching data in this manner.
    Excellent Work Anyway,
    And Thanks For Your Posts
    They Are Very Informative.
    The Buzzard
  5. #15
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    319
    In the code from asmi, it is possible to overwrite existing data, it will ask the user first if they wish to overwrite the data.
  6. #16
    Forum Deity
    AutoCAD 2009
    Oct 2008
    2,112
    Thats great,
    But if you had multiple pieces of data attached to the same object, How would you be able to call up a specific piece to overwrite?
    Would it prompt you then for all the data that is attached?
  7. #17
    Forum Deity
    AutoCAD 2009
    Oct 2008
    2,112
    Ok
    I see it now, Sorry about that. Great program!.
    But still is there a way to parce the data to separate cells in the spreadsheet?
  8. #18
    AutoCAD 2008
    Nov 2005
    1,427
    Is there a way to change existing data that has been already attached...
    Yes
    ...and can each piece of data be parced to a separate cell.
    These, and so are in separate cells (in the associative list ((Tag. Data )...) )and are extracted in separate cells in the CSV file.
    It seems that if you wanted to change existing data on an object you would need to erase that object and start over,...
    There is no need to remove the objects are removed only the data. But you can not just delete and add data. Theoretically, you can add to polyline the British Encyclopedia, moreover, each chapter will be in his cell.
    Can you suggest other ways? Yes, they exist. For example link to a database in Extended Data. But in this case it is better to use the Dictionary because the amount of data is low and the database does not exist.
  9. #19
    Forum Deity
    AutoCAD 2009
    Oct 2008
    2,112
    Thank You, This Is A Very Informative Thread.
  10. #20
    AutoCAD 2008
    Nov 2005
    1,427
    The data you have in a one cell?
    In this case, I use a single key and an associative list inside it, but you can use a lot of keys and a variety of data within them with the possibility of a separate access.
  1. Extracting Object Data, convert to text
    By jerrodt in forum Autodesk Software General
    Last Post: 20th Jun 2012, 09:07 am
  2. Extracting Data from Blocks for Parts List
    By ziemerd in forum AutoCAD Drawing Management & Output
    Last Post: 17th Nov 2008, 11:32 pm
  3. extracting spline data
    By motee-z in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st May 2006, 11:57 am
  4. Extracting Data
    By LSR in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Jun 2005, 08:41 pm
  5. Extracting attribute data
    By j_r_auden in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Feb 2005, 09:23 pm
