ASMI, what program can I use to write this code? I am trying to write a command for AutoCAD where it would read the attribute of the block within a polyline and extract the data to excel file. Please help. Thank you!<-- Please read post before.
DWRITE - write dataCode:(defun c:dwrite(/ plObj stBl enBl datLst cAns hyObj okFlg cMat mLst mNum) ; ************ MODIFY LIST OF MATERIALS ************ (setq mLst '( (0 . "N/A") (1 . "DIN 2391") (2 . "DIN 2392") (3 . "DIN 2394") ) ); end setq ; ************ MODIFY DEFAULT MATERIAL ************ (if(not dwrite:material) (setq dwrite:material "N/A") ); end if (defun Entsel_or_Text(Spaces Message / lChr tStr grLst filPt selSet outVal pSps) (princ Message) (setq tStr ""); end setq (if Spaces (setq pSps(list "\r")) (setq pSps(list " " "\r")) ); end if (while (and (not(member lChr pSps)) (/= 3(car grLst)) ); end and (if (setq grLst(grread nil 4 2)) (progn (cond ((= 3(car grLst)) (setq filPt(cadr grLst) selSet(ssget filPt) ); end setq (if selSet (setq outVal (list(ssname selSet 0)filPt)) ); end if ); end condition #1 ((or (equal '(2 13) grLst) (equal 25(car grLst)) ); end or (setq lChr "\r" outVal tStr); end setq ); end condition #2 ((and (equal '(2 8) grLst) (< 0(strlen tStr)) ); end and (setq tStr(substr tStr 1(1-(strlen tStr)))) (princ(strcat(chr 8)(chr 32)(chr 8))) ); end condition #3 ((and (= 2(car grLst)) (<= 32(cadr grLst)126) ); end and (setq lChr(chr(cadr grLst))) (if(not(member lChr pSps)) (progn (setq tStr(strcat tStr lChr) outVal tStr); end setq (princ lChr) ); end progn ); end if ); end condition #4 ); end cond ); end progn ); end if ); end while outVal ); end of Entsel_or_Text (while(not okFlg) (princ(strcat "\nCurrent material = " dwrite:material)) (setq plObj(Entsel_or_Text T "\nSelect polyline or [Material]: ")) (cond ((and (= 'LIST(type plObj)) (= "LWPOLYLINE"(cdr(assoc 0(entget(car plObj))))) ); end and (setq plObj(car plObj) okFlg T); end setq ); end condition #1 ((= 'LIST(type plObj)) (princ "\nThis isn't LwPolyline! ") ); end condition #2 ((and (= 'STR(type plObj)) (member(strcase plObj) '("M" "_M" "MATERIAL" "_MATERIAL")) ); end and (textscr) (princ "\n====== MATERIAL LIST ======") (foreach m mLst (princ(strcat "\n[" (itoa(car m)) "] - "(cdr m))) ); end foreach (princ "\n===========================") (setq mNum(getint "\nSelect material from list: ")) (if(and mNum(setq cMat(assoc mNum mLst))) (progn (setq dwrite:material(cdr cMat)) (graphscr) ); end progn (princ "\nCan't find material with this number! ") ); end if ); end condition #3 ((null plObj) (princ "\nEmpty selection! ") ); end condition #4 (T (princ "\nInvalid keyword option! ") ); end condition #5 ); end cond ); end while (while(not stBl) (setq stBl(Entsel_or_Text T "\nSelect 'Begin' block or type name: ")) (cond ((and (= 'LIST(type stBl)) (= "INSERT"(cdr(assoc 0(entget(car stBl))))) ); end and (setq stBl(cdr(assoc 2(entget(car stBl))))) ); end condition #1 ((= 'LIST(type stBl)) (princ "\nThis isn't block! ") (setq stBl nil) ); end condition #2 ((null stBl) (princ "\nEmpty input! ") ); end condition #3 ); end cond ); end while (while(not enBl) (setq enBl(Entsel_or_Text T "\nSelect 'End' block or type name: ")) (cond ((and (= 'LIST(type enBl)) (= "INSERT"(cdr(assoc 0(entget(car enBl))))) ); end and (setq enBl(cdr(assoc 2(entget(car enBl))))) ); end condition #1 ((= 'LIST(type enBl)) (princ "\nThis isn't block! ") (setq enBl nil) ); end condition #2 ((null enBl) (princ "\nEmpty input! ") ); end condition #3 ); end cond ); end while (setq datLst(list(cons 1 stBl)(cons 2 enBl)(cons 3 dwrite:material)) plObj(vlax-ename->vla-object plObj) hyObj(vla-get-Hyperlinks plObj) ); end setq (if(vlax-ldata-get plObj "PipeData") (progn (initget "Yes No") (setq cAns(getkword "\nPipe data already exists. Overwrite? [Yes/No]<Yes>: ")) (if(null cAns)(setq cAns "Yes")) (if(= "Yes" cAns) (progn (vlax-ldata-delete plObj "PipeData") (vlax-ldata-put plObj "PipeData" datLst) (vla-Delete(vla-Item hyObj 0)) (vla-Add hyObj "Has Pipe Data" (strcat "ID: " (itoa(vla-get-ObjectID plObj)) "\nMaterial: " dwrite:material "\nLength: " (rtos(vlax-curve-GetDistAtParam plObj (vlax-curve-GetEndParam plObj))))) (princ "\n<<< Data successfuly added >>> ") ); end progn ); end if ); end progn (progn (vlax-ldata-put plObj "PipeData" datLst) (vla-Add hyObj "Has Pipe Data" (strcat "ID: " (itoa(vla-get-ObjectID plObj)) "\nMaterial: " dwrite:material "\nLength: " (rtos(vlax-curve-GetDistAtParam plObj (vlax-curve-GetEndParam plObj))))) (princ "\n<<< Data successfuly added >>> ") ); end progn ); end if (princ) ); c:dwrite (defun c:dcollect(/ plSet oLst cDat fDescr fName cAns exApp wbCol cDoc) (if(setq plSet(ssget "_X" '((0 . "LWPOLYLINE")))) (progn (foreach pl (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr(ssnamex plSet)))) (if(setq cDat(vlax-ldata-get pl "PipeData")) (progn (setq oLst(cons (list (vla-get-ObjectID pl) (vla-get-ConstantWidth pl) (vla-get-Layer pl) (cdr(assoc 1 cDat)) (cdr(assoc 2 cDat)) (cdr(assoc 3 cDat)) (vlax-curve-GetDistAtParam pl (vlax-curve-GetEndParam pl)) ); end list oLst); end cons ); end setq ); end progn ); end if ); end foreach (if oLst (progn (setq fDescr(open (setq fName(strcat(vl-filename-directory(getvar "SAVENAME")) "\\"(vl-filename-base(getvar "DWGNAME")) ".csv")) "w")) (write-line "Pipe ID;Diameter;Layer;From;To;Material;Length" fDescr) (foreach itm (reverse oLst) (write-line(strcat (itoa(nth 0 itm)) ";" (strcat(rtos(* 1000.0(nth 1 itm))) ";" (nth 2 itm) ";" (nth 3 itm) ";" (nth 4 itm) ";" (nth 5 itm) ";" (rtos(nth 6 itm))) ); end strcat fDescr) ); end foreach (close fDescr) (princ(strcat "\nCSV file location: " fName )) (initget "Yes No") (setq cAns(getkword "\nOpen file [Yes/No]: ")) (if(= cAns "Yes") (if(setq exApp(vlax-get-or-create-object "Excel.Application")) (progn (vlax-put-property exApp 'Visible :vlax-true) (setq wbCol(vlax-get-property exApp 'Workbooks) cDoc(vlax-invoke-method wbCol 'Open fName)) (vlax-release-object cDoc) (vlax-release-object wbCol) (vlax-release-object exApp) ); end progn ); end if ); end if ); end progn (princ "\nNo data found! ") ); end if ); end progn ); end if (princ) ); end of c:dcollect (defun c:ddata(/ cEnt cDat cPln) (if(setq cEnt(entsel "\nSelect polyline to view data: ")) (if(= "LWPOLYLINE"(cdr(assoc 0(entget(car cEnt))))) (if(setq cDat(vlax-ldata-get(setq cPln(vlax-ename->vla-object(car cEnt))) "PipeData")) (alert(strcat " PIPE DATA \n" "\nPipe ID: " (itoa(vla-get-ObjectID cPln)) "\nDiameter: " (rtos(* 1000.0(vla-get-ConstantWidth cPln)2 0)) "\nLayer: " (vla-get-Layer cPln) "\nFrom: " (cdr(assoc 1 cDat)) "\nTo: " (cdr(assoc 2 cDat)) "\nMaterial: " (cdr(assoc 3 cDat)) "\nLength: " (rtos(vlax-curve-GetDistAtParam cPln (vlax-curve-GetEndParam cPln))) ); end strcat ); end alert (princ "\nNo data found! ") ); end if (princ "\nThis isn't LwPolyline! ") ); end if (princ "\nNothing selected! ") ); end if (princ) ); end of c:ddata (defun c:ddelete(/ cCnt cAns plSet cDat hyCol cHyp) (initget 1 "All Selection") (setq cAns(getkword "\nWhich data to delete [All/Selection]: ") cCnt 0) (if(= cAns "All") (setq plSet(ssget "_X" '((0 . "LWPOLYLINE")))) (setq plSet(ssget '((0 . "LWPOLYLINE")))) ); end if (getstring "\n*** WARNING! All data will deleted. Enter to Continue or Esc to Quite. ***") (if plSet (progn (foreach pl (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr(ssnamex plSet)))) (if(setq cDat(vlax-ldata-get pl "PipeData")) (progn (vlax-ldata-delete pl "PipeData") (setq cCnt(1+ cCnt)) ); end progn ); end if (vlax-for hy(vla-get-Hyperlinks pl) (if(= "Has Pipe Data"(vla-get-URL hy)) (vla-Delete hy) ); end vlax-for ); end vlax-for ); end foreach (if(/= 0 cCnt) (princ(strcat "\n<<< " (itoa cCnt) " item(s) was deleted >>> ")) (princ "\nNothing data found! ") ); end if ); end progn ); end if (princ) ); end of c:ddelete (vl-load-com)
DCOLLECT - put data to *.csv file
DDATA - view data
DDELETE - remove all or selected data
